[PATCH 05/14] posix: Split posix_api_configuration_table
Mon Oct 29 09:03:14 UTC 2018
Use separate configuration variables to avoid false dependencies.
Update #2514.
 cpukit/Makefile.am                     |  6 +++
 cpukit/include/rtems/confdefs.h        | 95 +++++++++++++++++-----------------
 cpukit/include/rtems/posix/config.h    | 66 ++---------------------
 cpukit/include/rtems/posix/mqueue.h    |  2 +
 cpukit/include/rtems/posix/psignal.h   |  2 +
 cpukit/include/rtems/posix/pthread.h   |  3 +-
 cpukit/include/rtems/posix/semaphore.h |  2 +
 cpukit/include/rtems/posix/shm.h       |  4 ++
 cpukit/include/rtems/posix/timer.h     |  2 +
 cpukit/posix/src/mqueue.c              |  3 +-
 cpukit/posix/src/mqueueconfig.c        | 34 ++++++++++++
 cpukit/posix/src/psignal.c             |  2 +-
 cpukit/posix/src/psignalconfig.c       | 34 ++++++++++++
 cpukit/posix/src/psxsemaphore.c        |  3 +-
 cpukit/posix/src/psxsemaphoreconfig.c  | 34 ++++++++++++
 cpukit/posix/src/psxtimerconfig.c      | 34 ++++++++++++
 cpukit/posix/src/pthread.c             |  3 +-
 cpukit/posix/src/pthreadconfig.c       | 34 ++++++++++++
 cpukit/posix/src/pthreadinitthreads.c  |  4 +-
 cpukit/posix/src/ptimer.c              |  3 +-
 cpukit/posix/src/shm.c                 |  3 +-
 cpukit/posix/src/shmconfig.c           | 34 ++++++++++++
 cpukit/score/src/wkspace.c             |  3 +-
 23 files changed, 284 insertions(+), 126 deletions(-)
 create mode 100644 cpukit/posix/src/mqueueconfig.c
 create mode 100644 cpukit/posix/src/psignalconfig.c
 create mode 100644 cpukit/posix/src/psxsemaphoreconfig.c
 create mode 100644 cpukit/posix/src/psxtimerconfig.c
 create mode 100644 cpukit/posix/src/pthreadconfig.c
 create mode 100644 cpukit/posix/src/shmconfig.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 5e1fdbd240..71afecfdc2 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -509,6 +509,7 @@ librtemscpu_a_SOURCES += posix/src/lio_listio.c
 librtemscpu_a_SOURCES += posix/src/mlockall.c
 librtemscpu_a_SOURCES += posix/src/mlock.c
 librtemscpu_a_SOURCES += posix/src/mprotect.c
+librtemscpu_a_SOURCES += posix/src/mqueueconfig.c
 librtemscpu_a_SOURCES += posix/src/msync.c
 librtemscpu_a_SOURCES += posix/src/munlockall.c
 librtemscpu_a_SOURCES += posix/src/munlock.c
@@ -545,11 +546,14 @@ librtemscpu_a_SOURCES += posix/src/prwlocktryrdlock.c
 librtemscpu_a_SOURCES += posix/src/prwlocktrywrlock.c
 librtemscpu_a_SOURCES += posix/src/prwlockunlock.c
 librtemscpu_a_SOURCES += posix/src/prwlockwrlock.c
+librtemscpu_a_SOURCES += posix/src/psignalconfig.c
 librtemscpu_a_SOURCES += posix/src/pspindestroy.c
 librtemscpu_a_SOURCES += posix/src/pspininit.c
 librtemscpu_a_SOURCES += posix/src/pspinlock.c
 librtemscpu_a_SOURCES += posix/src/pspinunlock.c
 librtemscpu_a_SOURCES += posix/src/psxpriorityisvalid.c
+librtemscpu_a_SOURCES += posix/src/psxsemaphoreconfig.c
+librtemscpu_a_SOURCES += posix/src/psxtimerconfig.c
 librtemscpu_a_SOURCES += posix/src/psxtransschedparam.c
 librtemscpu_a_SOURCES += posix/src/pthreadatfork.c
 librtemscpu_a_SOURCES += posix/src/pthreadattrdefault.c
@@ -576,6 +580,7 @@ librtemscpu_a_SOURCES += posix/src/pthreadattrsetstackaddr.c
 librtemscpu_a_SOURCES += posix/src/pthreadattrsetstack.c
 librtemscpu_a_SOURCES += posix/src/pthreadattrsetstacksize.c
 librtemscpu_a_SOURCES += posix/src/pthreadconcurrency.c
+librtemscpu_a_SOURCES += posix/src/pthreadconfig.c
 librtemscpu_a_SOURCES += posix/src/pthreaddetach.c
 librtemscpu_a_SOURCES += posix/src/pthreadequal.c
 librtemscpu_a_SOURCES += posix/src/pthreadexit.c
@@ -609,6 +614,7 @@ librtemscpu_a_SOURCES += posix/src/semtrywait.c
 librtemscpu_a_SOURCES += posix/src/semwait.c
 librtemscpu_a_SOURCES += posix/src/setcancelstate.c
 librtemscpu_a_SOURCES += posix/src/setcanceltype.c
+librtemscpu_a_SOURCES += posix/src/shmconfig.c
 librtemscpu_a_SOURCES += posix/src/sigaddset.c
 librtemscpu_a_SOURCES += posix/src/sigdelset.c
 librtemscpu_a_SOURCES += posix/src/sigemptyset.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 8323674f12..aa3d23e80c 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -96,13 +96,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   extern rtems_multiprocessing_table      Multiprocessing_configuration;
 #endif
-#ifdef RTEMS_POSIX_API
-   * This it the POSIX API configuration table.
