[PATCH] sb: Add support to search for a suitable vrsion of python.
chrisj at rtems.org chrisj at rtems.org
Thu Oct 11 06:38:41 UTC 2018
The command python has been removed from upstream python and python2
and python3 is now used. This patch wraps the commands in a shell
script that locates a suitable python to run.
Updates #3537
 source-builder/pkg-config             | 241 +++-----------------------
 source-builder/sb-bootstrap           |  24 ++-
 source-builder/sb-builder             |  24 ++-
 source-builder/sb-check               |  24 ++-
 source-builder/sb-defaults            |  24 ++-
 source-builder/sb-reports             |  24 ++-
 source-builder/sb-rtems-config        |  24 ++-
 source-builder/sb-set-builder         |  25 ++-
 source-builder/sb/cmd-bootstrap.py    |  29 ++++
 source-builder/sb/cmd-builder.py      |  29 ++++
 source-builder/sb/cmd-check.py        |  29 ++++
 source-builder/sb/cmd-defaults.py     |  29 ++++
 source-builder/sb/cmd-pkg-config.py   | 220 +++++++++++++++++++++++
 source-builder/sb/cmd-reports.py      |  29 ++++
 source-builder/sb/cmd-rtems-config.py |  29 ++++
 source-builder/sb/cmd-set-builder.py  |  29 ++++
 source-builder/sb/options.py          |   7 +-
 source-builder/sb/python-wrapper.sh   |  39 +++++
 18 files changed, 559 insertions(+), 320 deletions(-)
 create mode 100755 source-builder/sb/cmd-bootstrap.py
 create mode 100755 source-builder/sb/cmd-builder.py
 create mode 100755 source-builder/sb/cmd-check.py
 create mode 100755 source-builder/sb/cmd-defaults.py
 create mode 100755 source-builder/sb/cmd-pkg-config.py
 create mode 100755 source-builder/sb/cmd-reports.py
 create mode 100755 source-builder/sb/cmd-rtems-config.py
 create mode 100755 source-builder/sb/cmd-set-builder.py
 create mode 100644 source-builder/sb/python-wrapper.sh
diff --git a/source-builder/pkg-config b/source-builder/pkg-config
index fa251e5..65ee307 100755
--- a/source-builder/pkg-config
+++ b/source-builder/pkg-config
@@ -1,226 +1,27 @@
-#! /usr/bin/env python
+#! /bin/sh
 # RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2014-2016 Chris Johns (chrisj at rtems.org)
+# Copyright 2018 Chris Johns (chrisj at rtems.org)
 # All rights reserved.
 # This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-from __future__ import print_function
-import os
-import sys
-base = os.path.dirname(sys.argv[0])
-sys.path.insert(0, base + '/sb')
-try:
-    import argparse
-except:
-    sys.path.insert(0, base + '/sb/imports')
-    try:
-        import argparse
-    except:
-        print("Incorrect Source Builder installation", file = sys.stderr)
-        sys.exit(1)
-try:
-    import pkgconfig
-except ImportError:
-    sys.exit(1)
-# Make trace true to get a file of what happens and what is being asked.
-trace = True
-trace_stdout = False
-logfile = 'pkg-config.log'
-out = None
-srcfd = None
-# Write all the package source parsed to a single file.
-trace_src = True
-if trace_src:
-    srcfd = open('pkg-src.txt', 'w')
-def src(text):
-    if srcfd:
-        srcfd.writelines(text)
-def log(s, lf = True):
-    global trace, logfile, out
-    if trace:
-        if out is None:
-            if logfile:
-                out = open(logfile, 'a')
-            else:
-                out = sys.stdout
-        if lf:
-            if out != sys.stdout and trace_stdout:
-                print(s)
-            print(s, file = out)
-        else:
-                print(s, end = '')
-                sys.stdout.flush()
-            print(s, end = '', file = out)
-def run(argv):
-    class version_action(argparse.Action):
-        def __call__(self, parser, namespace, values, option_string = None):
-            parts = values[0].strip().split('.')
