[PATCH 5/6] telnetd: Create sessions at start
Wed Oct 10 12:12:32 UTC 2018
Update #3543.
 cpukit/include/rtems/pty.h                  |  11 +-
 cpukit/telnetd/pty.c                        |  33 +-
 cpukit/telnetd/telnetd.c                    | 476 +++++++++++++++-------------
 testsuites/libtests/telnetd01/init.c        |   6 +-
 testsuites/libtests/telnetd01/telnetd01.scn |   5 +-
 5 files changed, 291 insertions(+), 240 deletions(-)
diff --git a/cpukit/include/rtems/pty.h b/cpukit/include/rtems/pty.h
index d8f886d76a..94b66d63c4 100644
--- a/cpukit/include/rtems/pty.h
+++ b/cpukit/include/rtems/pty.h
@@ -34,7 +34,16 @@ typedef struct {
   char                          name[sizeof("/dev/pty18446744073709551615")];
 } rtems_pty_context;
-char *telnet_get_pty(rtems_pty_context *ctx, int socket);
+const char *rtems_pty_initialize(rtems_pty_context *pty, uintptr_t unique);
+RTEMS_INLINE_ROUTINE const char *rtems_pty_get_path(const rtems_pty_context *pty)
+  return pty->name;
+void rtems_pty_close_socket(rtems_pty_context *pty);
+void rtems_pty_set_socket(rtems_pty_context *pty, int socket);
 #ifdef __cplusplus
diff --git a/cpukit/telnetd/pty.c b/cpukit/telnetd/pty.c
index 7a47fddbc9..8bf550d313 100644
--- a/cpukit/telnetd/pty.c
+++ b/cpukit/telnetd/pty.c
@@ -94,26 +94,37 @@ int send_iac(rtems_pty_context *pty, unsigned char mode, unsigned char option)
   return write(pty->socket, buf, sizeof(buf));
-/* This procedure returns the devname for a pty slot free.
- * If not slot availiable (field socket>=0)
- *  then the socket argument is closed
-char *telnet_get_pty(rtems_pty_context *pty, int socket)
   rtems_status_code sc;
-  struct timeval t;
   memset(pty, 0, sizeof(*pty));
-  snprintf(pty->name, sizeof(pty->name), "/dev/pty%" PRIuPTR, (uintptr_t)pty);
+  snprintf(pty->name, sizeof(pty->name), "/dev/pty%" PRIuPTR, (uintptr_t)unique);
   rtems_termios_device_context_initialize(&pty->base, "pty");
-  pty->socket = socket;
+  pty->socket = -1;
   sc = rtems_termios_device_install(pty->name, &pty_handler, NULL, &pty->base);
   if (sc != RTEMS_SUCCESSFUL) {
-    close(socket);
     return NULL;
+  return pty->name;
+  if (pty->socket >= 0) {
+    (void)close(pty->socket);
+    pty->socket = -1;
+  struct timeval t;
+  rtems_pty_close_socket(pty);
+  pty->socket = socket;
   /* set a long polling interval to save CPU time */
   t.tv_sec=2;
   t.tv_usec=00000;
@@ -121,8 +132,6 @@ char *telnet_get_pty(rtems_pty_context *pty, int socket)
   /* inform the client that we will echo */
   send_iac(pty, IAC_WILL, 1);
-  return pty->name;
diff --git a/cpukit/telnetd/telnetd.c b/cpukit/telnetd/telnetd.c
index aadf33deb7..9f2dc25c93 100644
--- a/cpukit/telnetd/telnetd.c
+++ b/cpukit/telnetd/telnetd.c
@@ -23,13 +23,13 @@
  *    possible to have 'telnetd' run an arbitrary 'shell'
  *    program.
- * Copyright (c) 2009 embedded brains GmbH and others.
+ * Copyright (c) 2009, 2018 embedded brains GmbH and others.