-  extern posix_api_configuration_table    Configuration_POSIX_API;
-#endif
  * This macro determines whether the RTEMS reentrancy support for
  * the Newlib C Library is enabled.
@@ -2426,18 +2419,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #define _CONFIGURE_MEMORY_FOR_POSIX_SHMS(_shms) \
     _Configure_POSIX_Named_Object_RAM(_shms, sizeof(POSIX_Shm_Control) )
   #ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
-    #ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-       *  The user is defining their own table information and setting the
-       *  appropriate variables for the POSIX Initialization Thread Table.
-    #else
+    #ifndef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
       #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
         #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT   POSIX_Init
       #endif
@@ -2449,35 +2432,28 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #ifdef CONFIGURE_INIT
         posix_initialization_threads_table POSIX_Initialization_threads[] = {
-          { CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT, \
-              CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE }
+          { CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT,
+            CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE }
       #endif
       #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME \
-              POSIX_Initialization_threads
+        POSIX_Initialization_threads
       #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE \
-              RTEMS_ARRAY_SIZE(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME)
-    #endif    /* CONFIGURE_POSIX_HAS_OWN_INIT_TASK_TABLE */
-  #else     /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
+        RTEMS_ARRAY_SIZE(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME)
+    #endif /* !CONFIGURE_POSIX_HAS_OWN_INIT_TASK_TABLE */
+  #else /* !CONFIGURE_POSIX_INIT_THREAD_TABLE */
     #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME NULL
     #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE 0
-  #endif
+  #endif /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
 #else
    * This configuration parameter specifies the maximum number of
    * POSIX API threads.
   #define CONFIGURE_MAXIMUM_POSIX_THREADS         0
-#endif    /* RTEMS_POSIX_API */
+#endif /* RTEMS_POSIX_API */
  * This configuration parameter specifies the stack size of the
@@ -3006,25 +2982,48 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     CONFIGURE_INIT_TASK_TABLE
+  #if CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES > 0
+    const uint32_t _Configuration_POSIX_Maximum_message_queues =
+      CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES;
+  #endif
+  #if CONFIGURE_MAXIMUM_POSIX_SEMAPHORES > 0
+    const uint32_t _Configuration_POSIX_Maximum_named_semaphores =
+      CONFIGURE_MAXIMUM_POSIX_SEMAPHORES;
+  #endif
+  #if CONFIGURE_MAXIMUM_POSIX_SHMS > 0
+    const uint32_t _Configuration_POSIX_Maximum_shms =
+      CONFIGURE_MAXIMUM_POSIX_SHMS;
+  #endif
+  #if _CONFIGURE_POSIX_THREADS > 0
+    const uint32_t _Configuration_POSIX_Maximum_threads =
+      _CONFIGURE_POSIX_THREADS;
+  #endif
-     * This is the POSIX API Configuration Table.