-            for p in parts:
-                if not p.isdigit():
-                    raise error('invalid version value: %s' % (values))
-            setattr(namespace, self.dest, '.'.join(parts))
-    ec = 0
-    opts = argparse.ArgumentParser(prog = 'pkg-config', description = 'Package Configuration.')
-    opts.add_argument('libraries', metavar='lib', type = str,  help = 'a library', nargs = '*')
-    opts.add_argument('--modversion', dest = 'modversion', action = 'store', default = None,
-                      help = 'Requests that the version information of the libraries.')
-    opts.add_argument('--print-errors', dest = 'print_errors', action = 'store_true',
-                      default = False,
-                      help = 'Print any errors.')
-    opts.add_argument('--short-errors', dest = 'short_errors', action = 'store_true',
-                      default = False,
-                      help = 'Make error messages short.')
-    opts.add_argument('--silence-errors', dest = 'silence_errors', action = 'store_true',
-                      default = False,
-                      help = 'Do not print any errors.')
-    opts.add_argument('--errors-to-stdout', dest = 'errors_to_stdout', action = 'store_true',
-                      default = False,
-                      help = 'Print errors to stdout rather than stderr.')
-    opts.add_argument('--cflags', dest = 'cflags', action = 'store_true',
-                      default = False,
-                      help = 'This prints pre-processor and compile flags required to' \
-                             ' compile the package(s)')
-    opts.add_argument('--libs', dest = 'libs', action = 'store_true',
-                      default = False,
-                      help = 'This option is identical to "--cflags", only it prints the' \
-                             ' link flags.')
-    opts.add_argument('--libs-only-L', dest = 'libs_only_L', action = 'store_true',
-                      default = False,
-                      help = 'This prints the -L/-R part of "--libs".')
-    opts.add_argument('--libs-only-l', dest = 'libs_only_l', action = 'store_true',
-                      default = False,
-                      help = 'This prints the -l part of "--libs".')
-    opts.add_argument('--variable', dest = 'variable', action = 'store',
-                      nargs = 1, default = None,
-                      help = 'This returns the value of a variable.')
-    opts.add_argument('--define-variable', dest = 'define_variable', action = 'store',
-                      help = 'This sets a global value for a variable')
-    opts.add_argument('--uninstalled', dest = 'uninstalled', action = 'store_true',
-                      default = False,
-                      help = 'Ignored')
-    opts.add_argument('--atleast-pkgconfig-version', dest = 'atleast_pkgconfig_version',
-                      action = 'store', nargs = 1, default = None,
-                      help = 'Check the version of package config. Always ok.')
-    opts.add_argument('--exists', dest = 'exists', action = 'store_true',
-                      default = False,
-                      help = 'Test if a library is present')
-    opts.add_argument('--atleast-version', dest = 'atleast_version',
-                      action = version_action, nargs = 1, default = None,
-                      help = 'The package is at least this version.')
-    opts.add_argument('--exact-version', dest = 'exact_version', action = version_action,
-                        help = 'The package is the exact version.')
-    opts.add_argument('--max-version', dest = 'max_version', action = version_action,
-                      help = 'The package is no later than this version.')
-    opts.add_argument('--msvc-syntax', dest = 'msvc_syntax', action = 'store_true',
-                      default = False,
-                      help = 'Ignored')
-    opts.add_argument('--dont-define-prefix', dest = 'dont_define_prefix', action = 'store_true',
-                      default = False,
-                      help = 'Ignored')
-    opts.add_argument('--prefix-variable', dest = 'prefix', action = 'store',
-                      nargs = 1, default = pkgconfig.default_prefix(),
-                      help = 'Define the prefix.')
-    opts.add_argument('--static', dest = 'static', action = 'store_true',
-                      default = False,
-                      help = 'Output libraries suitable for static linking')
-    opts.add_argument('--dump', dest = 'dump', action = 'store_true',
-                      default = False,
-                      help = 'Dump the package if one is found.')
