[RFC] clang, posix: bypass static assert that does not compile with Clang
Daniel Hellstrom daniel at gaisler.com
Mon Oct 8 14:07:16 UTC 2018
Daniel Hellstrom
Software Section Head
Cobham Gaisler
T : +46 (0) 31 775 8657
F : +46 (0) 31 421407
daniel.hellstrom at gaisler.com
Cobham Gaisler AB, Kungsgatan 12, SE-411 19, GÖTEBORG, Sweden.
+46 (0) 31 775 8650, www.cobham.com/gaisler
Please consider the environment before printing this email
This e-mail and any files transmitted with it ("E-mail") is intended solely for the addressee(s) and may contain confidential and/or legally privileged information. If you are not the addressee(s), any disclosure,
reproduction, copying, distribution or other use of the E-mail is prohibited. If you have received this E-mail in error, please delete it and notify the sender immediately via our switchboard or return e-mail.
Neither the company nor any subsidiary or affiliate or associated company nor any individual sending this Email accepts any liability in respect of the content (including errors and omissions) nor shall this e-mail be deemed to enter the company or any subsidiary or affiliate or associated company into a contract or to create any legally binding obligations unless expressly agreed to in writing under separate cover and timeliness of the E-mail which arise as a result of transmission. If verification is required, please request a hard copy version from the sender.
On 2018-10-05 09:24, Sebastian Huber wrote:
> On 05/10/2018 08:57, Daniel Hellstrom wrote:
>> From: Jacob Hansen <jacob.hansen at gaisler.com>
>> This commits bypasses a static assert when using the Clang compiler.
>> This is done as the static assertion does not compile with Clang
>> ("static_assert expression is not an integral constant expression").
>> I am not sure this static assertion makes sense at all. SEM_FAILED
>> is used as a return value on failures from running sem_open(). Is
>> the test supposed to check that SEM_FAILED is defiend as NULL in the
>> included libraries (newlib) ? It is defiend as "(sem_t *) 0" in newlib.
>> The draft version of the posix standard, required sem_open to return
>> -1, so
>> maybe this is an attempt to ensure that SEM_FAILED is actually defined?
>> But the compilation would failed if SEM_FAILED is not defined anyway.
>> I guess the check would make sense if somehow the code depended on
>> SEM_FAILED to be equal to NULL. But in that case I would think the code
>> should be updated to remove this dependency.
>> Looking at the source for sem_open at cpukit/posix/src/semopen.c it
>> seems that it uses the SEM_FAILED define as a return value, and I do not
>> see any dependencies on SEM_FAILED==NULL anywhere.
>> The change that introduces this code is:
>> "posix: Implement self-contained POSIX semaphores":
>>    c090db7405b72ce6d0b726c0a39fb1c1aebab7ea
> This static assertion ensures that POSIX_SEMAPHORE_VALIDATE_OBJECT()
> rejects semaphore pointers with a SEM_FAILED value. We could change
> this macro to test also for SEM_FAILED, but it would result in code
> like this
> if (sem == 0 (aka NULL) || sem == 0 (aka SEM_FAILED) || ...)
> See also:
> https://gcc.gnu.org/ml/gcc-help/2018-10/msg00021.html
> Coverity Scan crashes at this line too. GCC issues only a -Wpedantic
> warning. In C++ the static assert would be fine. I am not sure how to
> fix this.
I just saw that you have pushed the
1d39e96470b27195d35a69cc94551c403b7980bd commit that updated the
RTEMS_STATIC_ASSERT() macro, thanks for updating this. I just wanted to
let you know that the issue I'm seeing with clang is still there:
make[5]: Entering directory
'/home/daniel/git/rtems/rcc-1.3/rtems/build/gr712rc_drvmgr_test_up/sparc-gaisler-rtems5/c/gr712rc/cpukit/posix'
sparc-gaisler-rtems5-clang --pipe -DHAVE_CONFIG_H   -I..
-I/home/daniel/git/rtems/rcc-1.3/rtems/build/gr712rc_drvmgr_test_up/sparc-gaisler-rtems5/c/gr712rc/include
-I/home/daniel/git/rtems/rcc-1.3/rtems/kernel/cpukit/include
-I/home/daniel/git/rtems/rcc-1.3/rtems/kernel/cpukit/score/cpu/sparc/include
-I/home/daniel/git/rtems/rcc-1.3/rtems/kernel/cpukit/libnetworking
-mcpu=gr712rc -O2 -g -ffunction-sections -fdata-sections -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -MT src/libposix_a-seminit.o -MD -MP -MF
src/.deps/libposix_a-seminit.Tpo -c -o src/libposix_a-seminit.o `test -f
'src/seminit.c' || echo
'/home/daniel/git/rtems/rcc-1.3/rtems/kernel/c/src/../../cpukit/posix/'`src/seminit.c
/home/daniel/git/rtems/rcc-1.3/rtems/kernel/c/src/../../cpukit/posix/src/seminit.c:25:21:
error: static_assert expression is not an integral constant expression
RTEMS_STATIC_ASSERT(NULL == SEM_FAILED, sem_failed);
/opt/rcc-1.3-rc6-llvm/lib/clang/8.0.0/include/stddef.h:105:16: note:
expanded from macro 'NULL'
#  define NULL ((void*)0)
/home/daniel/git/rtems/rcc-1.3/rtems/kernel/cpukit/include/rtems/score/basedefs.h:317:20:
note: expanded from macro 'RTEMS_STATIC_ASSERT'
     _Static_assert(cond, # msg)
note: cast from 'void *' is not allowed in a constant expression
1 error generated.
Makefile:3750: recipe for target 'src/libposix_a-seminit.o' failed
