[PATCH] Avoid default RTEMS application configuration
Mon Oct 22 05:28:51 UTC 2018
On 20/10/2018 02:04, Chris Johns wrote:
> On 19/10/18 5:47 pm, Sebastian Huber wrote:
>> ----- Am 18. Okt 2018 um 19:56 schrieb Chris Johns chrisj at rtems.org:
>>> On 18/10/18 6:38 pm, Sebastian Huber wrote:
>>>> Use a test body with a proper RTEMS application configuration to avoid a
>>>> dependency on the default configuration.  Do not include
>>>> <rtems/score/cpuopts.h> directly since this header file is an
>>>> implementation detail.
>>>> Update #3551.
>>>>   rtems.py | 30 +++++++++++++++++-------------
>>>>   1 file changed, 17 insertions(+), 13 deletions(-)
>>>> diff --git a/rtems.py b/rtems.py
>>>> index 1b0da60..c7a1966 100644
>>>> --- a/rtems.py
>>>> +++ b/rtems.py
>>>> @@ -259,13 +259,18 @@ def configure(conf, bsp_configure = None):
>>>>           # Checks for various RTEMS features.
>>>> -        conf.multicheck({ 'header_name': 'rtems/score/cpuopts.h'},
>>>> -                        msg = 'Checking for RTEMS CPU options header',
>>>> -                        mandatory = True)
>>>> -        load_cpuopts(conf, ab, rtems_path)
>>> OK.
>>>> -        conf.multicheck({ 'header_name': 'rtems.h'},
>>>> -                        msg = 'Checking for RTEMS header',
>>>> -                        mandatory = True)
>>> Why remove the test? I see the app test below checks for the header however the
>>> test creates a nice specific error message.
>> The test is not a simple compile test and dosen't only check that you can include <rtems.h>. In addition it checks that you can link a sample application successfully.
> The test you have added is a good addition. I am asking, why not keep both
> tests? It comes down to the error message and how user friendly it is. If
> 'rtems.h' is present we can assume it is an installed RTEMS. The second test can
> check the quality of the install. I would like to avoid users needing to dig
> into a config log to find an error and then try to understand it to figure out
> they have a bad path on the command line.
Waf doesn't simply check that you can include a header file. In addition
it tries to link an executable:
Checking for header rtems.h
int main(int argc, char **argv) {
     (void)argc; (void)argv;
     return 0;
[1/2] Compiling
build/.conf_check_ff53a9f7519945ffcad9ed062861cb10/test.cpp
['/build/rtems/5/bin/powerpc-rtems5-g++', '-qrtems',
'-B/build/rtems/5/powerpc-rtems5/lib/',
'-B/build/rtems/5/powerpc-rtems5/qoriq_e500/lib/', '--specs',
'bsp_specs', '-mcpu=8540', '-mcpu=8540', '-meabi', '-meabi',
'-msdata=sysv', '-msdata=sysv', '-fno-common', '-fno-common',
'-mstrict-align', '-mstrict-align', '-mspe', '-mspe', '-mabi=spe',
'-mabi=spe', '-mfloat-gprs=double', '-mfloat-gprs=double',
'-ffunction-sections', '-ffunction-sections', '-fdata-sections',
'-fdata-sections', '../test.cpp', '-c', '-o',
'/scratch/git-rtems-libbsd/build/.conf_check_ff53a9f7519945ffcad9ed062861cb10/testbuild/test.cpp.1.o']
[2/2] Linking
build/.conf_check_ff53a9f7519945ffcad9ed062861cb10/testbuild/testprog
'-fdata-sections', 'test.cpp.1.o', '-o',
'/scratch/git-rtems-libbsd/build/.conf_check_ff53a9f7519945ffcad9ed062861cb10/testbuild/testprog',
'-Wl,-Bstatic', '-Wl,-Bdynamic']
Using a simple main() requires the default configuration.
> What is the error report with just the 'main' test you added and an invalid
> RTEMS path?
When I remove the rtems.h from the BSP installation, then I get this:
Building a trivial RTEMS application          : no
The configuration failed
(complete log in /scratch/git-rtems-libbsd/build/config.log)
In config.log:
void Init(rtems_task_argument arg) { (void)arg; }
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER 1
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
[1/2] Compiling
build/.conf_check_506c35a0aa2e9f571a9e7ed38df523b2/test.c
['/build/rtems/5/bin/powerpc-rtems5-gcc', '-qrtems',
'-fdata-sections', '../test.c', '-c', '-o',
'/scratch/git-rtems-libbsd/build/.conf_check_506c35a0aa2e9f571a9e7ed38df523b2/testbuild/test.c.1.o']
err: ../test.c:1:10: fatal error: rtems.h: No such file or directory
compilation terminated.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
