[PATCH 1/6] Move default config to librtemsdefaultconfig.a
Wed Oct 17 22:49:28 UTC 2018
On 17/10/2018 21:25, Sebastian Huber wrote:
> The stuff in rtems_waf makes some problems. It uses the RTEMS libraries for the
> probes which contain simply a main() function and no RTEMS configuration. There
> are two options to address this issue.
Should rtems_waf be adjusted to not do this?
