[PATCH] windows: Remove BuildRoot from all configs, add a short tmp path.
chrisj at rtems.org chrisj at rtems.org
Mon Oct 22 01:09:09 UTC 2018
Closes #3562.
 bare/config/devel/texane-stlink-1.cfg         |  1 -
 rtems/config/tools/rtems-kernel-4-1.cfg       |  1 -
 .../rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg   |  1 -
 rtems/config/tools/rtems-tools-common-1.cfg   |  1 -
 rtems/config/tools/rtems-tools-git-1.cfg      |  1 -
 source-builder/config/autoconf-2-1.cfg        |  1 -
 source-builder/config/automake-1-1.cfg        |  1 -
 source-builder/config/binutils-2-1.cfg        |  1 -
 source-builder/config/dtc-1-1.cfg             |  1 -
 source-builder/config/expat-2-1.cfg           |  1 -
 source-builder/config/freetype-1.cfg          |  1 -
 source-builder/config/gcc-common-1.cfg        |  1 -
 source-builder/config/gdb-6-1.cfg             |  1 -
 source-builder/config/gdb-common-1.cfg        |  1 -
 source-builder/config/gettext-0-1.cfg         |  1 -
 source-builder/config/glib-2-1.cfg            |  1 -
 source-builder/config/libffi-3-1.cfg          |  1 -
 source-builder/config/libiconv-1-1.cfg        |  1 -
 source-builder/config/libjpeg-1.cfg           |  3 +-
 source-builder/config/libpng-1.cfg            |  1 -
 source-builder/config/libtiff-1.cfg           |  1 -
 source-builder/config/libtool-2-1.cfg         |  1 -
 source-builder/config/libusb-1-1.cfg          |  1 -
 source-builder/config/lwip-1.cfg              |  1 -
 source-builder/config/m4-1-1.cfg              |  1 -
 source-builder/config/microwindows-1.cfg      |  1 -
 source-builder/config/net-snmp-5-1.cfg        |  1 -
 source-builder/config/ntp-4-1.cfg             |  1 -
 source-builder/config/nxlib-1.cfg             |  1 -
 source-builder/config/or1ksim-1-1.cfg         |  1 -
 source-builder/config/pixman-0-1.cfg          |  1 -
 source-builder/config/protobuf-2-1.cfg        |  1 -
 source-builder/config/qemu-1-1.cfg            |  1 -
 source-builder/config/spike-1-1.cfg           |  1 -
 source-builder/config/sqlite-3-1.cfg          |  1 -
 source-builder/config/t1lib-1.cfg             |  1 -
 source-builder/defaults.mc                    |  5 +--
 source-builder/sb/build.py                    | 32 ++++++++-----------
 source-builder/sb/setbuilder.py               |  1 +
 39 files changed, 19 insertions(+), 57 deletions(-)
diff --git a/bare/config/devel/texane-stlink-1.cfg b/bare/config/devel/texane-stlink-1.cfg
index 2f102cc..9d6a157 100644
--- a/bare/config/devel/texane-stlink-1.cfg
+++ b/bare/config/devel/texane-stlink-1.cfg
@@ -17,7 +17,6 @@ Summary:   ST-Link v%{stlink_version} for host %{_host}
 Version:   %{stlink_version}
 Release:   %{release}
 URL: 	   https://github.com/texane/stlink/
-BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
 # Source
diff --git a/rtems/config/tools/rtems-kernel-4-1.cfg b/rtems/config/tools/rtems-kernel-4-1.cfg
index cdde4c0..8c725a5 100644
--- a/rtems/config/tools/rtems-kernel-4-1.cfg
+++ b/rtems/config/tools/rtems-kernel-4-1.cfg
@@ -18,7 +18,6 @@ Summary:   RTEMS v%{rtems_kernel_version} for target %{_target} on host %{_host}
 Version:   %{rtems_kernel_version}
 Release:   %{release}
 URL: 	   http://www.rtems.org/
 # Build if the RSB is released or optionally enable/disable building the RTEMS
diff --git a/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg b/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
index 28342cd..555956b 100644
--- a/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
+++ b/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
@@ -28,7 +28,6 @@ Summary:   GCC v%{gcc_version} and Newlib v%{newlib_version} for target %{_targe
