[PATCH v2] sb: Add support to search for a suitable version of python.
Malte Münch mamu at stablerock.de
Wed Oct 24 10:20:41 UTC 2018
Hi Chris,
the output with LC_ALL= is still in german but LC_ALL=C returns the
following:
[mamu at verstappen rtems]$ echo “” | LC_ALL=C gcc -xc -E -v -
Using built-in specs.
COLLECT_GCC=gcc
Target: x86_64-pc-linux-gnu
Configured with: /build/gcc/src/gcc/configure --prefix=/usr
--libdir=/usr/lib --libexecdir=/usr/lib --ma$
dir=/usr/share/man --infodir=/usr/share/info
--with-bugurl=https://bugs.archlinux.org/ --enable-language$
=c,c++,ada,fortran,go,lto,objc,obj-c++ --enable-shared
--enable-threads=posix --enable-libmpx --with-sys$
em-zlib --with-isl --enable-__cxa_atexit --disable-libunwind-exceptions
--enable-clocale=gnu --disable-l$
bstdcxx-pch --disable-libssp --enable-gnu-unique-object
--enable-linker-build-id --enable-lto --enable-p$
ugin --enable-install-libiberty --with-linker-hash-style=gnu
--enable-gnu-indirect-function --enable-mul$
ilib --disable-werror --enable-checking=release --enable-default-pie
--enable-default-ssp --enable-cet=a$
to
Thread model: posix
gcc version 8.2.1 20180831 (GCC)
COLLECT_GCC_OPTIONS='-E' '-v' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/cc1 -E -quiet -v -
-mtune=generic -march=x86-64
ignoring nonexistent directory
"/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../x86_64-pc-linux-gnu/i$
clude"
ignoring duplicate directory "/usr/include"
#include "..." search starts here:
#include <...> search starts here:
 /usr/include/
 /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include
 /usr/local/include
 /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed
End of search list.
# 1 "<stdin>"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3
# 32 "<command-line>" 2
# 1 "<stdin>"
COMPILER_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gc
c/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../l
ib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../:/lib/:/usr/lib/
I am not sure if the build will run through but until everything looks
fine with export LC_ALL=C
Best
Malte
