[PATCH v2] sb: Add support to search for a suitable version of python.
Malte Münch mamu at stablerock.de
Wed Oct 24 11:23:12 UTC 2018
Hi Chris,
the GDB build went fine but lateron the rtems-tools build crashed with
the following error:
ret=[x for x in
self.ant_iter(accept=accept,pats=[to_pat(incl),to_pat(excl)],maxdepth=kw.get('maxdepth',25),dir=dir,src=src,remove=kw.get('remove',True))]
RuntimeError: generator raised StopIteration
shell cmd failed: /bin/sh -ex
/home/mamu/dr/rsb/rtems/build/rtems-tools-36fde5169aef5b0af37f951907705caee76626ee-1/do-build
error: building rtems-tools-36fde5169aef5b0af37f951907705caee76626ee-1
  See error report:
rsb-report-rtems-tools-36fde5169aef5b0af37f951907705caee76626ee-1.txt
Build Set: Time 0:55:40.241000
> Many thanks for the help debugging this.
I have to thank you. I wouldn't have made it so far without your help.
Best
Malte