 Version:   %{gcc_version}
 Release:   %{release}
 URL: 	   http://gcc.gnu.org/
 # Supports Candian Cross (Cxc).
diff --git a/rtems/config/tools/rtems-tools-common-1.cfg b/rtems/config/tools/rtems-tools-common-1.cfg
index cf86b7e..b15fbce 100644
--- a/rtems/config/tools/rtems-tools-common-1.cfg
+++ b/rtems/config/tools/rtems-tools-common-1.cfg
@@ -9,7 +9,6 @@ Summary:   RTEMS Tools %{rtems_tools_version} for host %{_host}
 Version:   %{rtems_tools_version}
 Release:   %{release}
 License:   BSD-2-Clause + GPL-2.0
diff --git a/rtems/config/tools/rtems-tools-git-1.cfg b/rtems/config/tools/rtems-tools-git-1.cfg
index 3573c73..ec44132 100644
--- a/rtems/config/tools/rtems-tools-git-1.cfg
+++ b/rtems/config/tools/rtems-tools-git-1.cfg
 Release:   %{release}
 # Prepare the source code.
diff --git a/source-builder/config/autoconf-2-1.cfg b/source-builder/config/autoconf-2-1.cfg
index 5061cfd..7062881 100644
--- a/source-builder/config/autoconf-2-1.cfg
+++ b/source-builder/config/autoconf-2-1.cfg
@@ -16,7 +16,6 @@ Summary:   Autoconf v%{autoconf_version} for host %{_host}
 Version:   %{autoconf_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/autoconf/
 # Source
diff --git a/source-builder/config/automake-1-1.cfg b/source-builder/config/automake-1-1.cfg
index 6f45928..c4e52cd 100644
--- a/source-builder/config/automake-1-1.cfg
+++ b/source-builder/config/automake-1-1.cfg
@@ -16,7 +16,6 @@ Summary:   Automake v%{automake_version} for host %{_host}
 Version:   %{automake_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/automake/
 # Source
diff --git a/source-builder/config/binutils-2-1.cfg b/source-builder/config/binutils-2-1.cfg
index 5eefd0f..fd3ae55 100644
--- a/source-builder/config/binutils-2-1.cfg
+++ b/source-builder/config/binutils-2-1.cfg
@@ -19,7 +19,6 @@ Summary:   Binutils v%{binutils_version} for target %{_target} on host %{_host}
 Version:   %{binutils_version}
 Release:   %{release}
 URL: 	   http://sources.redhat.com/binutils
diff --git a/source-builder/config/dtc-1-1.cfg b/source-builder/config/dtc-1-1.cfg
index c9cb816..6dc08dd 100644
--- a/source-builder/config/dtc-1-1.cfg
+++ b/source-builder/config/dtc-1-1.cfg
@@ -13,7 +13,6 @@ Summary:   Device Tree Compiler v%{dtc_version} for target %{_target} on host %{
 Version:   %{dtc_version}
 Release:   %{release}
 URL: 	   http://www.jdl.com/software/
 # Source
diff --git a/source-builder/config/expat-2-1.cfg b/source-builder/config/expat-2-1.cfg
index 77774e7..2219d15 100644
--- a/source-builder/config/expat-2-1.cfg
+++ b/source-builder/config/expat-2-1.cfg
@@ -13,7 +13,6 @@ Summary:   Expat XML Parser v%{expat_version} for target %{_target} on host %{_h
 Version:   %{expat_version}
 Release:   %{release}
 URL: 	   http://expat.sourceforge.net/
 # Source
diff --git a/source-builder/config/freetype-1.cfg b/source-builder/config/freetype-1.cfg
index 37f1438..ec03feb 100644
--- a/source-builder/config/freetype-1.cfg
+++ b/source-builder/config/freetype-1.cfg
@@ -13,7 +13,6 @@ Summary:   freetype is for producing high-quality output (glyph images) of most
 Version:   %{freetype_version}
 Release:   %{release}
 URL:     http://www.freetype.org/
