Link RAP file error on zynq BSP
jameszxj
jameszxj at gmail.com
Mon Oct 15 06:16:00 UTC 2018
>On 12/10/18 10:05 am, Joel Sherrill wrote:
>>> On Thu, Oct 11, 2018 at 11:45 PM jameszxj <jameszxj at gmail.com
>>> <mailto:jameszxj at gmail.com>> wrote:
>>> HI,
>>> I run RTEMS on my xilinx z7k board and dynamic load application(RAP
>>> format) from shell.
>>> In recent update, i encount a link error when link the RAP file.
>>> Here is the command and output message:
>>> rtems-ld -n -e PT_Init --base rtems-nsa.elf
>>> wsp/build/nssys.elf -o wsp/build/nssys.out
>>> error: rap::object: Section index '65522' not found:
>>> wsp/build/nssys.elf
>>> At last I found the bsp_spec file has been modified, "*link:%{!qrtems:
>>> %(old_link)} %{qrtems: -dc -dp -N}" was removed
>>> from the bsp_spec file. Add this line to the file, ld is OK.
>>> Why removed these lines?
>>> The long-term goal is to remove the bsp_specs. I made a sweep making them more
>>> consistent and have a set of patches against gcc master which eliminates them on
>>> many architectures. Working so the details are implied by GCC.
>>> So let's look at the options and see which one has an impact which mattered that
>>> I didn't catch. This is the description of these options from ld's man page:
>>> -N
>>> --omagic
>>> Set the text and data sections to be readable and writable. Also,
>>> do not page-align the data segment, and disable linking against
>>> shared libraries. If the output format supports Unix style magic
>>> numbers, mark the output as "OMAGIC". Note: Although a writable
>>> text section is allowed for PE-COFF targets, it does not conform to
>>> the format specification published by Microsoft.
>>> -d
>>> -dc
>>> -dp These three options are equivalent; multiple forms are supported
>>> for compatibility with other linkers. They assign space to common
>>> symbols even if a relocatable output file is specified (with -r).
>>> The script command "FORCE_COMMON_ALLOCATION" has the same effect.
>>> I'm going to guess that it is -dc/-dp but have no idea how this would impact RAP
>>> except to confuse the code.
>>> Can you try adding adding the options one at a time until you make it work? Then
>>> Chris can figure out why it breaks RAP.>>
>I have tried this,just add -dc/-dp do not make it work.>
>>I suspect there is a section that is present which is needed that is not being
>>handled in the RAP toolkit code. That RAP format merges some sections in rtems-ld.>>
>Probably like this, and I just test it use just one simple source file, uninitialized variable
^^^^^^^^^^^^^^^^^^^^^^^^uninitialized global variable
>cause this error. If I initialize the variable, link is fine.>
>>James, if you can make a test file that generates the error then create a ticket
>>and attach the code I can take a look.>>
>>> Does the newest RTEMS support the loading of incrementally linked ELF
>>> files? RAP format runs OK, but the link needs BSP image, this
>>> make BSP's development and APP's development not so independent. a little
>>> pity, :)
>>> This is a Chris question.
>>James, if you do not provide a base image, ie no --base option, what happens?>>
>I am trying to figure out the problem, it maybe has sth. to do with the --nostdlib option,
>I need to do more tests. I shall describe the problem more clear later on.>
I compile APP with --nostdlib option, link process need to resolve the symbols through base iamge, so BSP image is needed.
And if I remove --nostdlib and add -lc -lm ... , I got a error message:
d:/msys64/opt/rtems/5.1/bin/../lib/gcc/arm-rtems5/7.3.0/../../../../arm-rtems5/bin/ld.exe: wsp/build/nssys.elf section `.unexpected_sections' will not fit in region `UNEXPECTED_SECTIONS'
collect2.exe: error: ld returned 1 exit status
>>Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181015/f65abf83/attachment.html>
