[PATCH] c-user: Clarify scheduler configuration
Sebastian Huber
Thu Oct 25 04:48:37 UTC 2018
c-user/configuring_a_system.rst | 57 ++++++++++++++++++++++-----
c-user/scheduling_concepts.rst | 35 +++++++++-------
c-user/symmetric_multiprocessing_services.rst | 2 +
3 files changed, 71 insertions(+), 23 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index d9f65a4..e622b91 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1452,7 +1452,7 @@ DEFAULT VALUE:
DESCRIPTION:
``CONFIGURE_MAXIMUM_PROCESSORS`` must be set to the maximum number of
- processors an applicaiton intends to use. The number of acually available
+ processors an application intends to use. The number of actually available
processors depends on the hardware and may be less. It is recommended to
use the smallest value suitable for the application in order to save
memory. Each processor needs an idle thread and interrupt stack for
@@ -3285,7 +3285,17 @@ General Scheduler Configuration
This section defines the configuration parameters related to selecting a
-scheduling algorithm for an application. For the :ref:`schedulers built into
+scheduling algorithm for an application. A scheduler configuration is optional
+and only necessary in very specific circumstances. A normal application
+configuration does not need any of the configuration options described in this
+section. By default, the :ref:`Deterministic Priority Scheduler
+<SchedulerPriority>` algorithm is used in uniprocessor configurations. In case
+SMP is enabled and the configured maximum processors
+(:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`) is greater
+than one, then the :ref:`Earliest Deadline First (EDF) SMP Scheduler
+<SchedulerSMPEDF>` is selected as the default scheduler algorithm.
+For the :ref:`schedulers built into
RTEMS <SchedulingConcepts>`, the configuration is straightforward. All that is
required is to define the configuration macro which specifies which scheduler
you want for in your application.
@@ -3318,6 +3328,9 @@ DESCRIPTION:
<SchedulerCBS>` algorithm is made available to the application.
NOTES:
+ This scheduler configuration option is an advanced configuration option.
+ Think twice before you use it.
In case no explicit :ref:`clustered scheduler configuration
<ConfigurationSchedulersClustered>` is present, then it is used as the
scheduler for exactly one processor.
@@ -3346,6 +3359,9 @@ DESCRIPTION:
<SchedulerEDF>` algorithm is made available to the application.
NOTES:
@@ -3374,6 +3390,9 @@ DESCRIPTION:
<SchedulerSMPEDF>` algorithm is made available to the application.
NOTES:
This scheduler algorithm is only available when RTEMS is built with SMP
support enabled.
@@ -3381,9 +3400,9 @@ NOTES:
scheduler for up to 32 processors.
- This scheduler algorithm is the default in SMP configurations and is only
- selected when :ref:`CONFIGURE_MAXIMUM_PROCESSORS
- <CONFIGURE_MAXIMUM_PROCESSORS>` is greater than one.
+ This scheduler algorithm is the default in SMP configurations if
+ :ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>` is
+ greater than one.
.. index:: CONFIGURE_SCHEDULER_NAME
@@ -3418,7 +3437,8 @@ DESCRIPTION:
the scheduler is determined by the configuration.
NOTES:
- None.
.. index:: CONFIGURE_SCHEDULER_PRIORITY
@@ -3445,6 +3465,9 @@ DESCRIPTION:
<SchedulerPriority>` algorithm is made available to the application.
NOTES:
@@ -3478,6 +3501,9 @@ DESCRIPTION:
application.
NOTES:
support enabled.
@@ -3509,6 +3535,9 @@ DESCRIPTION:
<SchedulerSMPPriority>` algorithm is made available to the application.
NOTES:
support enabled.
@@ -3540,6 +3569,9 @@ DESCRIPTION:
<SchedulerPrioritySimple>` algorithm is made available to the application.
NOTES:
@@ -3569,6 +3601,9 @@ DESCRIPTION:
application.
NOTES:
support enabled.
@@ -3612,6 +3647,9 @@ DESCRIPTION:
the per-thread information of the user scheduler.