- * embedded brains GmbH
- * Obere Lagerstr. 30
- * D-82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ *   embedded brains GmbH
+ *   Dornierstr. 4
+ *   D-82178 Puchheim
+ *   Germany
+ *   <rtems at embedded-brains.de>
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
@@ -40,6 +40,7 @@
 #include "config.h"
 #endif
+#include <sys/queue.h>
 #include <sys/socket.h>
 #include <netinet/in.h>
 #include <arpa/inet.h>
@@ -54,201 +55,226 @@
 #include <rtems/pty.h>
 #include <rtems/shell.h>
 #include <rtems/telnetd.h>
+#include <rtems/thread.h>
 #include <rtems/userenv.h>
 #ifdef RTEMS_NETWORKING
 #endif
-#define PARANOIA
+#define TELNETD_EVENT_SUCCESS RTEMS_EVENT_0
+#define TELNETD_EVENT_ERROR RTEMS_EVENT_1
 typedef struct telnetd_context telnetd_context;
 typedef struct telnetd_session {
-  rtems_pty_context  pty;
-  char               peername[16];
-  telnetd_context   *ctx;
+  rtems_pty_context            pty;
+  char                         peername[16];
+  telnetd_context             *ctx;
+  rtems_id                     task_id;
+  LIST_ENTRY(telnetd_session)  link;
 } telnetd_session;
 struct telnetd_context {
-  rtems_telnetd_config_table config;
-  int                        server_socket;
-  uint16_t                   active_clients;
+  rtems_telnetd_config_table   config;
+  int                          server_socket;
+  rtems_id                     task_id;
+  rtems_mutex                  mtx;
+  LIST_HEAD(, telnetd_session) free_sessions;
+  telnetd_session              sessions[RTEMS_ZERO_LENGTH_ARRAY];
-typedef union uni_sa {
+typedef union {
   struct sockaddr_in sin;
-  struct sockaddr     sa;
-} uni_sa;
+  struct sockaddr    sa;
+} telnetd_address;
-static telnetd_session *grab_a_Connection(telnetd_context *ctx)
+RTEMS_NO_RETURN static void telnetd_session_fatal_error(
+  const telnetd_context *ctx
-  telnetd_session *session;
-  uni_sa peer;
-  socklen_t address_len;
-  int acp_sock;
+  (void)rtems_event_send(ctx->task_id, TELNETD_EVENT_ERROR);
+  rtems_task_exit();
-  if (ctx->active_clients >= ctx->config.client_maximum) {
-    return NULL;
+static bool telnetd_login(telnetd_context *ctx, telnetd_session *session)
+  bool success;
+  if (ctx->config.login_check == NULL) {
+    return true;
-  session = malloc(sizeof(*session));
-  if (session == NULL) {
-    perror("telnetd:malloc");
-    return NULL;
+  success = rtems_shell_login_prompt(
+    stdin,
+    stderr,
+    session->pty.name,
+    ctx->config.login_check
+  if (!success) {
+    syslog(
+      LOG_AUTHPRIV | LOG_WARNING,
+      "telnetd: too many wrong passwords entered from %s",
+      session->peername
-  address_len = sizeof(peer.sin);
-  acp_sock = accept(ctx->server_socket, &peer.sa, &address_len);
-  if (acp_sock<0) {
-    perror("telnetd:accept");
-    free(session);
-    return NULL;
+  return success;
-  if (telnet_get_pty(&session->pty, acp_sock) == NULL) {
-    syslog( LOG_DAEMON | LOG_ERR, "telnetd: unable to obtain PTY");
-    /* NOTE: failing 'do_get_pty()' closed the socket */
-    free(session);
-    return NULL;
+static void telnetd_session_task(rtems_task_argument arg)
+  rtems_status_code sc;
+  telnetd_session *session;
+  const char *path;
+  session = (telnetd_session *) arg;
+  ctx = session->ctx;
+  sc = rtems_libio_set_private_env();
+  if (sc != RTEMS_SUCCESSFUL) {
+    telnetd_session_fatal_error(ctx);
-  if (
-    inet_ntop(
-      AF_INET,
-      &peer.sin.sin_addr,
-      session->peername,
-      sizeof(session->peername)
-    ) == NULL
-    strlcpy(session->peername, "<UNKNOWN>", sizeof(session->peername));
+  path = rtems_pty_get_path(&session->pty);