-    args = opts.parse_args(argv[1:])
-    if (args.exists and (args.exact_version or args.max_version)) or \
-            (args.exact_version and (args.exists or args.max_version)) or \
-            (args.max_version and (args.exists or args.exact_version)):
-        raise error('only one of --exists, --exact-version, or --max-version')
-    if args.dont_define_prefix:
-        args.prefix = pkgconfig.default_prefix(False)
-    exists = False
-    ec = 1
-    if args.atleast_pkgconfig_version:
-        ec = 0
-    else:
-        ec, pkg, flags = pkgconfig.check_package(args.libraries, args, log, src)
-        if ec == 0:
-            if args.cflags:
-                if len(flags['cflags']):
-                    print(flags['cflags'])
-                    log('cflags: %s' % (flags['cflags']))
-                else:
-                    log('cflags: empty')
-            if args.libs:
-                if len(flags['libs']):
-                    print(flags['libs'])
-                    log('libs: %s' % (flags['libs']))
-                else:
-                    log('libs: empty')
-    #pkgconfig.package.dump_loaded()
-    return ec
-try:
-    log('-' * 40)
-    log('pkg-config', lf = False)
-    for a in sys.argv[1:]:
-        log(' "%s"' % (a), lf = False)
-    log('')
-    ec = run(sys.argv)
-    log('ec = %d' % (ec))
-    print("incorrect package config installation", file = sys.stderr)
-    sys.exit(1)
-except pkgconfig.error as e:
-    print('error: %s' % (e), file = sys.stderr)
-    sys.exit(1)
-sys.exit(ec)
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-pkg-config.py
+if test -f ${base}/sb/python-wrapper.sh; then
+  . ${base}/sb/python-wrapper.sh
+fi
+echo "error: python wrapper not found"
diff --git a/source-builder/sb-bootstrap b/source-builder/sb-bootstrap
index a1ee9a7..618e2bb 100755
--- a/source-builder/sb-bootstrap
+++ b/source-builder/sb-bootstrap
@@ -1,7 +1,7 @@
+#! /bin/sh
-# Copyright 2013 Chris Johns (chrisj at rtems.org)
@@ -17,15 +17,11 @@
-import sys, os
-try:
-    import bootstrap
-    bootstrap.run(sys.argv)
-    sys.exit(1)
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-bootstrap.py
+fi
diff --git a/source-builder/sb-builder b/source-builder/sb-builder
index 8721b56..be3d205 100755
--- a/source-builder/sb-builder
+++ b/source-builder/sb-builder
@@ -1,7 +1,7 @@
+#! /bin/sh
-# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
@@ -17,15 +17,11 @@
-import sys, os
-try:
-    import build
-    build.run(sys.argv)
-    sys.exit(1)
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-builder.py
+fi
diff --git a/source-builder/sb-check b/source-builder/sb-check
index d23b799..b092697 100755
--- a/source-builder/sb-check
+++ b/source-builder/sb-check
@@ -1,7 +1,7 @@
+#! /bin/sh
@@ -17,15 +17,11 @@
-import sys, os
-try:
-    import check
-    check.run()
-    sys.exit(1)
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-check.py
+fi
diff --git a/source-builder/sb-defaults b/source-builder/sb-defaults
index 790a5e5..25437ba 100755
--- a/source-builder/sb-defaults
+++ b/source-builder/sb-defaults
@@ -1,7 +1,7 @@
+#! /bin/sh
-# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
@@ -17,15 +17,11 @@
-import sys, os
-try:
-    import options
-    options.run(sys.argv)
-    sys.exit(1)
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-defaults.py
+fi
diff --git a/source-builder/sb-reports b/source-builder/sb-reports
index 3330be3..5fb02d1 100755
--- a/source-builder/sb-reports
+++ b/source-builder/sb-reports
@@ -1,7 +1,7 @@
+#! /bin/sh
@@ -17,15 +17,11 @@
-import sys, os
-try:
-    import reports
-    reports.run(sys.argv)
-    sys.exit(1)
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-reports.py
+fi
