[PATCH v2] sb: Add support to search for a suitable version of python.
Wed Oct 24 22:47:29 UTC 2018
On 25/10/2018 09:09, Malte Münch wrote:
> It seems to be an issue with the waf building system. If i change the
> symlink /usr/bin/python to python2 everything works fine and the build
> is able to run through.
I suspected this may be an issue. joel and I are planning to update all the waf
instances we have in our projects.
Can you please clone the rtems-tools.git repo and run the build command from the
RSB log and then fetch the latest waf from waf.io and try that to see if it
resolves the issue?
Thanks
