[PATCH 00/14] Enable all POSIX APIs except signals and sporadic server
Sebastian Huber
Mon Oct 29 09:03:09 UTC 2018
This is the final patch set to enable all POSIX APIs except signals and
the sporadic server.
Sebastian Huber (14):
posix: Provide aio_suspend() by default
score: Remove bogus thread object name support
Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES
Move default config to librtemsdefaultconfig.a
posix: Split posix_api_configuration_table
posix: Provide named semaphores by default
posix: Provide shared memory objects by default
posix: Provide message queues by default
posix: Hide POSIX_API_Control by default
posix: Provide threads by default
posix: Enable psxtmtests tests by default
posix: Enable more smptests tests by default
posix: Enable more psxtests by default
posix: Enable more sptests test cases by default
cpukit/Makefile.am | 81 +++---
cpukit/include/rtems/confdefs.h | 366 ++++++++++++-------------
cpukit/include/rtems/monitor.h | 4 +-
cpukit/include/rtems/posix/config.h | 66 +----
cpukit/include/rtems/posix/mqueue.h | 2 +
cpukit/include/rtems/posix/mqueueimpl.h | 6 +-
cpukit/include/rtems/posix/psignal.h | 2 +
cpukit/include/rtems/posix/pthread.h | 3 +-
cpukit/include/rtems/posix/pthreadattrimpl.h | 2 -
cpukit/include/rtems/posix/pthreadimpl.h | 2 +
cpukit/include/rtems/posix/semaphore.h | 2 +
cpukit/include/rtems/posix/semaphoreimpl.h | 6 +-
cpukit/include/rtems/posix/shm.h | 4 +
cpukit/include/rtems/posix/threadsup.h | 2 +
cpukit/include/rtems/posix/timer.h | 2 +
cpukit/include/rtems/score/coremsg.h | 26 +-
cpukit/include/rtems/score/object.h | 16 +-
cpukit/include/rtems/score/objectimpl.h | 74 ++---
cpukit/include/rtems/score/thread.h | 10 +-
cpukit/include/rtems/score/threadimpl.h | 4 +-
cpukit/libcsupport/src/resource_snapshot.c | 30 +-
cpukit/libmisc/monitor/mon-monitor.c | 4 -
cpukit/libmisc/monitor/mon-object.c | 8 +-
cpukit/posix/src/key.c | 4 +-
cpukit/posix/src/mqueue.c | 3 +-
cpukit/posix/src/mqueueconfig.c | 34 +++
cpukit/posix/src/psignal.c | 2 +-
cpukit/posix/src/psignalconfig.c | 34 +++
cpukit/posix/src/psxsemaphore.c | 3 +-
cpukit/posix/src/psxsemaphoreconfig.c | 34 +++
cpukit/posix/src/psxtimerconfig.c | 34 +++
cpukit/posix/src/psxtransschedparam.c | 6 +-
cpukit/posix/src/pthread.c | 15 +-
cpukit/posix/src/pthreadconfig.c | 34 +++
cpukit/posix/src/pthreadcreate.c | 14 +-
cpukit/posix/src/pthreadinitthreads.c | 4 +-
cpukit/posix/src/pthreadsetschedparam.c | 16 +-
cpukit/posix/src/ptimer.c | 7 +-
cpukit/posix/src/semaphoredeletesupp.c | 2 +-
cpukit/posix/src/shm.c | 3 +-
cpukit/posix/src/shmconfig.c | 34 +++
cpukit/posix/src/shmops.c | 40 +++
cpukit/rtems/src/rtemsobjectgetapiclassname.c | 8 +-
cpukit/rtems/src/tasks.c | 4 +-
cpukit/score/src/objectclose.c | 6 +-
cpukit/score/src/objectgetnameasstring.c | 17 +-
cpukit/score/src/objectidtoname.c | 6 +-
cpukit/score/src/objectinitializeinformation.c | 4 +-
cpukit/score/src/objectnamespaceremove.c | 34 +--
cpukit/score/src/objectnametoidstring.c | 2 -
cpukit/score/src/objectsetname.c | 12 +-
cpukit/score/src/thread.c | 12 +-
cpukit/score/src/threaditerate.c | 2 -
cpukit/score/src/threadrestart.c | 16 --
cpukit/score/src/wkspace.c | 5 +-
testsuites/libtests/Makefile.am | 47 ++++
testsuites/psxtests/Makefile.am | 102 -------
testsuites/psxtests/psx07/init.c | 2 +
testsuites/psxtests/psxcleanup/system.h | 1 -
testsuites/psxtests/psxconfig01/init.c | 7 +-
testsuites/psxtests/psxmsgq01/init.c | 3 +-
testsuites/psxtests/psxmsgq01/system.h | 2 +
testsuites/psxtmtests/Makefile.am | 98 -------
testsuites/psxtmtests/psxtmmq01/init.c | 2 +
testsuites/smptests/Makefile.am | 6 -
testsuites/sptests/spmutex01/init.c | 58 ++--
testsuites/sptests/spstdthreads01/init.c | 7 -
testsuites/sptests/spsysinit01/init.c | 35 +--
testsuites/sptests/spthreadq01/init.c | 31 +--
69 files changed, 734 insertions(+), 840 deletions(-)
create mode 100644 cpukit/posix/src/mqueueconfig.c
create mode 100644 cpukit/posix/src/psignalconfig.c
create mode 100644 cpukit/posix/src/psxsemaphoreconfig.c
create mode 100644 cpukit/posix/src/psxtimerconfig.c
create mode 100644 cpukit/posix/src/pthreadconfig.c
create mode 100644 cpukit/posix/src/shmconfig.c
create mode 100644 cpukit/posix/src/shmops.c
2.16.4
