[PATCH] Coverage : Use '.o' files for coverage analysis
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Oct 25 19:06:38 UTC 2018
Hi Chris!
Do you find the patch alright? I was wondering if you were expecting some
changes or modifications. I can do it and submit within this week. :)
On Tue, 16 Oct 2018 at 09:06, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> mistakenly resent this. Sorry about it.
> I have made a separate patch for covoar,
> I intended to send that one. :)
> On Tue, Oct 16, 2018, 9:03 AM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Use the Object files in cpukit/ instead of the static library
>> for Coverage analysis
>> tester/rt/coverage.py | 27 ++++--
>> tester/rtems/testing/coverage/symbol-sets.ini | 90 +++++++++----------
>> 2 files changed, 66 insertions(+), 51 deletions(-)
>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>> index c979332..55cb59a 100644
>> --- a/tester/rt/coverage.py
>> +++ b/tester/rt/coverage.py
>> @@ -244,13 +244,17 @@ class symbol_parser(object):
>> symbol_config_path,
>> symbol_select_path,
>> symbol_set,
>> - build_dir):
>> + build_dir,
>> + bsp_name,
>> + target):
>> self.symbol_select_file = symbol_select_path
>> self.symbol_file = symbol_config_path
>> self.build_dir = build_dir
>> self.symbol_sets = {}
>> self.symbol_set = symbol_set
>> self.ssets = []
>> + self.bsp_name = bsp_name
>> + self.target = target
>> def parse(self):
>> config = configparser.ConfigParser()
>> @@ -264,9 +268,13 @@ class symbol_parser(object):
>> for sset in self.ssets:
>> lib = path.join(self.build_dir, config.get('libraries',
>> sset))
>> self.symbol_sets[sset] = lib.encode('utf-8')
>> + ss = self.symbol_sets[sset]
>> + ss = ss.replace('@BSP@', self.bsp_name)
>> + ss = ss.replace('@BUILD-TARGET@', self.target)
>> + self.symbol_sets[sset] = ss
>> return self.ssets
>> except:
>> - raise error.general('Symbol set parsing failed')
>> + raise error.general('Symbol set parsing failed for %s' %
>> sset)
>> def write_ini(self, symbol_set):
>> @@ -275,11 +283,15 @@ class symbol_parser(object):
>> config.add_section('symbol-sets')
>> config.set('symbol-sets', 'sets', sset)
>> config.add_section(sset)
>> - config.set(sset, 'libraries', self.symbol_sets[sset])
>> + object_files = [o for o in
>> os.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
>> + object_paths = []
>> + for o in object_files:
>> + object_paths.append(path.join(self.symbol_sets[sset], o))
>> + config.set(sset, 'libraries', ','.join(object_paths))
>> with open(self.symbol_select_file, 'w') as conf:
>> - config.write(conf)
>> + config.write(conf)
>> except:
>> - raise error.general('symbol parser write failed')
>> + raise error.general('symbol parser write failed for %s' %
>> sset)
>> class covoar(object):
>> @@ -357,6 +369,7 @@ class coverage_run(object):
>> self.report_format = self.macros['cov_report_format']
>> self.target = self.macros['target']
>> + self.bsp_name = self.macros['bsp'].split('-')[0]
>> def run(self):
>> try:
>> @@ -366,7 +379,9 @@ class coverage_run(object):
>> parser = symbol_parser(self.symbol_config_path,
>> self.symbol_select_path,
>> self.symbol_set,
>> - build_dir)
>> + build_dir,
>> + self.bsp_name,
>> + self.target)
>> symbol_sets = parser.parse()
>> for sset in symbol_sets:
>> parser.write_ini(sset)
>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>> b/tester/rtems/testing/coverage/symbol-sets.ini
>> index 2685ef4..8f85533 100644
>> --- a/tester/rtems/testing/coverage/symbol-sets.ini
>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>> @@ -29,50 +29,50 @@
>> [symbol-sets]
>> -sets =
>> score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>> +sets =
>> score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>> [libraries]
>> -score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>> -rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>> -sapi = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/libsapi.a
>> -libdl = @BUILD-TARGET@/c/@BSP@/cpukit/libdl/libdl.a
>> -posix = @BUILD-TARGET@/c/@BSP@/cpukit/posix/libposix.a
>> -libirfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/librfs.a
>> -libdosfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdosfs.a
>> -libdevfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdevfs.a
>> -libimfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libimfs.a
>> -#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs/libdefaultfs.a
>> -#libjffs2 = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libjffs2.a
>> -#dtc = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt/libfdt.a
>> -#libdrvmgr = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr/libdrvmgr.a
>> -#libi2c = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c/libi2c.a
>> -libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/libcsupport.a
>> -libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libbspcmdline.a
>> -libcpuuse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcpuuse.a
>> -libstackchk = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstackchk.a
>> -libfsmount = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libfsmount.a
>> -libstringto = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstringto.a
>> -libdevnull = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdevnull.a
>> -libdumpbuf = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdumpbuf.a
>> -#libcapture = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcapture.a
>> -#libdummy = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdummy.a
>> -#libmonitor = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmonitor.a
>> -#libmouse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmouse.a
>> -#libmw-fb = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmw-fb.a
>> -#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libredirector.a
>> -#librtemsfdt = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/librtemsfdt.a
>> -#libserdbg = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libserdbg.a
>> -#libshell = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libshell.a
>> -#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libtestsupport.a
>> -#libuntar = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuntar.a
>> -#libutf8proc = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libutf8proc.a
>> -#libuuid = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuuid.a
>> -#libxz = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libxz.a
>> -libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
>> -#libpci = @BUILD-TARGET@/c/@BSP@/cpukit/libpci/libpci.a
>> -#librpc = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/librpc.a
>> -#libxdr = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/libxdr.a
>> -#libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
>> -#libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
>> -#libstdthreads = @BUILD-TARGET@/c/@BSP@
>> /cpukit/libstdthreads/libstdthreads.a
>> -#zlib = @BUILD-TARGET@/c/@BSP@/cpukit/zlib/libz.a
>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
>> +sapi = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
>> +libdl = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
>> +posix = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
>> +librfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
>> +libdosfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
>> +libdevfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
>> +libimfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
>> +#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
>> +#libjffs2 = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
>> +#dtc = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
>> +#libdrvmgr = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
>> +#libi2c = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
>> +#libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
>> +libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
>> +libcpuuse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
>> +libstackchk = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
>> +libfsmount = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
>> +libstringto = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
>> +libdevnull = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
>> +libdumpbuf = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
>> +#libcapture = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libdummy = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libmonitor = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libmouse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libmw-fb = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#librtemsfdt = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libserdbg = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libshell = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libuntar = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libutf8proc = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libuuid = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +#libxz = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>> +libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
>> +#libpci = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
>> +#librpc = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>> +#libxdr = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>> +#libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
>> +#libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
>> +#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
>> +#zlib = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
>> 2.17.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181026/11213d02/attachment-0001.html>