-    posix_api_configuration_table Configuration_POSIX_API = {
-      _CONFIGURE_POSIX_THREADS,
-      CONFIGURE_MAXIMUM_POSIX_TIMERS,
-      CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS,
-      CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES,
-      CONFIGURE_MAXIMUM_POSIX_SEMAPHORES,
-      CONFIGURE_MAXIMUM_POSIX_SHMS,
-      CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
-      CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME
+    #if CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS > 0
+      const uint32_t _Configuration_POSIX_Maximum_queued_signals =
+        CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS;
+    #endif
-    const size_t _Configuration_POSIX_Minimum_stack_size =
-      CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE;
+    #if CONFIGURE_MAXIMUM_POSIX_TIMERS > 0
+      const uint32_t _Configuration_POSIX_Maximum_timers =
+        CONFIGURE_MAXIMUM_POSIX_TIMERS;
+    #endif
+    posix_initialization_threads_table * const
+      _Configuration_POSIX_Initialization_threads =
+        CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME;
+    const size_t _Configuration_POSIX_Initialization_thread_count =
+      CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE;
   #endif
+  const size_t _Configuration_POSIX_Minimum_stack_size =
+    CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE;
    * This variable specifies the minimum stack size for tasks in an RTEMS
    * application.
diff --git a/cpukit/include/rtems/posix/config.h b/cpukit/include/rtems/posix/config.h
index e90dc27011..e6b5870ac7 100644
--- a/cpukit/include/rtems/posix/config.h
+++ b/cpukit/include/rtems/posix/config.h
@@ -46,70 +46,10 @@ typedef struct {
   int       stack_size;
 } posix_initialization_threads_table;
- *  The following records define the POSIX Configuration Table.
- *  The information contained in this table is required in all
- *  RTEMS systems which include POSIX threads support, whether
- *  single or multiprocessor.  This table primarily defines the
- *  following:
- *     + required number of each object type
-typedef struct {
-   * This field contains the maximum number of POSIX API
-   * threads which are configured for this application.
-  uint32_t                            maximum_threads;
-   * timers which are configured for this application.
-  uint32_t                            maximum_timers;
-   * queued signals which are configured for this application.
-  uint32_t                            maximum_queued_signals;
-   * message queues which are configured for this application.
-  uint32_t                            maximum_message_queues;
+extern posix_initialization_threads_table * const
+  _Configuration_POSIX_Initialization_threads;
-   * semaphores which are configured for this application.
-  uint32_t                            maximum_semaphores;
-   * Maximum configured number of POSIX Shared memory objects.
-  uint32_t                            maximum_shms;
-   * This field contains the number of POSIX API Initialization
-   * threads listed in @a User_initialization_thread_table.
-  uint32_t                            number_of_initialization_threads;
-   * This field contains the list of POSIX API Initialization threads.
-  posix_initialization_threads_table *User_initialization_threads_table;
-} posix_api_configuration_table;
- * @brief POSIX API configuration table.
- * This is the POSIX API Configuration Table expected to be generated
- * by confdefs.h.
-extern posix_api_configuration_table Configuration_POSIX_API;
+extern const size_t _Configuration_POSIX_Initialization_thread_count;
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/posix/mqueue.h b/cpukit/include/rtems/posix/mqueue.h
index cdf94514af..6211c68783 100644
--- a/cpukit/include/rtems/posix/mqueue.h
+++ b/cpukit/include/rtems/posix/mqueue.h
@@ -61,6 +61,8 @@ typedef struct {
    int                         oflag;
 }  POSIX_Message_queue_Control;
+extern const uint32_t _Configuration_POSIX_Maximum_message_queues;
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/posix/psignal.h b/cpukit/include/rtems/posix/psignal.h
index ed98442e32..52a9ec6caf 100644
--- a/cpukit/include/rtems/posix/psignal.h
+++ b/cpukit/include/rtems/posix/psignal.h
@@ -31,5 +31,7 @@ typedef struct {
   siginfo_t   Info;
 }  POSIX_signals_Siginfo_node;
+extern const uint32_t _Configuration_POSIX_Maximum_queued_signals;
 #endif
 /* end of file */
diff --git a/cpukit/include/rtems/posix/pthread.h b/cpukit/include/rtems/posix/pthread.h
index bf46253776..25bf40ef27 100644
--- a/cpukit/include/rtems/posix/pthread.h
+++ b/cpukit/include/rtems/posix/pthread.h
@@ -19,7 +19,6 @@
 #ifndef _RTEMS_POSIX_PTHREAD_H
 #define _RTEMS_POSIX_PTHREAD_H
-#include <rtems/posix/config.h>
 #include <rtems/posix/threadsup.h>
@@ -39,6 +38,8 @@ extern "C" {
 extern const size_t _Configuration_POSIX_Minimum_stack_size;
+extern const uint32_t _Configuration_POSIX_Maximum_threads;
  * @brief POSIX threads initialize user threads body.
