[PATCH 1/6] Move default config to librtemsdefaultconfig.a
Tue Oct 16 13:07:09 UTC 2018
On 15/10/2018 14:52, Joel Sherrill wrote:
> Does doing this mean that autoconf probes now need to pass an extra
> library to link against?
I think Autoconf is not an issue. By default, the feature probes will
use the dummy crt0.o provided by Newlib.
> The detault config primarily exists to allow autoconf probes to work.
> If it adds the need to specify an additional library argument, then it
> impacts the configuration, rsb recipes, and build instructions for
> every add-on package. It also could result in the default
> configuration library being included in what the add-on recommends via
> something like pkgconfig.
The default configuration library should not be added by default via
pkgconfig or anything automatically. The goal is that a user has to
explicitly add this library if he wishes to use a default configuration.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
