[PATCH 1/6] Move default config to librtemsdefaultconfig.a
Mon Oct 15 13:16:57 UTC 2018
On 15/10/2018 14:52, Joel Sherrill wrote:
> Does doing this mean that autoconf probes now need to pass an extra
> library to link against?
Yes.
> The detault config primarily exists to allow autoconf probes to work.
> If it adds the need to specify an additional library argument, then it
> impacts the configuration, rsb recipes, and build instructions for
> every add-on package. It also could result in the default
> configuration library being included in what the add-on recommends via
> something like pkgconfig.
The Autoconf needs already some information about RTEMS, e.g. at least
the "-specs bsp_specs -qrtems".
> Have you built external add-ons with this change?
No, is this examples-v2?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