 # freetype Source
diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
index b432fdf..69e71ee 100644
--- a/source-builder/config/gcc-common-1.cfg
+++ b/source-builder/config/gcc-common-1.cfg
@@ -19,7 +19,6 @@ Summary:   GCC v%{gcc_version} and Newlib v%{newlib_version} for target %{_targe
 Release:   %{release}
diff --git a/source-builder/config/gdb-6-1.cfg b/source-builder/config/gdb-6-1.cfg
index 09c112c..70729b2 100644
--- a/source-builder/config/gdb-6-1.cfg
+++ b/source-builder/config/gdb-6-1.cfg
@@ -29,7 +29,6 @@ Summary:   GDB v%{gdb_version} for target %{_target} on host %{_host}
 Version:   %{gdb_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/gdb/
 # Source
diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
index 30fdf90..45df5e9 100644
--- a/source-builder/config/gdb-common-1.cfg
+++ b/source-builder/config/gdb-common-1.cfg
@@ -139,7 +139,6 @@ Summary:   GDB v%{gdb_version} for target %{_target} on host %{_host}
 Release:   %{release}
 # GDB has changed it default extension.
diff --git a/source-builder/config/gettext-0-1.cfg b/source-builder/config/gettext-0-1.cfg
index 7758d7b..19402b6 100644
--- a/source-builder/config/gettext-0-1.cfg
+++ b/source-builder/config/gettext-0-1.cfg
@@ -14,7 +14,6 @@ Summary:   GetText offers to programmers, translators, and even users, a well
 Version:   %{gettext_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/gettext/
 # Source
diff --git a/source-builder/config/glib-2-1.cfg b/source-builder/config/glib-2-1.cfg
index 6c40be2..16a51fe 100644
--- a/source-builder/config/glib-2-1.cfg
+++ b/source-builder/config/glib-2-1.cfg
@@ -14,7 +14,6 @@ Summary:   GLib provides the core application building blocks for
 Version:   %{glib_version}
 Release:   %{release}
 URL: 	   https://developer.gnome.org/glib/
 # Source
diff --git a/source-builder/config/libffi-3-1.cfg b/source-builder/config/libffi-3-1.cfg
index d258acb..f64353f 100644
--- a/source-builder/config/libffi-3-1.cfg
+++ b/source-builder/config/libffi-3-1.cfg
@@ -14,7 +14,6 @@ Summary:   LibFFI provides a portable, high level programming interface to
 Version:   %{libffi_version}
 Release:   %{release}
 URL: 	   https://sourceware.org/libffi/
 # Source
diff --git a/source-builder/config/libiconv-1-1.cfg b/source-builder/config/libiconv-1-1.cfg
index 1ccecd4..fd2d738 100644
--- a/source-builder/config/libiconv-1-1.cfg
+++ b/source-builder/config/libiconv-1-1.cfg
@@ -15,7 +15,6 @@ Summary:   Provides an iconv() implementation, for use on systems which
 Version:   %{libiconv_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/libiconv/
 # Source
diff --git a/source-builder/config/libjpeg-1.cfg b/source-builder/config/libjpeg-1.cfg
index 6ef0a5a..6acb02f 100644
--- a/source-builder/config/libjpeg-1.cfg
+++ b/source-builder/config/libjpeg-1.cfg
@@ -9,11 +9,10 @@
 %endif
-Summary:   libjpeg is the Independent JPEG Group jpeg library
+Summary:   libjpeg is the Independent JPEG Group jpeg library
 Version:   %{libjpeg_version}
 Release:   %{release}
 URL: 	   http://www.ijg.org/
 # NTP Source
diff --git a/source-builder/config/libpng-1.cfg b/source-builder/config/libpng-1.cfg
index 6821089..2644948 100644
--- a/source-builder/config/libpng-1.cfg
