[PATCH 1/6] Move default config to librtemsdefaultconfig.a
Thu Oct 18 07:40:02 UTC 2018
On 18/10/2018 00:49, Chris Johns wrote:
> On 17/10/2018 21:25, Sebastian Huber wrote:
>> The stuff in rtems_waf makes some problems. It uses the RTEMS libraries for the
>> probes which contain simply a main() function and no RTEMS configuration. There
>> are two options to address this issue.
> Should rtems_waf be adjusted to not do this?
I think it is good that rtems_waf tries to link against the BSP
libraries and not just the dummy crt0.o provided by Newlib. I adjusted
it to avoid the default configuration:
https://lists.rtems.org/pipermail/devel/2018-October/023355.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
