libBSD and CPU Load display questions in SMP mode
Wed Oct 17 05:09:53 UTC 2018
On 17/10/2018 04:17, jameszxj wrote:
> thanks,
> 1.I read the c-use doc, but still confused about EDF SCHEDULER.
> The doc said "All SMP schedulers included in RTEMS are priority based. "
> Is that mean High priority task always piror low priority task just
> like Priority SMP Scheduler.
> But some doc from internet said EDF scheduler has a dynamic priority.
Is this the documentation you found?
https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#earliest-deadline-first-smp-scheduler
> My system wants High priority task always piror low priority task, low
> priority task can be delay or interrupt.
> Does it means that we can not use EDF scheduler?
You can use the EDF scheduler. It is the default scheduler if more that
one processor is configured.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
