Cygwin sb-check Failure
Tue Oct 23 20:38:18 UTC 2018
On 24/10/2018 07:27, Joel Sherrill wrote:
> Looks like the recent changes have broken Cygwin:
> $ ../source-builder/sb-check
> error: failed to load CYGWIN_NT-10.0 host support: error: cannot find MinGW
> install: C:/cygwin64/mingw64
> Assuming this is similar to the MSYS2 situation, is there a reason to want to
> use the mingw python2 with Cygwin and is it even avaialble?
A cygwin build should be POSIX which should work like Linux etc.
Left a piece of debug in windows.py. On line 161 please remove the 'or True'. If
this works on cygwin please push.
I am sorry about this.
