[PATCH] Coverage : Generate reports using the object files in cpukit
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Oct 25 20:19:15 UTC 2018
tester/rt/coverage.py | 27 ++++--
tester/rtems/testing/coverage/symbol-sets.ini | 90 +++++++++----------
2 files changed, 66 insertions(+), 51 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index c979332..978a8c4 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -244,13 +244,17 @@ class symbol_parser(object):
symbol_config_path,
symbol_select_path,
symbol_set,
- build_dir):
+ build_dir,
+ bsp_name,
+ target):
self.symbol_select_file = symbol_select_path
self.symbol_file = symbol_config_path
self.build_dir = build_dir
self.symbol_sets = {}
self.symbol_set = symbol_set
self.ssets = []
+ self.bsp_name = bsp_name
+ self.target = target
def parse(self):
config = configparser.ConfigParser()
@@ -264,9 +268,13 @@ class symbol_parser(object):
for sset in self.ssets:
lib = path.join(self.build_dir, config.get('libraries', sset))
self.symbol_sets[sset] = lib.encode('utf-8')
+ ss = self.symbol_sets[sset]
+ ss = ss.replace('@BSP@', self.bsp_name)
+ ss = ss.replace('@BUILD-TARGET@', self.target)
+ self.symbol_sets[sset] = ss
return self.ssets
except:
- raise error.general('Symbol set parsing failed')
+ raise error.general('Symbol set parsing failed for %s' % (sset))
def write_ini(self, symbol_set):
@@ -275,11 +283,15 @@ class symbol_parser(object):
config.add_section('symbol-sets')
config.set('symbol-sets', 'sets', sset)
config.add_section(sset)
- config.set(sset, 'libraries', self.symbol_sets[sset])
+ object_files = [o for o in os.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
+ object_paths = []
+ for o in object_files:
+ object_paths.append(path.join(self.symbol_sets[sset], o))
+ config.set(sset, 'libraries', ','.join(object_paths))
with open(self.symbol_select_file, 'w') as conf:
- config.write(conf)
+ config.write(conf)
except:
- raise error.general('symbol parser write failed')
+ raise error.general('symbol parser write failed for %s' % (sset))
class covoar(object):
@@ -357,6 +369,7 @@ class coverage_run(object):
self.report_format = self.macros['cov_report_format']
self.target = self.macros['target']
+ self.bsp_name = self.macros['bsp'].split('-')[0]
def run(self):
try:
@@ -366,7 +379,9 @@ class coverage_run(object):
parser = symbol_parser(self.symbol_config_path,
self.symbol_select_path,
self.symbol_set,
- build_dir)
+ build_dir,
+ self.bsp_name,
+ self.target)
symbol_sets = parser.parse()
for sset in symbol_sets:
parser.write_ini(sset)
diff --git a/tester/rtems/testing/coverage/symbol-sets.ini b/tester/rtems/testing/coverage/symbol-sets.ini
index 2685ef4..8f85533 100644
--- a/tester/rtems/testing/coverage/symbol-sets.ini
+++ b/tester/rtems/testing/coverage/symbol-sets.ini
@@ -29,50 +29,50 @@
[symbol-sets]
-sets = score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
+sets = score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
[libraries]
-score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
-rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
-sapi = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/libsapi.a
-libdl = @BUILD-TARGET@/c/@BSP@/cpukit/libdl/libdl.a
-posix = @BUILD-TARGET@/c/@BSP@/cpukit/posix/libposix.a
-libirfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/librfs.a
-libdosfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdosfs.a
-libdevfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdevfs.a
-libimfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libimfs.a
-#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs/libdefaultfs.a
-#libjffs2 = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libjffs2.a
-#dtc = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt/libfdt.a
-#libdrvmgr = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr/libdrvmgr.a
-#libi2c = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c/libi2c.a
-libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/libcsupport.a
-libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libbspcmdline.a
-libcpuuse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcpuuse.a
-libstackchk = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstackchk.a
-libfsmount = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libfsmount.a
-libstringto = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstringto.a
-libdevnull = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdevnull.a
-libdumpbuf = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdumpbuf.a
-#libcapture = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcapture.a
-#libdummy = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdummy.a
-#libmonitor = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmonitor.a
-#libmouse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmouse.a
-#libmw-fb = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmw-fb.a
-#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libredirector.a
-#librtemsfdt = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/librtemsfdt.a
-#libserdbg = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libserdbg.a
-#libshell = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libshell.a
-#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libtestsupport.a
-#libuntar = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuntar.a
-#libutf8proc = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libutf8proc.a
-#libuuid = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuuid.a
-#libxz = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libxz.a
-libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
-#libpci = @BUILD-TARGET@/c/@BSP@/cpukit/libpci/libpci.a
-#librpc = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/librpc.a
-#libxdr = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/libxdr.a
-#libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
-#libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
-#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads/libstdthreads.a
-#zlib = @BUILD-TARGET@/c/@BSP@/cpukit/zlib/libz.a
+score = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
+rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
+sapi = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
+libdl = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
+posix = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
+librfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
+libdosfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
+libdevfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
+libimfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
+#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
+#libjffs2 = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
+#dtc = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
+#libdrvmgr = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
+#libi2c = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
+#libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
+libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
+libcpuuse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
+libstackchk = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
+libfsmount = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
+libstringto = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
+libdevnull = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
+libdumpbuf = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
+#libcapture = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libdummy = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libmonitor = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libmouse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libmw-fb = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#librtemsfdt = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libserdbg = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libshell = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libuntar = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libutf8proc = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libuuid = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+#libxz = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
+libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
+#libpci = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
+#librpc = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
+#libxdr = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
+#libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
+#libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
+#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
+#zlib = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
2.17.2
