[PATCH] Avoid default RTEMS application configuration
Thu Oct 18 17:56:32 UTC 2018
On 18/10/18 6:38 pm, Sebastian Huber wrote:
> Use a test body with a proper RTEMS application configuration to avoid a
> dependency on the default configuration.  Do not include
> <rtems/score/cpuopts.h> directly since this header file is an
> implementation detail.
> Update #3551.
>  rtems.py | 30 +++++++++++++++++-------------
>  1 file changed, 17 insertions(+), 13 deletions(-)
> diff --git a/rtems.py b/rtems.py
> index 1b0da60..c7a1966 100644
> --- a/rtems.py
> +++ b/rtems.py
> @@ -259,13 +259,18 @@ def configure(conf, bsp_configure = None):
>          # Checks for various RTEMS features.
> -        conf.multicheck({ 'header_name': 'rtems/score/cpuopts.h'},
> -                        msg = 'Checking for RTEMS CPU options header',
> -                        mandatory = True)
> -        load_cpuopts(conf, ab, rtems_path)
OK.
> -        conf.multicheck({ 'header_name': 'rtems.h'},
> -                        msg = 'Checking for RTEMS header',
> -                        mandatory = True)
Why remove the test? I see the app test below checks for the header however the
test creates a nice specific error message.
> +        main = 'void Init(rtems_task_argument arg) { (void)arg; }%s' % (os.linesep)
> +        main += '#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER 1%s' % (os.linesep)
> +        main += '#define CONFIGURE_MAXIMUM_TASKS 1%s' % (os.linesep)
> +        main += '#define CONFIGURE_RTEMS_INIT_TASKS_TABLE%s' % (os.linesep)
> +        main += '#define CONFIGURE_INIT%s' % (os.linesep)
> +        main += '#include <rtems/confdefs.h>%s' % (os.linesep)
> +        code = '#include <rtems.h>%s' % (os.linesep)
> +        code += main
I wonder if this fragment should be placed in a function called
'test_application' so it is called rather than passing 'main' about?
ie ..
  def test_applicaiton(code = []):
       main =  ['void Init(rtems_task_argument arg) { (void)arg; }']
       main += ['#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER 1']
       main += ['#define CONFIGURE_MAXIMUM_TASKS 1']
       main += ['#define CONFIGURE_RTEMS_INIT_TASKS_TABLE]'
       main += ['#define CONFIGURE_INIT']
       main += ['#include <rtems/confdefs.h>']
       return os.linesep.join(code + main)
 [ Why not include confdefs.h in the `main` code? ]
then this ...
> +        conf.check_cc(fragment = code,
> +                      execute = False,
> +                      msg = 'Building a trivial RTEMS application')
becomes ...
  code = ['#include <rtems/confdefs.h>']
  conf.check_cc(fragment = test_application(code),
                execute = False,
or ...
  conf.check_cc(fragment = test_application(),
                execute = False,
if confdefs.h is part of 'main'.
The opts check becomes even simpler.
> +        load_cpuopts(conf, main)
>          # Add tweaks.
> @@ -294,7 +299,7 @@ def build(bld):
>      if bld.env.LONG_COMMANDS == 'yes':
>          long_command_line()
> -def load_cpuopts(conf, arch_bsp, rtems_path):
> +def load_cpuopts(conf, main):
>      options = ['RTEMS_DEBUG',
>                 'RTEMS_MULTIPROCESSING',
>                 'RTEMS_NEWLIB',
> @@ -302,14 +307,14 @@ def load_cpuopts(conf, arch_bsp, rtems_path):
>                 'RTEMS_SMP',
>                 'RTEMS_NETWORKING']
>      for opt in options:
> -        enabled = check_opt(conf, opt, 'rtems/score/cpuopts.h', arch_bsp, rtems_path)
> +        enabled = check_cpuopt(conf, opt, main)
>          if enabled:
>              conf.env[opt] = 'Yes'
>          else:
>              conf.env[opt] = 'No'
> -def check_opt(conf, opt, header, arch_bsp, rtems_path):
> -    code  = '#include <%s>%s' % (header, os.linesep)
> +def check_cpuopt(conf, opt, main):
>      code += '#ifndef %s%s' % (opt, os.linesep)
>      code += ' #error %s is not defined%s' % (opt, os.linesep)
>      code += '#endif%s' % (os.linesep)
> @@ -318,11 +323,10 @@ def check_opt(conf, opt, header, arch_bsp, rtems_path):
>      code += '#else%s' % (os.linesep)
>      code += ' #error %s is false%s' % (opt, os.linesep)
> -    code += 'int main() { return 0; }%s' % (os.linesep)
> +    code += main
>      try:
>                        execute = False,
> -                      define_ret = False,
>                        msg = 'Checking for %s' % (opt))
>      except conf.errors.WafError:
>          return False;
Thanks