+  stdin = fopen(path, "r+");
+  if (stdin == NULL) {
-#ifdef PARANOIA
-  syslog(LOG_DAEMON | LOG_INFO,
-      "telnetd: accepted connection from %s on %s",
-      session->pty.name);
-#endif
+  stdout = fopen(path, "r+");
+  if (stdout == NULL) {
-  ++ctx->active_clients;
-  session->ctx = ctx;
-  return session;
+  stderr = fopen(path, "r+");
+  if (stderr == NULL) {
+  (void)rtems_event_send(ctx->task_id, TELNETD_EVENT_SUCCESS);
-static void release_a_Connection(
-  telnetd_context *ctx,
-  telnetd_session *session,
-  FILE **pstd,
-  int n
-#ifdef PARANOIA
-  syslog(
-    LOG_DAEMON | LOG_INFO,
-    "telnetd: releasing connection from %s on %s",
-    session->pty.name
-#endif
+  while (true) {
+    rtems_event_set events;
-  --ctx->active_clients;
+    (void)rtems_event_system_receive(
+      RTEMS_EVENT_SYSTEM_SERVER,
+      RTEMS_WAIT | RTEMS_EVENT_ALL,
+      RTEMS_NO_TIMEOUT,
+      &events
-  while (--n>=0)
-    if (pstd[n]) fclose(pstd[n]);
+    syslog(
+      LOG_DAEMON | LOG_INFO,
+      "telnetd: accepted connection from %s on %s",
+      session->peername,
+      path
-  unlink(session->pty.name);
+    if (telnetd_login(ctx, session)) {
+      (*ctx->config.command)(session->pty.name, ctx->config.arg);
-static rtems_id telnetd_spawn_task(
-  rtems_name name,
-  rtems_task_priority priority,
-  size_t stack_size,
-  rtems_task_entry entry,
-  void *arg
-  rtems_status_code sc;
-  rtems_id task_id;
+    syslog(
+      "telnetd: releasing connection from %s on %s",
+      path
-  sc = rtems_task_create(
-    name,
-    priority,
-    stack_size,
-    RTEMS_DEFAULT_MODES,
-    RTEMS_FLOATING_POINT,
-    &task_id
-  if (sc != RTEMS_SUCCESSFUL) {
-    return RTEMS_ID_NONE;
+    rtems_pty_close_socket(&session->pty);
-  (void)rtems_task_start(task_id, entry, (rtems_task_argument) arg);
-  return task_id;
+    rtems_mutex_lock(&ctx->mtx);
+    LIST_INSERT_HEAD(&ctx->free_sessions, session, link);
+    rtems_mutex_unlock(&ctx->mtx);
-static void
-telnetd_session_task(rtems_task_argument arg);
+static void telnetd_sleep_after_error(void)
+      /* If something went wrong, sleep for some time */
+      sleep(10);
-static void
-telnetd_server_task(rtems_task_argument arg)
+static void telnetd_server_task(rtems_task_argument arg)
-  telnetd_session   *session = NULL;
-  rtems_id           task_id;
-  telnetd_context   *ctx = (telnetd_context *) arg;
-  /* we don't redirect stdio as this probably
-   * was started from the console anyway ..
-  do {
-    session = grab_a_Connection(ctx);
+  ctx = (telnetd_context *) arg;
+  while (true) {
+    telnetd_address peer;
+    socklen_t address_len;
+    int session_socket;
+    address_len = sizeof(peer.sin);
+    session_socket = accept(ctx->server_socket, &peer.sa, &address_len);
+    if (session_socket < 0) {
+      syslog(LOG_DAEMON | LOG_ERR, "telnetd: cannot accept session");
+      telnetd_sleep_after_error();
+      continue;
+    session = LIST_FIRST(&ctx->free_sessions);
-      /* if something went wrong, sleep for some time */
-      sleep(10);
+      (void)close(session_socket);
+      syslog(LOG_DAEMON | LOG_ERR, "telnetd: no free session available");
       continue;
-    task_id = telnetd_spawn_task(
-      rtems_build_name('T', 'N', 'T', 'a'),
-      ctx->config.priority,
-      ctx->config.stack_size,
-      telnetd_session_task,
-      session
-    if (task_id == RTEMS_ID_NONE) {
-      FILE *dummy;
-      /* hmm - the pty driver slot can only be
-       * released by opening and subsequently
-       * closing the PTY - this also closes
-       * the underlying socket. So we mock up
-       * a stream...
