[PATCH 01/31] shell: Use #include "..." for local header files
Tue Oct 9 05:35:08 UTC 2018
On 09/10/2018 03:41, Chris Johns wrote:
> On 8/10/18 3:43 am, Sebastian Huber wrote:
>> Update #3375.
> Why?
To keep the count of  command line arguments small. These three header
files are used only in the shell directory. They are not installed.
The <err.h> and <fts.h> are candidates for Newlib. It is a bit of work
to make them available via Newlib since they are already provided by
Cygwin. This patch set is a preparation for this:
https://sourceware.org/ml/newlib/2018/msg01004.html
> Some of these files are imported ....
>>   cpukit/libmisc/Makefile.am              | 1 -
>>   cpukit/libmisc/shell/cmp-ls.c           | 2 +-
> ... for this example this file.
I don't think the changed #include statements will cause major problems
if someone decides to merge upstream patches.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
