[PATCH] Covoar : remove lib parsing as the support is shifted to coverage script
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Oct 16 03:37:35 UTC 2018
tester/covoar/DesiredSymbols.cc | 16 +++++++---------
1 file changed, 7 insertions(+), 9 deletions(-)
diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
index 60d22c3..94ab562 100644
--- a/tester/covoar/DesiredSymbols.cc
+++ b/tester/covoar/DesiredSymbols.cc
@@ -55,10 +55,10 @@ namespace Coverage {
// For each set read the libraries from the configuration file and load.
// [A]
- // libraries = @BUILD-PREFIX@/c/@BSP@/A/libA.a
+ // libraries = @BUILD-PREFIX@/c/@BSP@/A
// [B]
- // libraries = @BUILD-PREFIX@/c/@BSP@/B/libB.a
+ // libraries = @BUILD-PREFIX@/c/@BSP@/B
try {
cache.open();
@@ -79,14 +79,12 @@ namespace Coverage {
if (verbose)
std::cerr << " Symbol set: " << set << std::endl;
const rld::config::section& set_section = config.get_section(set);
- rld::strings libs;
- rld::config::parse_items (set_section, "libraries", libs, true);
- for (std::string lib : libs) {
- lib = rld::find_replace(lib, "@BUILD-TARGET@", buildTarget);
- lib = rld::find_replace(lib, "@BSP@", buildBSP);
+ rld::strings objs;
+ rld::config::parse_items (set_section, "libraries", objs, true);
+ for (std::string obj : objs) {
if (verbose)
- std::cerr << " Loading library: " << lib << std::endl;
- cache.add(lib);
+ std::cerr << " Loading Object: " << obj << std::endl;
+ cache.add(obj);
2.17.2