+++ b/source-builder/config/libpng-1.cfg
@@ -13,7 +13,6 @@ Summary:   libpng is the official PNG reference library
 Version:   %{libpng_version}
 Release:   %{release}
 URL:       http://www.libpng.org/
 # libpng Source
diff --git a/source-builder/config/libtiff-1.cfg b/source-builder/config/libtiff-1.cfg
index f445bf0..f7fa893 100644
--- a/source-builder/config/libtiff-1.cfg
+++ b/source-builder/config/libtiff-1.cfg
@@ -13,7 +13,6 @@ Summary:   libtiff provides support for the Tag Image File Format (TIFF), a wide
 Version:   %{tiff_version}
 Release:   %{release}
 URL:     http://www.libtiff.org/
 # libtiff Source
diff --git a/source-builder/config/libtool-2-1.cfg b/source-builder/config/libtool-2-1.cfg
index 0d1f972..df446b0 100644
--- a/source-builder/config/libtool-2-1.cfg
+++ b/source-builder/config/libtool-2-1.cfg
@@ -16,7 +16,6 @@ Summary:   Libtool v%{libtool_version} for host %{_host}
 Version:   %{libtool_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/libtool/
 # Source
diff --git a/source-builder/config/libusb-1-1.cfg b/source-builder/config/libusb-1-1.cfg
index 271d5e0..4b250a3 100644
--- a/source-builder/config/libusb-1-1.cfg
+++ b/source-builder/config/libusb-1-1.cfg
@@ -12,7 +12,6 @@ Summary:   LibUSB v%{libusb_version} for target %{_target} on host %{_host}
 Version:   %{libusb_version}
 Release:   %{release}
 URL: 	   http://libusb.org/
 # Source
diff --git a/source-builder/config/lwip-1.cfg b/source-builder/config/lwip-1.cfg
index 226a5d9..1dd3bb7 100644
--- a/source-builder/config/lwip-1.cfg
+++ b/source-builder/config/lwip-1.cfg
@@ -13,7 +13,6 @@ Summary:   Light weight TCP/IP stack
 Version:   %{lwip_version}
 Release:   %{release}
 URL: 	   http://git.savannah.gnu.org/cgit/lwip.git
 # LWIP Source
diff --git a/source-builder/config/m4-1-1.cfg b/source-builder/config/m4-1-1.cfg
index c77e4a3..db0c291 100644
--- a/source-builder/config/m4-1-1.cfg
+++ b/source-builder/config/m4-1-1.cfg
@@ -12,7 +12,6 @@ Summary:   M4 v%{m4_version} for host %{_host}
 Version:   %{m4_version}
 Release:   %{release}
 URL: 	   http://www.gnu.org/software/m4/
 # Source
diff --git a/source-builder/config/microwindows-1.cfg b/source-builder/config/microwindows-1.cfg
index 189a3a8..d6cfab5 100644
--- a/source-builder/config/microwindows-1.cfg
+++ b/source-builder/config/microwindows-1.cfg
@@ -13,7 +13,6 @@ Summary:   microwindows is an Open Source Window System
 Version:   %{microwindows_version}
 Release:   %{release}
 URL:     http://www.microwindows.org/
 # microwindows Source
diff --git a/source-builder/config/net-snmp-5-1.cfg b/source-builder/config/net-snmp-5-1.cfg
index cf85e19..bffe430 100644
--- a/source-builder/config/net-snmp-5-1.cfg
+++ b/source-builder/config/net-snmp-5-1.cfg
@@ -13,7 +13,6 @@ Summary:   NetSNMP is a SNMP v1, v2c and v3 Management Agent with MIB-II support
 Version:   %{net_snmp_version}
 Release:   %{release}
 URL: 	   http://www.net-snmp.org/
 # NetSNMP Source
diff --git a/source-builder/config/ntp-4-1.cfg b/source-builder/config/ntp-4-1.cfg
index 014c935..a7d5982 100644
--- a/source-builder/config/ntp-4-1.cfg
+++ b/source-builder/config/ntp-4-1.cfg
@@ -13,7 +13,6 @@ Summary:   NTP is the Network Time Protocol.