-      if ( !(dummy=fopen(session->pty.name,"r+")) )
-        perror("Unable to dummy open the pty, losing a slot :-(");
-      release_a_Connection(ctx, session, &dummy, 1);
-      free(session);
-      sleep(2); /* don't accept connections too fast */
+    LIST_REMOVE(session, link);
+    rtems_pty_set_socket(&session->pty, session_socket);
+    if (
+      inet_ntop(
+        AF_INET,
+        &peer.sin.sin_addr,
+        sizeof(session->peername)
+      ) == NULL
+      strlcpy(session->peername, "<UNKNOWN>", sizeof(session->peername));
-  } while(1);
+    (void)rtems_event_system_send(session->task_id, RTEMS_EVENT_SYSTEM_SERVER);
 static void telnetd_destroy_context(telnetd_context *ctx)
+  LIST_FOREACH(session, &ctx->free_sessions, link) {
+    if (session->task_id != 0) {
+      (void)rtems_task_delete(session->task_id);
+    (void)unlink(rtems_pty_get_path(&session->pty));
   if (ctx->server_socket >= 0) {
-    close(ctx->server_socket);
+    (void)close(ctx->server_socket);
+  rtems_mutex_destroy(&ctx->mtx);
   free(ctx);
 static rtems_status_code telnetd_create_server_socket(telnetd_context *ctx)
-  uni_sa srv;
+  telnetd_address srv;
   int enable;
@@ -285,25 +311,94 @@ static rtems_status_code telnetd_create_server_socket(telnetd_context *ctx)
   return RTEMS_SUCCESSFUL;
+static rtems_status_code telnetd_create_session_tasks(telnetd_context *ctx)
+  uint16_t i;
+  ctx->task_id = rtems_task_self();
+  for (i = 0; i < ctx->config.client_maximum; ++i) {
+    const char *path;
+    session = &ctx->sessions[i];
+    session->ctx = ctx;
+    rtems_mutex_init(&ctx->mtx, "Telnet");
+    sc = rtems_task_create(
+      rtems_build_name('T', 'N', 'T', 'a' + i % 26),
+      ctx->config.priority,
+      ctx->config.stack_size,
+      RTEMS_DEFAULT_MODES,
+      RTEMS_FLOATING_POINT,
+      &session->task_id
+      syslog(LOG_DAEMON | LOG_ERR, "telnetd: cannot create session task");
+      return RTEMS_UNSATISFIED;
+    path = rtems_pty_initialize(&session->pty, i);
+    if (path == NULL) {
+      syslog(LOG_DAEMON | LOG_ERR, "telnetd: cannot create session PTY");
+    (void)rtems_task_start(
+      session->task_id,
+      telnetd_session_task,
+      (rtems_task_argument) session
+    (void)rtems_event_receive(
+      TELNETD_EVENT_SUCCESS | TELNETD_EVENT_ERROR,
+      RTEMS_WAIT | RTEMS_EVENT_ANY,
+      RTEMS_NO_TIMEOUT,
+      &events
+    if ((events & TELNETD_EVENT_ERROR) != 0) {
+      syslog(LOG_DAEMON | LOG_ERR, "telnetd: cannot initialize session task");
+  return RTEMS_SUCCESSFUL;
 rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
-  rtems_id task_id;
+  uint16_t client_maximum;
   if (config->command == NULL) {
     syslog(LOG_DAEMON | LOG_ERR, "telnetd: configuration with invalid command");
     return RTEMS_INVALID_ADDRESS;
-  ctx = calloc(1, sizeof(*ctx));
+  if (config->client_maximum == 0) {
+    client_maximum = 5;
+  } else {
+    client_maximum = config->client_maximum;
+  ctx = calloc(
+    1,
+    sizeof(*ctx) + client_maximum * sizeof(ctx->sessions[0])
   if (ctx == NULL) {
     syslog(LOG_DAEMON | LOG_ERR, "telnetd: cannot allocate server context");
   ctx->config = *config;
+  ctx->config.client_maximum = client_maximum;
   ctx->server_socket = -1;
+  LIST_INIT(&ctx->free_sessions);
   /* Check priority */
@@ -320,101 +415,38 @@ rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
     ctx->config.stack_size = (size_t)32 * 1024;
