libBSD and CPU Load display questions in SMP mode
Wed Oct 17 07:28:12 UTC 2018
On 17/10/2018 09:20, Chris Johns wrote:
> On 17/10/18 5:17 pm, Sebastian Huber wrote:
>> On 17/10/2018 07:59, Chris Johns wrote:
>>> On 17/10/18 4:05 pm, Sebastian Huber wrote:
>>>> On 17/10/2018 02:46, Chris Johns wrote:
>>>>> On 16/10/2018 19:34, Sebastian Huber wrote:
>>>>>> On 16/10/2018 10:28, jameszxj wrote:
>>>>>>> CPU:zynq z7020  RTEMS version: master version
>>>>>>> SMP define:
>>>>>>> #define CONFIGURE_MAXIMUM_PROCESSORS        2
>>>>>>> #if 1
>>>>>>> #define CONFIGURE_MAXIMUM_PRIORITY 255
>>>>>>> #define CONFIGURE_SCHEDULER_PRIORITY_SMP
>>>>>> The only SMP scheduler supported by libbsd is:
>>>>>> #define CONFIGURE_SCHEDULER_EDF_SMP
>>>>> Why does the restriction exist?
>>>> This SMP scheduler implementation is the only one in RTEMS that supports thread
>>>> pinning. It is the default scheduler.
>>> The documentation says:
>>>    In case no explicit clustered scheduler configuration is present, then it
>>>    is used as the scheduler for exactly one processor.
>> You mean
>> https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#configure-scheduler-edf
> Yes.
>>> I do not know what this means.
>> I think the wording is clear. It describes the CONFIGURE_SCHEDULER_EDF
>> configuration option.
> I read it as ... "if I do not provide a clustered scheduler config then EDF is
> used for just a single processor so if I have more than one processor something
> else is used on that but what is the something else" .. but I am not sure.
No, you are here in the description of the CONFIGURE_SCHEDULER_EDF
configuration option. It describes what happens if you do a
>>> I see the default is mentioned just after this. I
>>> wonder if a section about the defaults in either 24.21 and/or 24.22?
>> The section 24.21 is about the general scheduler configuration. This
>> configuration is optional. Maybe we should clarify this in the section entry.
> Yes, I think this needs to be front and center somewhere. It makes sense once
> you understand however we should help new users coming on board with RTEMS.
>> The section 24.22 is about the clustered scheduler configuration. This
>> configuration is also optional.
> Yes and it has the default scheduler comment.
>>> The clustered scheduling section has:
>>>    A clustered scheduler configuration is optional. By default, up to 32
>>>    processors are managed by the EDF SMP Scheduler.
>>> It is not clear if the default is 32 processors, the scheduler or both.
>> By default means if you didn't configure anything.
> What about ...
>   A clustered scheduler configuration is optional. If configured the default
>   scheduler, up to 32 processors, is the EDF SMP Scheduler.
I think the "If configured" is very confusing. The EDF SMP scheduler is
used if you don't configure anything except
CONFIGURE_MAXIMUM_PROCESSORS. This is what most users should do.
I will try to create a documentation patch.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
