[PATCH 1/2] Support O_CLOEXEC open() flag
Thu Oct 18 10:42:58 UTC 2018
Make sure this flag is ignored and does not prevent a successful open.
Close #3547.
 testsuites/psxtests/psxfile01/test.c | 32 ++++++++++++++++++++++++++++----
 1 file changed, 28 insertions(+), 4 deletions(-)
diff --git a/testsuites/psxtests/psxfile01/test.c b/testsuites/psxtests/psxfile01/test.c
index dbdce86be8..129412d3ef 100644
--- a/testsuites/psxtests/psxfile01/test.c
+++ b/testsuites/psxtests/psxfile01/test.c
@@ -57,6 +57,8 @@ char test_write_buffer[ 1024 ];
 rtems_filesystem_operations_table  IMFS_ops_no_evalformake;
 rtems_filesystem_operations_table  IMFS_ops_no_rename;
+static const char somefile[] = "somefile";
  *  File test support routines.
@@ -132,11 +134,10 @@ void stat_a_file(
 static void test_open_directory(void)
-  static const char file[] = "somefile";
   int status;
   int fd;
-  fd = open( file, O_CREAT, S_IRWXU );
+  fd = open( somefile, O_CREAT, S_IRWXU );
   rtems_test_assert( fd >= 0 );
   status = close( fd );
@@ -144,12 +145,34 @@ static void test_open_directory(void)
 #ifdef O_DIRECTORY
   errno = 0;
-  fd = open( file, O_DIRECTORY, S_IRWXU );
+  fd = open( somefile, O_DIRECTORY, S_IRWXU );
   rtems_test_assert( fd == -1 );
   rtems_test_assert( errno == ENOTDIR );
 #endif
-  status = unlink( file );
+  status = unlink( somefile );
+  rtems_test_assert( status == 0 );
+static void test_open_cloexec(void)
+  int status;
+  int fd;
+  mode_t mode;
+  mode = O_CREAT;
+#ifdef O_CLOEXEC
+  mode |= O_CLOEXEC;
+#endif
+  fd = open( somefile, mode, S_IRWXU );
+  rtems_test_assert( fd >= 0 );
+  status = close( fd );
@@ -185,6 +208,7 @@ int main(
   TEST_BEGIN();
   test_open_directory();
+  test_open_cloexec();
    *  Grab the maximum size of an in-memory file.
2.16.4
