[PATCH 06/14] posix: Provide named semaphores by default
Mon Oct 29 09:03:15 UTC 2018
Update #2514.
 cpukit/Makefile.am                            | 12 ++---
 cpukit/include/rtems/confdefs.h               | 77 ++++++++++++++-------------
 cpukit/rtems/src/rtemsobjectgetapiclassname.c |  8 +--
 3 files changed, 50 insertions(+), 47 deletions(-)
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 71afecfdc2..3d9bead51a 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -551,7 +551,9 @@ librtemscpu_a_SOURCES += posix/src/pspindestroy.c
 librtemscpu_a_SOURCES += posix/src/pspininit.c
 librtemscpu_a_SOURCES += posix/src/pspinlock.c
 librtemscpu_a_SOURCES += posix/src/pspinunlock.c
+librtemscpu_a_SOURCES += posix/src/psxnametoid.c
 librtemscpu_a_SOURCES += posix/src/psxpriorityisvalid.c
+librtemscpu_a_SOURCES += posix/src/psxsemaphore.c
 librtemscpu_a_SOURCES += posix/src/psxsemaphoreconfig.c
 librtemscpu_a_SOURCES += posix/src/psxtimerconfig.c
 librtemscpu_a_SOURCES += posix/src/psxtransschedparam.c
@@ -605,12 +607,16 @@ librtemscpu_a_SOURCES += posix/src/sched_rr_get_interval.c
 librtemscpu_a_SOURCES += posix/src/sched_setparam.c
 librtemscpu_a_SOURCES += posix/src/sched_setscheduler.c
 librtemscpu_a_SOURCES += posix/src/sched_yield.c
+librtemscpu_a_SOURCES += posix/src/semaphoredeletesupp.c
+librtemscpu_a_SOURCES += posix/src/semclose.c
 librtemscpu_a_SOURCES += posix/src/semdestroy.c
 librtemscpu_a_SOURCES += posix/src/semgetvalue.c
 librtemscpu_a_SOURCES += posix/src/seminit.c
+librtemscpu_a_SOURCES += posix/src/semopen.c
 librtemscpu_a_SOURCES += posix/src/sempost.c
 librtemscpu_a_SOURCES += posix/src/semtimedwait.c
 librtemscpu_a_SOURCES += posix/src/semtrywait.c
+librtemscpu_a_SOURCES += posix/src/semunlink.c
 librtemscpu_a_SOURCES += posix/src/semwait.c
 librtemscpu_a_SOURCES += posix/src/setcancelstate.c
 librtemscpu_a_SOURCES += posix/src/setcanceltype.c
@@ -1055,9 +1061,7 @@ librtemscpu_a_SOURCES += posix/src/psignalclearprocesssignals.c
 librtemscpu_a_SOURCES += posix/src/psignalclearsignals.c
 librtemscpu_a_SOURCES += posix/src/psignalsetprocesssignals.c
 librtemscpu_a_SOURCES += posix/src/psignalunblockthread.c
-librtemscpu_a_SOURCES += posix/src/psxnametoid.c
-librtemscpu_a_SOURCES += posix/src/psxsemaphore.c
 librtemscpu_a_SOURCES += posix/src/psxtimercreate.c
 librtemscpu_a_SOURCES += posix/src/psxtimerdelete.c
 librtemscpu_a_SOURCES += posix/src/pthread.c
@@ -1069,10 +1073,6 @@ librtemscpu_a_SOURCES += posix/src/pthreadsetschedparam.c
 librtemscpu_a_SOURCES += posix/src/pthreadsetschedprio.c
 librtemscpu_a_SOURCES += posix/src/pthreadsigmask.c
 librtemscpu_a_SOURCES += posix/src/ptimer.c
-librtemscpu_a_SOURCES += posix/src/semaphoredeletesupp.c
-librtemscpu_a_SOURCES += posix/src/semclose.c
-librtemscpu_a_SOURCES += posix/src/semopen.c
-librtemscpu_a_SOURCES += posix/src/semunlink.c
 librtemscpu_a_SOURCES += posix/src/setitimer.c
 librtemscpu_a_SOURCES += posix/src/shm.c
 librtemscpu_a_SOURCES += posix/src/shmheap.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index aa3d23e80c..a38cdec8c0 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -32,6 +32,10 @@
 #include <rtems/score/userextimpl.h>
+#include <rtems/posix/key.h>
+#include <rtems/posix/semaphore.h>
+#include <limits.h>
 #ifdef CONFIGURE_DISABLE_BSP_SETTINGS
   #undef BSP_DEFAULT_UNIFIED_WORK_AREAS
@@ -1932,6 +1936,10 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
       rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
   #endif
+  #if !defined(CONFIGURE_MAXIMUM_POSIX_SEMAPHORES)
+    #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
+      rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
+  #endif
   #ifdef RTEMS_POSIX_API
     #if !defined(CONFIGURE_MAXIMUM_POSIX_THREADS)
@@ -1952,10 +1960,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES \
     #endif
-    #if !defined(CONFIGURE_MAXIMUM_POSIX_SEMAPHORES)
-      #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
-        rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-    #endif
     #if !defined(CONFIGURE_MAXIMUM_POSIX_SHMS)
       #define CONFIGURE_MAXIMUM_POSIX_SHMS \
@@ -2256,8 +2260,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
-#include <rtems/posix/key.h>
  * This configuration parameter specifies the maximum number of
  * POSIX API keys.
@@ -2296,6 +2298,31 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       _Configure_Max_Objects(_key_value_pairs) \
         * sizeof(POSIX_Keys_Key_value_pair)))
+ * Account for the object control structures plus the name
+ * of the object to be duplicated.