-  if (ctx->config.client_maximum == 0) {
-    ctx->config.client_maximum = 5;
+  sc = telnetd_create_server_socket(ctx);
+    telnetd_destroy_context(ctx);
+    return sc;
-  sc = telnetd_create_server_socket(ctx);
+  sc = telnetd_create_session_tasks(ctx);
     return sc;
     rtems_build_name('T', 'N', 'T', 'D'),
     RTEMS_MINIMUM_STACK_SIZE,
-    telnetd_server_task,
-    ctx
+    &ctx->task_id
-    ctx->config.command = NULL;
     syslog(LOG_DAEMON | LOG_ERR, "telnetd: cannot create server task");
+    ctx->task_id,
+    telnetd_server_task,
+    (rtems_task_argument) ctx
   syslog(LOG_DAEMON | LOG_INFO, "telnetd: started successfully");
-/* utility wrapper */
-static void
-  FILE                *nstd[3]={0};
-  FILE                *ostd[3]={ stdin, stdout, stderr };
-  int                  i=0;
-  telnetd_session    *session = (telnetd_session *) arg;
-  telnetd_context    *ctx = session->ctx;
-  bool login_failed = false;
-  bool start = true;
-  sc=rtems_libio_set_private_env();
-  /* newlib hack/workaround. Before we change stdin/out/err we must make
-         * sure the internal data are initialized (fileno(stdout) has this sideeffect).
-   * This should probably be done from RTEMS' libc support layer...
-   * (T.S., newlibc-1.13; 2005/10)
-  fileno(stdout);
-  if (RTEMS_SUCCESSFUL != sc) {
-    rtems_error(sc,"rtems_libio_set_private_env");
-    goto cleanup;
-  /* redirect stdio */
-  for (i=0; i<3; i++) {
-    if ( !(nstd[i]=fopen(session->pty.name,"r+")) ) {
-      perror("unable to open stdio");
-      goto cleanup;
-  stdin  = nstd[0];
-  stdout = nstd[1];
-  stderr = nstd[2];
-  /* call their routine */
-  if (ctx->config.login_check != NULL) {
-    start = rtems_shell_login_prompt(
-      stdin,
-      stderr,
-      session->pty.name,
-      ctx->config.login_check
-    login_failed = !start;
-  if (start) {
-    ctx->config.command( session->pty.name, ctx->config.arg);
-  stdin  = ostd[0];
-  stdout = ostd[1];
-  stderr = ostd[2];
-  if (login_failed) {
-    syslog(
-      LOG_AUTHPRIV | LOG_WARNING,
-      "telnetd: to many wrong passwords entered from %s",
-      session->peername
-cleanup:
-  release_a_Connection(ctx, session, nstd, i);
-  free(session);
diff --git a/testsuites/libtests/telnetd01/init.c b/testsuites/libtests/telnetd01/init.c
index f2243d9dd8..e7c2540840 100644
--- a/testsuites/libtests/telnetd01/init.c
+++ b/testsuites/libtests/telnetd01/init.c
@@ -105,9 +105,11 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS (3 + 1 + 5 * 4)
-#define CONFIGURE_MAXIMUM_TASKS 7
+#define CONFIGURE_MAXIMUM_TASKS 8
+#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/libtests/telnetd01/telnetd01.scn b/testsuites/libtests/telnetd01/telnetd01.scn
index 2dc2c60846..31439da5a0 100644
--- a/testsuites/libtests/telnetd01/telnetd01.scn
+++ b/testsuites/libtests/telnetd01/telnetd01.scn
@@ -4,9 +4,8 @@
 *** TEST BUILD: RTEMS_NETWORKING
 *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB 9670d7541e0621915e521fe76e7bb33de8cee661, Newlib d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
 syslog: telnetd: configuration with invalid command
-Telnetd: spawning task failed (status: RTEMS_INVALID_PRIORITY)
-syslog: telnetd: cannot create server task
+syslog: telnetd: cannot create session task
 syslog: telnetd: started successfully
-syslog: telnetd: already started
+syslog: telnetd: cannot bind server socket
 *** END OF TEST TELNETD 1 ***
2.16.4