NOTES:
At this time, the mechanics and requirements for writing a new scheduler
are evolving and not fully documented. It is recommended that you look at
the existing Deterministic Priority Scheduler in
@@ -3624,6 +3662,9 @@ NOTES:
Clustered Scheduler Configuration
+A clustered scheduler configuration is optional. It is an advanced
+configuration area and only necessary in specific circumstances.
Clustered scheduling helps to control the worst-case latencies in a
multiprocessor system (SMP). The goal is to reduce the amount of shared state
in the system and thus prevention of lock contention. Modern multiprocessor
@@ -3636,9 +3677,7 @@ partitioned into non-empty pairwise-disjoint subsets. These subsets are called
clusters. Clusters with a cardinality of one are partitions. Each cluster is
owned by exactly one scheduler.
-A clustered scheduler configuration is optional. By default, up to 32
-processors are managed by the :ref:`EDF SMP Scheduler <SchedulerSMPEDF>`. In
-order to use clustered scheduling the application designer has to answer two
+In order to use clustered scheduling the application designer has to answer two
questions.
#. How is the set of processors partitioned into clusters?
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index 239e0c3..e088c62 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -239,20 +239,27 @@ allowed to run.
Earliest Deadline First SMP Scheduler
-A job-level fixed-priority scheduler using the Earliest Deadline First (EDF)
-method. By convention, the maximum priority level is
-:math:`min(INT\_MAX, 2^{62} - 1)` for background tasks. The tasks with an
-active deadline have a higher priority than the background tasks. This
-scheduler supports task processor affinities of one-to-one and one-to-all, e.g.
-a task can execute on exactly one processor or all processors managed by the
-scheduler instance. This is the default scheduler in SMP configurations if
-more than one processor is configured. The processor affinity set of a task
-must contain all online processors to select the one-to-all affinity. This is
-to avoid pathological cases if processors are added/removed to/from the
-scheduler instance at run-time. In case the processor affinity set contains
-not all online processors, then a one-to-one affinity will be used selecting
-the processor with the largest index within the set of processors currently
-owned by the scheduler instance.
+This is a job-level fixed-priority scheduler using the Earliest Deadline First
+(EDF) method. By convention, the maximum priority level is
+:math:`min(INT\_MAX, 2^{62} - 1)` for background tasks. Tasks without an
+active deadline are background tasks. In case deadlines are not used, then the
+EDF scheduler behaves exactly like a fixed-priority scheduler. The tasks with
+an active deadline have a higher priority than the background tasks. This
+scheduler supports :ref:`task processor affinities <rtems_task_set_affinity>`
+of one-to-one and one-to-all, e.g. a task can execute on exactly one processor
+or all processors managed by the scheduler instance. The processor affinity
+set of a task must contain all online processors to select the one-to-all
+affinity. This is to avoid pathological cases if processors are added/removed
+to/from the scheduler instance at run-time. In case the processor affinity set
+contains not all online processors, then a one-to-one affinity will be used
+selecting the processor with the largest index within the set of processors
+currently owned by the scheduler instance. This scheduler algorithm supports
+:ref:`thread pinning <ThreadPinning>`. The ready queues use a red-black tree
+with the task priority as the key.
+This scheduler algorithm is the default scheduler in SMP configurations if more
+than one processor is configured (:ref:`CONFIGURE_MAXIMUM_PROCESSORS
+<CONFIGURE_MAXIMUM_PROCESSORS>`).
.. _SchedulerSMPPriority:
diff --git a/c-user/symmetric_multiprocessing_services.rst b/c-user/symmetric_multiprocessing_services.rst
index 91c1d27..61208c6 100644
--- a/c-user/symmetric_multiprocessing_services.rst
+++ b/c-user/symmetric_multiprocessing_services.rst
@@ -810,6 +810,8 @@ RTEMS provides two means for per-processor data:
This API is not intended for general application use. Please ask on the
development mailing list in case you want to use it.
+.. _ThreadPinning:
Thread Pinning
2.16.4