+#define _Configure_POSIX_Named_Object_RAM(_number, _size) \
+  (_Configure_Object_RAM(_number, _size) \
+    + _Configure_Max_Objects(_number) \
+      * _Configure_From_workspace(_POSIX_PATH_MAX + 1))
+ * This configuration parameter specifies the maximum number of
+ * POSIX API semaphores.
+#ifndef CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+  #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 0
+#endif
+ * This macro is calculated to specify the memory required for
+#define _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES(_semaphores) \
+  _Configure_POSIX_Named_Object_RAM( \
+     _semaphores, sizeof(POSIX_Semaphore_Control) )
  *  The rest of the POSIX threads API features are only available when
  *  POSIX is enabled.
@@ -2303,25 +2330,14 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #include <sys/types.h>
   #include <signal.h>
-  #include <limits.h>
   #include <mqueue.h>
   #include <rtems/posix/mqueue.h>
   #include <rtems/posix/psignal.h>
   #include <rtems/posix/pthread.h>
-  #include <rtems/posix/semaphore.h>
   #include <rtems/posix/shm.h>
   #include <rtems/posix/threadsup.h>
   #include <rtems/posix/timer.h>
-   * Account for the object control structures plus the name
-   * of the object to be duplicated.
-  #define _Configure_POSIX_Named_Object_RAM(_number, _size) \
-    (_Configure_Object_RAM(_number, _size) \
-      + _Configure_Max_Objects(_number) \
-        * _Configure_From_workspace(_POSIX_PATH_MAX + 1))
    * POSIX API threads.
@@ -2377,22 +2393,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
        _message_queues, sizeof(POSIX_Message_queue_Control) )
-   * This configuration parameter specifies the maximum number of
-   * POSIX API semaphores.
-  #ifndef CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-    #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 0
-  #endif
-   * This macro is calculated to specify the memory required for
-  #define _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES(_semaphores) \
-    _Configure_POSIX_Named_Object_RAM( \
-       _semaphores, sizeof(POSIX_Semaphore_Control) )
    * Configure the maximum number of POSIX shared memory objects.
@@ -2559,8 +2559,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
         CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS) + \
       _CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES( \
         CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) + \
-      _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
-        CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \
       _CONFIGURE_MEMORY_FOR_POSIX_SHMS( \
         CONFIGURE_MAXIMUM_POSIX_SHMS) + \
       _CONFIGURE_MEMORY_FOR_POSIX_TIMERS(CONFIGURE_MAXIMUM_POSIX_TIMERS))
@@ -2721,6 +2719,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
    _CONFIGURE_MEMORY_FOR_POSIX_KEYS( \
       _CONFIGURE_POSIX_KEYS, \
       CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ) + \
+   _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
+     CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \
    _CONFIGURE_MEMORY_FOR_POSIX + \
    _CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \
    _CONFIGURE_MEMORY_FOR_MP + \
@@ -3219,12 +3219,14 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     /* POSIX API managers that are always enabled */
     uint32_t POSIX_KEYS;
-#ifdef RTEMS_POSIX_API
     /* POSIX API Pieces */
+#ifdef RTEMS_POSIX_API
     uint32_t POSIX_TIMERS;
     uint32_t POSIX_QUEUED_SIGNALS;
     uint32_t POSIX_MESSAGE_QUEUES;
+#endif
     uint32_t POSIX_SEMAPHORES;
     uint32_t POSIX_SHMS;
 #endif
@@ -3272,7 +3274,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS ),
       CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES ),
+#endif
     _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
     _CONFIGURE_MEMORY_FOR_POSIX_SHMS( CONFIGURE_MAXIMUM_POSIX_SHMS ),
     _CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
 #endif
@@ -3340,7 +3344,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
        (CONFIGURE_MAXIMUM_POSIX_TIMERS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES != 0) || \
-       (CONFIGURE_MAXIMUM_POSIX_SEMAPHORES != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_SHMS != 0) || \
       defined(CONFIGURE_POSIX_INIT_THREAD_TABLE))
   #error "CONFIGURATION ERROR: POSIX API support not configured!!"
diff --git a/cpukit/rtems/src/rtemsobjectgetapiclassname.c b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
index b1cc161c9e..6b90897389 100644
--- a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
+++ b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
@@ -42,18 +42,20 @@ static const rtems_assoc_t rtems_object_api_classic_assoc[] = {
   { NULL,                      0, 0}
 static const rtems_assoc_t rtems_object_api_posix_assoc[] = {
   { "Thread",                  OBJECTS_POSIX_THREADS, 0},
   { "Key",                     OBJECTS_POSIX_KEYS, 0},
   { "Interrupt",               OBJECTS_POSIX_INTERRUPTS, 0},
   { "Message Queue",           OBJECTS_POSIX_MESSAGE_QUEUES, 0},
+#endif
   { "Semaphore",               OBJECTS_POSIX_SEMAPHORES, 0},
   { "Timer",                   OBJECTS_POSIX_TIMERS, 0},
   { "Shared Memory",           OBJECTS_POSIX_SHMS, 0},
+#endif
   { NULL,                      0, 0}
-#endif
 const char *rtems_object_get_api_class_name(
   int the_api,
@@ -67,10 +69,8 @@ const char *rtems_object_get_api_class_name(
     api_assoc = rtems_object_api_internal_assoc;
   else if ( the_api == OBJECTS_CLASSIC_API )
     api_assoc = rtems_object_api_classic_assoc;
   else if ( the_api == OBJECTS_POSIX_API )
     api_assoc = rtems_object_api_posix_assoc;
-#endif
   else
     return "BAD API";
   class_assoc = rtems_assoc_ptr_by_local( api_assoc, the_class );
2.16.4