diff --git a/source-builder/sb-rtems-config b/source-builder/sb-rtems-config
index 1633b6b..66a95f7 100755
--- a/source-builder/sb-rtems-config
+++ b/source-builder/sb-rtems-config
@@ -1,7 +1,7 @@
+#! /bin/sh
@@ -17,15 +17,11 @@
-import sys, os
-try:
-    import rtemsconfig
-    rtemsconfig.run(sys.argv)
-    sys.exit(1)
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-rtems-config.py
+fi
diff --git a/source-builder/sb-set-builder b/source-builder/sb-set-builder
index 561199e..6a196fe 100755
--- a/source-builder/sb-set-builder
+++ b/source-builder/sb-set-builder
@@ -1,7 +1,7 @@
+#! /bin/sh
@@ -17,16 +17,11 @@
-import sys, os
-try:
-    import setbuilder
-    setbuilder.run()
-    sys.exit(1)
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-set-builder.py
+fi
diff --git a/source-builder/sb/cmd-bootstrap.py b/source-builder/sb/cmd-bootstrap.py
new file mode 100755
index 0000000..0243237
--- /dev/null
+++ b/source-builder/sb/cmd-bootstrap.py
@@ -0,0 +1,29 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2013 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+from __future__ import print_function
+import sys, os
+try:
+    import bootstrap
+    bootstrap.run(sys.argv)
+except ImportError:
+    print("Incorrect Source Builder installation", file = sys.stderr)
+    sys.exit(1)
diff --git a/source-builder/sb/cmd-builder.py b/source-builder/sb/cmd-builder.py
index 0000000..437b81a
--- /dev/null
+++ b/source-builder/sb/cmd-builder.py
@@ -0,0 +1,29 @@
+# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
+import sys, os
+try:
+    import build
+    build.run(sys.argv)
+    sys.exit(1)
diff --git a/source-builder/sb/cmd-check.py b/source-builder/sb/cmd-check.py
index 0000000..4525dbb
--- /dev/null
+++ b/source-builder/sb/cmd-check.py
@@ -0,0 +1,29 @@
+import sys, os
+try:
+    import check
+    check.run()
+    sys.exit(1)
diff --git a/source-builder/sb/cmd-defaults.py b/source-builder/sb/cmd-defaults.py
index 0000000..0b2b357
--- /dev/null
+++ b/source-builder/sb/cmd-defaults.py
@@ -0,0 +1,29 @@
+# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
+import sys, os
+try:
+    import options
+    options.run(sys.argv)
+    sys.exit(1)
diff --git a/source-builder/sb/cmd-pkg-config.py b/source-builder/sb/cmd-pkg-config.py
index 0000000..c2f485c
--- /dev/null
+++ b/source-builder/sb/cmd-pkg-config.py
@@ -0,0 +1,220 @@
+# Copyright 2014-2016 Chris Johns (chrisj at rtems.org)
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+import os
+import sys
+base = os.path.dirname(sys.argv[0])
+try:
+    import argparse
+except:
+    sys.path.insert(0, base + '/sb/imports')
+    try:
+        import argparse
+    except:
+        sys.exit(1)
+import pkgconfig
+# Make trace true to get a file of what happens and what is being asked.
+trace = True
+trace_stdout = False
+logfile = 'pkg-config.log'
+out = None
+srcfd = None
+# Write all the package source parsed to a single file.
+trace_src = True
+if trace_src:
+    srcfd = open('pkg-src.txt', 'w')
+def src(text):
+    if srcfd:
+        srcfd.writelines(text)
+def log(s, lf = True):
+    global trace, logfile, out
+    if trace:
+        if out is None:
+            if logfile:
+                out = open(logfile, 'a')
+            else:
+                out = sys.stdout
+        if lf:
+            if out != sys.stdout and trace_stdout:
+                print(s)
+            print(s, file = out)
+        else:
+                print(s, end = '')
+                sys.stdout.flush()
+            print(s, end = '', file = out)
+def run(argv):
+    class version_action(argparse.Action):
+        def __call__(self, parser, namespace, values, option_string = None):
+            parts = values[0].strip().split('.')