 Version:   %{ntp_version}
 Release:   %{release}
 URL: 	   http://www.ntp.org/
 # NTP Source
diff --git a/source-builder/config/nxlib-1.cfg b/source-builder/config/nxlib-1.cfg
index ba3a941..32cbb62 100644
--- a/source-builder/config/nxlib-1.cfg
+++ b/source-builder/config/nxlib-1.cfg
@@ -13,7 +13,6 @@ Summary:   nxlib is a wrapper library that provides closer compatibility to the
 Version:   %{nxlib_version}
 Release:   %{release}
 # nxlib Source
diff --git a/source-builder/config/or1ksim-1-1.cfg b/source-builder/config/or1ksim-1-1.cfg
index fb77567..468f524 100644
--- a/source-builder/config/or1ksim-1-1.cfg
+++ b/source-builder/config/or1ksim-1-1.cfg
@@ -13,7 +13,6 @@ Summary:   or1ksim-github
 Version:   %{or1ksim_version}
 Release:   %{release}
 URL: 	   https://github.com/openrisc/or1ksim
 # Source
diff --git a/source-builder/config/pixman-0-1.cfg b/source-builder/config/pixman-0-1.cfg
index f02c3d6..fc393e8 100644
--- a/source-builder/config/pixman-0-1.cfg
+++ b/source-builder/config/pixman-0-1.cfg
@@ -15,7 +15,6 @@ Summary:   Pixman is a low-level software library for pixel manipulation,
 Version:   %{pixman_version}
 Release:   %{release}
 URL: 	   http://www.pixman.org/
 # Source
diff --git a/source-builder/config/protobuf-2-1.cfg b/source-builder/config/protobuf-2-1.cfg
index f5b49c8..45cfbf0 100644
--- a/source-builder/config/protobuf-2-1.cfg
+++ b/source-builder/config/protobuf-2-1.cfg
@@ -15,7 +15,6 @@ Summary:   Protocol buffers are Googles language-neutral,
 Version:   %{protobuf_version}
 Release:   %{release}
 URL: 	   https://developers.google.com/protocol-buffers/
 # Protocol Buffers Source
diff --git a/source-builder/config/qemu-1-1.cfg b/source-builder/config/qemu-1-1.cfg
index 43af72e..178cb5c 100644
--- a/source-builder/config/qemu-1-1.cfg
+++ b/source-builder/config/qemu-1-1.cfg
@@ -21,7 +21,6 @@ Summary:   Qemu is a simulator of various processors.
 Version:   %{qemu_version}
 Release:   %{release}
 URL: 	   http://www.qemu.org/
 # Source
diff --git a/source-builder/config/spike-1-1.cfg b/source-builder/config/spike-1-1.cfg
index 54e4915..ede6a42 100644
--- a/source-builder/config/spike-1-1.cfg
+++ b/source-builder/config/spike-1-1.cfg
@@ -13,7 +13,6 @@ Summary:   spike-github
 Version:   %{spike_version}
 Release:   %{release}
 URL: 	   https://github.com/riscv/riscv-isa-sim/
 # Source
diff --git a/source-builder/config/sqlite-3-1.cfg b/source-builder/config/sqlite-3-1.cfg
index a748848..07699fd 100644
--- a/source-builder/config/sqlite-3-1.cfg
+++ b/source-builder/config/sqlite-3-1.cfg
@@ -15,7 +15,6 @@ Summary:   SQLite is an in-process library that implements a
 Version:   %{sqlite_version}
 Release:   %{release}
 URL: 	   http://www.sqlite.org/
 # Sqlite Source
diff --git a/source-builder/config/t1lib-1.cfg b/source-builder/config/t1lib-1.cfg
index d2a47a2..3cb02c5 100644
--- a/source-builder/config/t1lib-1.cfg
+++ b/source-builder/config/t1lib-1.cfg
@@ -13,7 +13,6 @@ Summary:   t1lib is the official PNG reference library
 Version:   %{t1lib_version}
 Release:   %{release}
 URL:       http://www.t1lib.org/
 # t1lib Source
diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
index aa1a5e6..88cab4d 100644
--- a/source-builder/defaults.mc
+++ b/source-builder/defaults.mc
@@ -40,6 +40,7 @@ nil:                 none,    none,     ''
