machine/param.h Leak of non-standard methods to Application Space
Thu Oct 18 05:08:40 UTC 2018
On 17/10/2018 17:04, Joel Sherrill wrote:
> Hi
> We are updating the port of a large third party framework and ran
> into an issue where what I would think are BSD kernel methods
> leak into application space. All but one of the methods is used
> by rtems-libbsd code.
> I think the following in <machine/param.h> needs to be protected by
> an _KERNEL ifdef.
> Does that sound OK?
>  * Mach derived conversion macros
> #define round_page(x)           (((unsigned long)(x) + PAGE_MASK) &
> ~PAGE_MASK)
> #define trunc_page(x)           ((unsigned long)(x) & ~PAGE_MASK)
> #define atop(x)                 ((unsigned long)(x) >> PAGE_SHIFT)
> #define ptoa(x)                 ((unsigned long)(x) << PAGE_SHIFT)
> #define pgtok(x)                ((unsigned long)(x) * (PAGE_SIZE / 1024))
In FreeBSD they are always present:
https://github.com/freebsd/freebsd/blob/master/sys/riscv/include/param.h#L97
The <sys/param.h> is not a POSIX header file. Unfortunately it is
included in <sys/_cpuset.h> and thus in <rtems.h>. I think we should fix.
Are these macros only used in kernel-space files in libbsd?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
