libBSD and CPU Load display questions in SMP mode
jameszxj
jameszxj at gmail.com
Tue Oct 16 08:28:38 UTC 2018
Hi,
ask questions again,(◡‿◡)
Board infomation:
CPU:zynq z7020 RTEMS version: master version
SMP define:
#define CONFIGURE_MAXIMUM_PROCESSORS 2
#if 1
#define CONFIGURE_MAXIMUM_PRIORITY 255
#define CONFIGURE_SCHEDULER_PRIORITY_SMP
#include <rtems/scheduler.h>
RTEMS_SCHEDULER_PRIORITY_SMP(a, CONFIGURE_MAXIMUM_PRIORITY + 1);
RTEMS_SCHEDULER_PRIORITY_SMP(b, CONFIGURE_MAXIMUM_PRIORITY + 1);
#define SCHED_A rtems_build_name(' ', ' ', ' ', 'A')
#define SCHED_B rtems_build_name(' ', ' ', ' ', 'B')
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
RTEMS_SCHEDULER_TABLE_PRIORITY_SMP(a, SCHED_A), \
RTEMS_SCHEDULER_TABLE_PRIORITY_SMP(b, SCHED_B)
#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL)
#endif
I am switching from AMP mode to SMP mode, and found 2 problems.
1. top command display message, Load is 100%, and Idle is almost 100% too.
Is it right? In fact,CPU is doing nothing.
Tasks: 25 Load Average: 100.510% Load: 100.966% Idle: 99.033%
Mem: 457M free 50M used 516K stack
ID | NAME | RPRI | CPRI | TIME | TOTAL | CURRENT
0x09010002 | IDLE | 510 | 510 | 4m9.328460 | 50.073 | 100.000
0x09010001 | IDLE | 510 | 510 | 4m7.319959 | 49.670 | 99.033
0x0a010002 | WDOG | 6 | 6 | 0.003674 | 0.000 | 0.001
2.when I connect to RTEMS with ftp or telnet, system reset.
If just only define CONFIGURE_MAXIMUM_PROCESSORS,ftp and telnet is ok.
*** FATAL ***
fatal source: 10 (RTEMS_FATAL_SOURCE_SMP)
fatal code: 7 (0x00000007)
RTEMS version: 5.0.0
RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB d2d46786f113ed39d29deafa3feeb4d42ae94001, Newlib d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
executing thread ID: 0x08a010006
executing thread name: IRQS
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181016/65d29d04/attachment.html>