 # Set to invalid values.
 _bset:               none,    none,     ''
+_bset_tmp:           none,    none,     ''
 name:                none,    none,     ''
 version:             none,    none,     ''
 release:             none,    none,     ''
@@ -91,8 +92,8 @@ _buildcxcdir:        dir,     optional, '%{_topdir}/build/%{buildname}-cxc'
 _buildxcdir:         dir,     optional, '%{_topdir}/build/%{buildname}-xc'
 _docdir:             dir,     none,     '%{_defaultdocdir}'
 _tmppath:            dir,     none,     '%{_topdir}/build/tmp'
-_tmproot:            dir,     none,     '%{_tmppath}/sb-%{_uid}/%{_bset}'
-_tmpcxcroot:         dir,     none,     '%{_tmppath}/sb-%{_uid}-cxc/%{_bset}'
+_tmproot:            dir,     none,     '%{_tmppath}/sb-%{_uid}/%{_bset_tmp}'
+_tmpcxcroot:         dir,     none,     '%{_tmppath}/sb-%{_uid}-cxc/%{_bset_tmp}'
 buildroot:           dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}'
 buildcxcroot:        dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-cxc'
 buildxcroot:         dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-xx'
diff --git a/source-builder/sb/build.py b/source-builder/sb/build.py
index a17bfe2..faa11cc 100644
--- a/source-builder/sb/build.py
+++ b/source-builder/sb/build.py
@@ -58,6 +58,19 @@ def humanize_number(num, suffix):
         num /= 1024.0
     return "%.3f%s%s" % (size, 'Y', suffix)
+def short_name(name):
+    # If on Windows use short names to keep the build paths as short as possible.
+    if options.host_windows:
+        buildname = ''
+        add = True
+        for n in name.split('-'):
+            buildname += n[0]
+        return buildname
+    else:
+        return name
 class script:
     """Create and manage a shell script."""
@@ -108,23 +121,6 @@ class script:
 class build:
     """Build a package given a config file."""
-    def _name_(self, name):
-        # If on Windows use shorter names to keep the build paths.
-        if options.host_windows:
-            buildname = ''
-            add = True
-            for c in name:
-                if c == '-':
-                    add = True
-                elif add:
-                    buildname += c
-                    add = False
-            return buildname
-        else:
-            return name
     def _generate_report_(self, header, footer = None):
         ereport.generate('rsb-report-%s.txt' % self.macros['name'],
                          self.opts, header, footer)
@@ -141,7 +137,7 @@ class build:
             self.config = config.file(name, opts, self.macros)
             self.script_build = script()
             self.script_clean = script()
-            self.macros['buildname'] = self._name_(self.macros['name'])
+            self.macros['buildname'] = short_name(self.macros['name'])
         except error.general as gerr:
             log.notice(str(gerr))
             log.stderr('Build FAILED')
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index c50ba20..3589e8c 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -322,6 +322,7 @@ class buildset:
         else:
             exbset = self.macros.expand(self.bset)
             self.macros['_bset'] = exbset
+            self.macros['_bset_tmp'] = build.short_name(exbset)
             root, ext = path.splitext(exbset)
             if exbset.endswith('.bset'):
                 bset = exbset
2.19.0
