[PATCH] ftpd: Restructure chroot() handling.
Sebastian Huber
Tue Oct 9 06:13:39 UTC 2018
Remove superfluous setting of errno = 0.
Update #3530.
cpukit/ftpd/ftpd.c | 10 +++-------
1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/cpukit/ftpd/ftpd.c b/cpukit/ftpd/ftpd.c
index 580e55cb42..9c84ff5c43 100644
--- a/cpukit/ftpd/ftpd.c
+++ b/cpukit/ftpd/ftpd.c
@@ -1872,7 +1872,6 @@ session(rtems_task_argument arg)
while (1)
rtems_event_set set;
- int rv;
rtems_event_receive(FTPD_RTEMS_EVENT, RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT,
&set);
@@ -1882,14 +1881,11 @@ session(rtems_task_argument arg)
&& chroot(ftpd_root) == 0);
- * The chdir() must immediatly follow the chroot(), otherwise static
+ * The chdir() must immediately follow the chroot(), otherwise static
* analysis tools may complain about a security issue.
- rv = chroot_made ? chdir("/") : -1;
- errno = 0;
- if (rv == 0)
+ if (chroot_made && chdir("/") == 0)
send_reply(info, 220, FTPD_SERVER_MESSAGE);
2.16.4