+            for p in parts:
+                if not p.isdigit():
+                    raise error('invalid version value: %s' % (values))
+            setattr(namespace, self.dest, '.'.join(parts))
+    ec = 0
+    opts = argparse.ArgumentParser(prog = 'pkg-config', description = 'Package Configuration.')
+    opts.add_argument('libraries', metavar='lib', type = str,  help = 'a library', nargs = '*')
+    opts.add_argument('--modversion', dest = 'modversion', action = 'store', default = None,
+                      help = 'Requests that the version information of the libraries.')
+    opts.add_argument('--print-errors', dest = 'print_errors', action = 'store_true',
+                      default = False,
+                      help = 'Print any errors.')
+    opts.add_argument('--short-errors', dest = 'short_errors', action = 'store_true',
+                      default = False,
+                      help = 'Make error messages short.')
+    opts.add_argument('--silence-errors', dest = 'silence_errors', action = 'store_true',
+                      default = False,
+                      help = 'Do not print any errors.')
+    opts.add_argument('--errors-to-stdout', dest = 'errors_to_stdout', action = 'store_true',
+                      default = False,
+                      help = 'Print errors to stdout rather than stderr.')
+    opts.add_argument('--cflags', dest = 'cflags', action = 'store_true',
+                      default = False,
+                      help = 'This prints pre-processor and compile flags required to' \
+                             ' compile the package(s)')
+    opts.add_argument('--libs', dest = 'libs', action = 'store_true',
+                      default = False,
+                      help = 'This option is identical to "--cflags", only it prints the' \
+                             ' link flags.')
+    opts.add_argument('--libs-only-L', dest = 'libs_only_L', action = 'store_true',
+                      default = False,
+                      help = 'This prints the -L/-R part of "--libs".')
+    opts.add_argument('--libs-only-l', dest = 'libs_only_l', action = 'store_true',
+                      default = False,
+                      help = 'This prints the -l part of "--libs".')
+    opts.add_argument('--variable', dest = 'variable', action = 'store',
+                      nargs = 1, default = None,
+                      help = 'This returns the value of a variable.')
+    opts.add_argument('--define-variable', dest = 'define_variable', action = 'store',
+                      help = 'This sets a global value for a variable')
+    opts.add_argument('--uninstalled', dest = 'uninstalled', action = 'store_true',
+                      default = False,
+                      help = 'Ignored')
+    opts.add_argument('--atleast-pkgconfig-version', dest = 'atleast_pkgconfig_version',
+                      action = 'store', nargs = 1, default = None,
+                      help = 'Check the version of package config. Always ok.')
+    opts.add_argument('--exists', dest = 'exists', action = 'store_true',
+                      default = False,
+                      help = 'Test if a library is present')
+    opts.add_argument('--atleast-version', dest = 'atleast_version',
+                      action = version_action, nargs = 1, default = None,
+                      help = 'The package is at least this version.')
+    opts.add_argument('--exact-version', dest = 'exact_version', action = version_action,
+                        help = 'The package is the exact version.')
+    opts.add_argument('--max-version', dest = 'max_version', action = version_action,
+                      help = 'The package is no later than this version.')
+    opts.add_argument('--msvc-syntax', dest = 'msvc_syntax', action = 'store_true',
+                      default = False,
+                      help = 'Ignored')
+    opts.add_argument('--dont-define-prefix', dest = 'dont_define_prefix', action = 'store_true',
+                      default = False,
+                      help = 'Ignored')
+    opts.add_argument('--prefix-variable', dest = 'prefix', action = 'store',
+                      nargs = 1, default = pkgconfig.default_prefix(),
+                      help = 'Define the prefix.')
+    opts.add_argument('--static', dest = 'static', action = 'store_true',
+                      default = False,
+                      help = 'Output libraries suitable for static linking')
+    opts.add_argument('--dump', dest = 'dump', action = 'store_true',
+                      default = False,
+                      help = 'Dump the package if one is found.')