diff --git a/cpukit/include/rtems/posix/semaphore.h b/cpukit/include/rtems/posix/semaphore.h
index 9133db22be..734d8bb84b 100644
--- a/cpukit/include/rtems/posix/semaphore.h
+++ b/cpukit/include/rtems/posix/semaphore.h
@@ -46,6 +46,8 @@ typedef struct {
    uint32_t        open_count;
 }  POSIX_Semaphore_Control;
+extern const uint32_t _Configuration_POSIX_Maximum_named_semaphores;
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/posix/shm.h b/cpukit/include/rtems/posix/shm.h
index d2b6036493..310af6692b 100644
--- a/cpukit/include/rtems/posix/shm.h
+++ b/cpukit/include/rtems/posix/shm.h
@@ -18,6 +18,8 @@
 #include <rtems/score/threadq.h>
+#include <sys/types.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -124,6 +126,8 @@ typedef struct {
    time_t               ctime;
 } POSIX_Shm_Control;
+extern const uint32_t _Configuration_POSIX_Maximum_shms;
  * @brief object_create operation for shm objects stored in RTEMS Workspace.
diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
index 79fe093219..52732af991 100644
--- a/cpukit/include/rtems/posix/timer.h
+++ b/cpukit/include/rtems/posix/timer.h
@@ -50,6 +50,8 @@ typedef struct {
   struct timespec   time;       /* Time at which the timer was started   */
 } POSIX_Timer_Control;
+extern const uint32_t _Configuration_POSIX_Maximum_timers;
 #ifdef __cplusplus
diff --git a/cpukit/posix/src/mqueue.c b/cpukit/posix/src/mqueue.c
index 2ad90c1e79..e2c9b5f2b2 100644
--- a/cpukit/posix/src/mqueue.c
+++ b/cpukit/posix/src/mqueue.c
@@ -51,8 +51,7 @@ static void _POSIX_Message_queue_Manager_initialization(void)
     &_POSIX_Message_queue_Information, /* object information table */
     OBJECTS_POSIX_API,                 /* object API */
     OBJECTS_POSIX_MESSAGE_QUEUES,      /* object class */
-    Configuration_POSIX_API.maximum_message_queues,
-                                /* maximum objects of this class */
+    _Configuration_POSIX_Maximum_message_queues,
     sizeof( POSIX_Message_queue_Control ),
                                 /* size of this object's control block */
     true,                       /* true if names for this object are strings */
diff --git a/cpukit/posix/src/mqueueconfig.c b/cpukit/posix/src/mqueueconfig.c
new file mode 100644
index 0000000000..921fb73772
--- /dev/null
+++ b/cpukit/posix/src/mqueueconfig.c
@@ -0,0 +1,34 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright 2018, embedded brains GmbH <rtems at embedded-brains.de>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/posix/mqueue.h>
+const uint32_t _Configuration_POSIX_Maximum_message_queues;
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index 3e887a8ed0..0d61a1d737 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -103,7 +103,7 @@ static void _POSIX_signals_Manager_Initialization(void)
   uint32_t   signo;
-  maximum_queued_signals = Configuration_POSIX_API.maximum_queued_signals;
+  maximum_queued_signals = _Configuration_POSIX_Maximum_queued_signals;
   memcpy(
     _POSIX_signals_Vectors,
diff --git a/cpukit/posix/src/psignalconfig.c b/cpukit/posix/src/psignalconfig.c
index 0000000000..0840d94b16
--- /dev/null
+++ b/cpukit/posix/src/psignalconfig.c
@@ -0,0 +1,34 @@
+ * are met:
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/posix/psignal.h>
+const uint32_t _Configuration_POSIX_Maximum_queued_signals;
diff --git a/cpukit/posix/src/psxsemaphore.c b/cpukit/posix/src/psxsemaphore.c
index a82ad17966..9e259b8ea3 100644
--- a/cpukit/posix/src/psxsemaphore.c
+++ b/cpukit/posix/src/psxsemaphore.c
@@ -42,8 +42,7 @@ static void _POSIX_Semaphore_Manager_initialization(void)
     &_POSIX_Semaphore_Information, /* object information table */
     OBJECTS_POSIX_SEMAPHORES,   /* object class */
-    Configuration_POSIX_API.maximum_semaphores,
+    _Configuration_POSIX_Maximum_named_semaphores,
     sizeof( POSIX_Semaphore_Control ),
