[PATCH] POSIX inttypes Testsuite
Aditya Upadhyay aadit0402 at gmail.com
Sat Oct 20 16:25:39 UTC 2018
On Sat, Oct 20, 2018 at 12:43 AM Joel Sherrill <joel at rtems.org> wrote:
> A few administrative changes.
> There needs to be a proper commit log message.
> init.c does not have a copyright/license notices.
Should It be same as what we are seeing in other testsuite .c files? I
am not familiar
with Copyright and license related things.
> There is no .doc file giving a description of the test purposes/cases.
Thanks for pointing it. Added it now.
> On Wed, Sep 26, 2018 at 11:32 AM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
>>  testsuites/psxtests/Makefile.am                    |  10 ++
>>  testsuites/psxtests/configure.ac                   |   1 +
>>  testsuites/psxtests/psxinttypes01/init.c           | 122 +++++++++++++++++++++
>>  .../psxtests/psxinttypes01/psxinttypes01.scn       |  28 +++++
>>  4 files changed, 161 insertions(+)
>>  create mode 100644 testsuites/psxtests/psxinttypes01/init.c
>>  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
>> index 2a18d54..c7b4899 100644
>> --- a/testsuites/psxtests/Makefile.am
>> +++ b/testsuites/psxtests/Makefile.am
>> @@ -15,6 +15,16 @@ psx_lib =
>>  support_includes = -I$(top_srcdir)/../support/include
>>  if HAS_POSIX
>> +if TEST_psxinttypes01
>> +psx_tests += psxinttypes01
>> +psx_screens += psxinttypes01/psxinttypes01.scn
>> +psxinttypes01_SOURCES = psxinttypes01/init.c
>> +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
>> +       $(support_includes) -I$(top_srcdir)/include
>> +endif
>> +endif
>> +if HAS_POSIX
>>  if TEST_psx01
>>  psx_tests += psx01
>>  psx01_SOURCES = psx01/init.c psx01/task.c psx01/system.h \
>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
>> index cdd6ee7..85559e4 100644
>> --- a/testsuites/psxtests/configure.ac
>> +++ b/testsuites/psxtests/configure.ac
>> @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxid01])
>>  RTEMS_TEST_CHECK([psximfs01])
>>  RTEMS_TEST_CHECK([psximfs02])
>>  RTEMS_TEST_CHECK([psxintrcritical01])
>> +RTEMS_TEST_CHECK([psxinttypes01])
>>  RTEMS_TEST_CHECK([psxitimer])
>>  RTEMS_TEST_CHECK([psxkey01])
>>  RTEMS_TEST_CHECK([psxkey02])
>> diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
>> new file mode 100644
>> index 0000000..7f5942a
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxinttypes01/init.c
>> @@ -0,0 +1,122 @@
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <rtems/test.h>
>> +#include <inttypes.h>
>> +#include <stdio.h>
>> +#include <errno.h>
>> +#include <tmacros.h>
>> +#include <stdint.h>
>> +#include <stddef.h>
>> +const char rtems_test_name[] = "PSXINTTYPE 01";
>> +/* forward declarations to avoid warnings */
>> +rtems_task Init(rtems_task_argument ignored);
>> +  int       base     = 10;
>> +  char     *nptr1    = "123abc";
>> +  char     *endptr1  = NULL;
>> +  wchar_t  *nptr2    = L"-123junk";
>> +  wchar_t  *endptr2  = NULL;
>> +  intmax_t  status1;
>> +  uintmax_t status2;
>> +  TEST_BEGIN();
>> +  puts( "\nChecking invalid base value" );
>> +  rtems_test_assert( base >=2 && base <= 36 );
>> +  /*Test for strtoimax  */
>> +  puts( "Strtoimax Testcases...." );
>> +  puts( "Generating Status" );
>> +  status1 = strtoimax( nptr1, &endptr1, base );
>> +  rtems_test_assert( status1 != 0);
>> +  rtems_test_assert( base != EINVAL);
>> +  puts( "Checking Garbage end of endptr" );
>> +  rtems_test_assert( *endptr1 != '\0' );
>> +  puts( "Checking Underflow Case" );
>> +  rtems_test_assert( status1 >= INTMAX_MIN );
>> +  puts( "Checking Overflow Case" );
>> +  rtems_test_assert( status1 <= INTMAX_MAX ) ;
>> +  printf( "status = %jd \n" , status1 );
>> +  /*Test for strtoumax  */
>> +  puts( "Strtoumax Testcases...." );
>> +  status2 = strtoumax( nptr1, &endptr1, base );
>> +  rtems_test_assert( status2 != 0);
>> +  rtems_test_assert( status2 <= UINTMAX_MAX );
>> +  printf( "status = %ju \n", status2 );
>> +  /*Test for wcstoimax  */
>> +  puts( "Wcstoimax Testcases...." );
>> +  status1 = wcstoimax( nptr2, &endptr2, base );
>> +  rtems_test_assert( *endptr2 != '\0' );
>> +  printf( "status = %jd \n", status1 );
>> +  /*Test for wcstoumax  */
>> +  puts( "wcstoumax Testcases...." );
>> +  status2 = wcstoumax( nptr2, &endptr2, base );
>> +  TEST_END();
>> +  rtems_test_exit(0);
>> +/* NOTICE: the clock driver is explicitly disabled */
>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_MAXIMUM_TASKS            1
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> +#include <rtems/confdefs.h>
>> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> index 0000000..72640b4
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> @@ -0,0 +1,28 @@
>> +*** BEGIN OF TEST PSXINTTYPE 01 ***
>> +Checking invalid base value
>> +Strtoimax Testcases....
>> +Generating Status
>> +Checking Garbage end of endptr
>> +Checking Underflow Case
>> +Checking Overflow Case
>> +status = 123
>> +Strtoumax Testcases....
>> +Generating Status
>> +status = 123
>> +Wcstoimax Testcases....
>> +Generating Status
>> +status = -123
>> +wcstoumax Testcases....
>> +Generating Status
>> +status = 18446744073709551493
>> +*** END OF TEST PSXINTTYPE 01 ***
>> 2.7.4