+    args = opts.parse_args(argv[1:])
+    if (args.exists and (args.exact_version or args.max_version)) or \
+            (args.exact_version and (args.exists or args.max_version)) or \
+            (args.max_version and (args.exists or args.exact_version)):
+        raise error('only one of --exists, --exact-version, or --max-version')
+    if args.dont_define_prefix:
+        args.prefix = pkgconfig.default_prefix(False)
+    exists = False
+    ec = 1
+    if args.atleast_pkgconfig_version:
+        ec = 0
+    else:
+        ec, pkg, flags = pkgconfig.check_package(args.libraries, args, log, src)
+        if ec == 0:
+            if args.cflags:
+                if len(flags['cflags']):
+                    print(flags['cflags'])
+                    log('cflags: %s' % (flags['cflags']))
+                else:
+                    log('cflags: empty')
+            if args.libs:
+                if len(flags['libs']):
+                    print(flags['libs'])
+                    log('libs: %s' % (flags['libs']))
+                else:
+                    log('libs: empty')
+    #pkgconfig.package.dump_loaded()
+    return ec
+try:
+    log('-' * 40)
+    log('pkg-config', lf = False)
+    for a in sys.argv[1:]:
+        log(' "%s"' % (a), lf = False)
+    log('')
+    ec = run(sys.argv)
+    log('ec = %d' % (ec))
+    print("incorrect package config installation", file = sys.stderr)
+    sys.exit(1)
+except pkgconfig.error as e:
+    print('error: %s' % (e), file = sys.stderr)
+    sys.exit(1)
+sys.exit(ec)
diff --git a/source-builder/sb/cmd-reports.py b/source-builder/sb/cmd-reports.py
index 0000000..4c41e33
--- /dev/null
+++ b/source-builder/sb/cmd-reports.py
@@ -0,0 +1,29 @@
+import sys, os
+try:
+    import reports
+    reports.run(sys.argv)
+    sys.exit(1)
diff --git a/source-builder/sb/cmd-rtems-config.py b/source-builder/sb/cmd-rtems-config.py
index 0000000..f29ef04
--- /dev/null
+++ b/source-builder/sb/cmd-rtems-config.py
@@ -0,0 +1,29 @@
+import sys, os
+try:
+    import rtemsconfig
+    rtemsconfig.run(sys.argv)
+    sys.exit(1)
diff --git a/source-builder/sb/cmd-set-builder.py b/source-builder/sb/cmd-set-builder.py
index 0000000..56114cd
--- /dev/null
+++ b/source-builder/sb/cmd-set-builder.py
@@ -0,0 +1,29 @@
+import sys, os
+try:
+    import setbuilder
+    setbuilder.run()
+    sys.exit(1)
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
index 5767c48..afba28f 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -601,10 +601,15 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
     global host_windows
     global host_posix
+    # Adjust the args to remove the wrapper.
+    args = args[1:]
     # The path to this command.
-    command_path = path.dirname(args[0])
+    command_path = path.dirname(path.abspath(args[0]))
     if len(command_path) == 0:
         command_path = '.'
diff --git a/source-builder/sb/python-wrapper.sh b/source-builder/sb/python-wrapper.sh
new file mode 100644
index 0000000..82afc7d
--- /dev/null
+++ b/source-builder/sb/python-wrapper.sh
@@ -0,0 +1,39 @@
+set -e
+if test ! -f $PYTHON_CMD; then
+  echo "error: python command not found: $PYTHON_CMD"
+  exit 5
+fi
+for py in python2 python3 python
+do
+  set +e
+  py_cmd=$(command -v $py)
+  set -e
+  if test -n "$RTEMS_PYTHON_OVERRIDE"; then
+    if test "$RTEMS_PYTHON_OVERRIDE" != "$pycmd"; then
+      py_cmd=""
+    fi
+  fi
+  if test -n "$py_cmd"; then
+    exec $py_cmd $PYTHON_CMD $0 $*
+  fi
+done
+echo "error: no valid python found"
+exit 5
2.17.1 (Apple Git-112)
