[PATCH v2] Avoid default RTEMS application configuration
Mon Oct 22 06:13:50 UTC 2018
On 22/10/2018 16:46, Sebastian Huber wrote:
> Use a test body with a proper RTEMS application configuration to avoid a
> dependency on the default configuration.  Do not include
> <rtems/score/cpuopts.h> directly since this header file is an
> implementation detail.
Looks good. Please push.
Will you update libbsd and examples-v2?
Thanks