diff --git a/cpukit/posix/src/psxsemaphoreconfig.c b/cpukit/posix/src/psxsemaphoreconfig.c
index 0000000000..7e29742537
--- /dev/null
+++ b/cpukit/posix/src/psxsemaphoreconfig.c
@@ -0,0 +1,34 @@
+ * are met:
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/posix/semaphore.h>
+const uint32_t _Configuration_POSIX_Maximum_named_semaphores;
diff --git a/cpukit/posix/src/psxtimerconfig.c b/cpukit/posix/src/psxtimerconfig.c
index 0000000000..2781a8cec5
--- /dev/null
+++ b/cpukit/posix/src/psxtimerconfig.c
@@ -0,0 +1,34 @@
+ * are met:
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/posix/timer.h>
+const uint32_t _Configuration_POSIX_Maximum_timers;
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 7d1674694f..da31252063 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -181,8 +181,7 @@ static void _POSIX_Threads_Manager_initialization(void)
     &_POSIX_Threads_Information, /* object information table */
     OBJECTS_POSIX_THREADS,       /* object class */
-    Configuration_POSIX_API.maximum_threads
+    _Configuration_POSIX_Maximum_threads
diff --git a/cpukit/posix/src/pthreadconfig.c b/cpukit/posix/src/pthreadconfig.c
index 0000000000..75683c3c6e
--- /dev/null
+++ b/cpukit/posix/src/pthreadconfig.c
@@ -0,0 +1,34 @@
+ * are met:
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/posix/pthread.h>
+const uint32_t _Configuration_POSIX_Maximum_threads;
diff --git a/cpukit/posix/src/pthreadinitthreads.c b/cpukit/posix/src/pthreadinitthreads.c
index 15c6b9fbf9..97ae5df70a 100644
--- a/cpukit/posix/src/pthreadinitthreads.c
+++ b/cpukit/posix/src/pthreadinitthreads.c
@@ -41,8 +41,8 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
   pthread_t                           thread_id;
   pthread_attr_t                      attr;
-  user_threads = Configuration_POSIX_API.User_initialization_threads_table;
-  maximum      = Configuration_POSIX_API.number_of_initialization_threads;
+  user_threads = _Configuration_POSIX_Initialization_threads;
+  maximum      = _Configuration_POSIX_Initialization_thread_count;
   if ( !user_threads )
     return;
diff --git a/cpukit/posix/src/ptimer.c b/cpukit/posix/src/ptimer.c
index e938d50058..9472cd49e5 100644
--- a/cpukit/posix/src/ptimer.c
+++ b/cpukit/posix/src/ptimer.c
@@ -62,8 +62,7 @@ static void _POSIX_Timer_Manager_initialization(void)
     &_POSIX_Timer_Information,  /* object information table */
     OBJECTS_POSIX_TIMERS,       /* object class */
-    Configuration_POSIX_API.maximum_timers,
+    _Configuration_POSIX_Maximum_timers,
     sizeof( POSIX_Timer_Control ),
     false,                      /* true if names for this object are strings */
diff --git a/cpukit/posix/src/shm.c b/cpukit/posix/src/shm.c
index d76b5b8569..131aa1384b 100644
--- a/cpukit/posix/src/shm.c
+++ b/cpukit/posix/src/shm.c
@@ -32,8 +32,7 @@ static void _POSIX_Shm_Manager_initialization( void )
     &_POSIX_Shm_Information,    /* object information table */
     OBJECTS_POSIX_SHMS,         /* object class */
-    Configuration_POSIX_API.maximum_shms,
+    _Configuration_POSIX_Maximum_shms,
     sizeof( POSIX_Shm_Control ),
diff --git a/cpukit/posix/src/shmconfig.c b/cpukit/posix/src/shmconfig.c
index 0000000000..e03f4e8be5
--- /dev/null
+++ b/cpukit/posix/src/shmconfig.c
@@ -0,0 +1,34 @@
+ * are met:
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/posix/shm.h>
+const uint32_t _Configuration_POSIX_Maximum_shms;
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index ea2ab84849..2657ba0dda 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -25,6 +25,7 @@
 #include <rtems/score/percpudata.h>
 #include <rtems/score/tls.h>
 #include <rtems/config.h>
@@ -54,7 +55,7 @@ static uint32_t _Workspace_Get_maximum_thread_count( void )
 #if defined(RTEMS_POSIX_API)
   thread_count += rtems_resource_maximum_per_allocation(
 #endif
2.16.4
