[PATCH 10/14] posix: Provide threads by default
Mon Oct 29 09:03:19 UTC 2018
Update #2514.
 cpukit/Makefile.am                            |  14 +--
 cpukit/include/rtems/confdefs.h               | 123 ++++++++++++--------------
 cpukit/include/rtems/monitor.h                |   4 +-
 cpukit/include/rtems/posix/pthreadattrimpl.h  |   2 -
 cpukit/include/rtems/score/thread.h           |  10 +--
 cpukit/libcsupport/src/resource_snapshot.c    |  30 +------
 cpukit/libmisc/monitor/mon-monitor.c          |   4 -
 cpukit/libmisc/monitor/mon-object.c           |   8 +-
 cpukit/posix/src/psxtransschedparam.c         |   6 +-
 cpukit/posix/src/pthread.c                    |  10 ++-
 cpukit/posix/src/pthreadcreate.c              |  14 +--
 cpukit/posix/src/pthreadsetschedparam.c       |  16 +++-
 cpukit/rtems/src/rtemsobjectgetapiclassname.c |   2 +-
 cpukit/score/src/threaditerate.c              |   2 -
 cpukit/score/src/threadrestart.c              |  16 ----
 cpukit/score/src/wkspace.c                    |   2 -
 16 files changed, 106 insertions(+), 157 deletions(-)
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index a8f78ead9c..b0d9088d44 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -470,6 +470,7 @@ librtemscpu_a_SOURCES += libmd/md5.c
 librtemscpu_a_SOURCES += libstdthreads/call_once.c
 librtemscpu_a_SOURCES += libstdthreads/cnd.c
 librtemscpu_a_SOURCES += libstdthreads/mtx.c
+librtemscpu_a_SOURCES += libstdthreads/thrd.c
 librtemscpu_a_SOURCES += libstdthreads/tss.c
 librtemscpu_a_SOURCES += posix/src/adjtime.c
 librtemscpu_a_SOURCES += posix/src/aio_suspend.c
@@ -596,8 +597,10 @@ librtemscpu_a_SOURCES += posix/src/pthreadattrsetscope.c
 librtemscpu_a_SOURCES += posix/src/pthreadattrsetstackaddr.c
 librtemscpu_a_SOURCES += posix/src/pthreadattrsetstack.c
 librtemscpu_a_SOURCES += posix/src/pthreadattrsetstacksize.c
+librtemscpu_a_SOURCES += posix/src/pthread.c
 librtemscpu_a_SOURCES += posix/src/pthreadconcurrency.c
 librtemscpu_a_SOURCES += posix/src/pthreadconfig.c
+librtemscpu_a_SOURCES += posix/src/pthreadcreate.c
 librtemscpu_a_SOURCES += posix/src/pthreaddetach.c
 librtemscpu_a_SOURCES += posix/src/pthreadequal.c
 librtemscpu_a_SOURCES += posix/src/pthreadexit.c
@@ -606,10 +609,14 @@ librtemscpu_a_SOURCES += posix/src/pthreadgetattrnp.c
 librtemscpu_a_SOURCES += posix/src/pthreadgetcpuclockid.c
 librtemscpu_a_SOURCES += posix/src/pthreadgetnamenp.c
 librtemscpu_a_SOURCES += posix/src/pthreadgetschedparam.c
+librtemscpu_a_SOURCES += posix/src/pthreadinitthreads.c
+librtemscpu_a_SOURCES += posix/src/pthreadjoin.c
 librtemscpu_a_SOURCES += posix/src/pthreadonce.c
 librtemscpu_a_SOURCES += posix/src/pthreadself.c
 librtemscpu_a_SOURCES += posix/src/pthreadsetaffinitynp.c
 librtemscpu_a_SOURCES += posix/src/pthreadsetnamenp.c
+librtemscpu_a_SOURCES += posix/src/pthreadsetschedparam.c
+librtemscpu_a_SOURCES += posix/src/pthreadsetschedprio.c
 librtemscpu_a_SOURCES += posix/src/rwlockattrdestroy.c
 librtemscpu_a_SOURCES += posix/src/rwlockattrgetpshared.c
 librtemscpu_a_SOURCES += posix/src/rwlockattrinit.c
@@ -1047,7 +1054,6 @@ endif
 if HAS_PTHREADS
-librtemscpu_a_SOURCES += libstdthreads/thrd.c
 librtemscpu_a_SOURCES += posix/src/aio_cancel.c
 librtemscpu_a_SOURCES += posix/src/aio_error.c
 librtemscpu_a_SOURCES += posix/src/aio_fsync.c
@@ -1070,13 +1076,7 @@ librtemscpu_a_SOURCES += posix/src/psignalunblockthread.c
 librtemscpu_a_SOURCES += posix/src/psxpriorityisvalid.c
 librtemscpu_a_SOURCES += posix/src/psxtimercreate.c
 librtemscpu_a_SOURCES += posix/src/psxtimerdelete.c
-librtemscpu_a_SOURCES += posix/src/pthread.c
-librtemscpu_a_SOURCES += posix/src/pthreadcreate.c
-librtemscpu_a_SOURCES += posix/src/pthreadinitthreads.c
-librtemscpu_a_SOURCES += posix/src/pthreadjoin.c
 librtemscpu_a_SOURCES += posix/src/pthreadkill.c
-librtemscpu_a_SOURCES += posix/src/pthreadsetschedparam.c
-librtemscpu_a_SOURCES += posix/src/pthreadsetschedprio.c
 librtemscpu_a_SOURCES += posix/src/pthreadsigmask.c
 librtemscpu_a_SOURCES += posix/src/ptimer.c
 librtemscpu_a_SOURCES += posix/src/setitimer.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index c2c6fe6507..64577b92d7 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -34,6 +34,7 @@
 #include <rtems/posix/key.h>
 #include <rtems/posix/mqueue.h>
+#include <rtems/posix/pthread.h>
 #include <rtems/posix/semaphore.h>
 #include <rtems/posix/shm.h>
@@ -1950,12 +1951,12 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_MAXIMUM_POSIX_SHMS \
       rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
   #endif
+  #if !defined(CONFIGURE_MAXIMUM_POSIX_THREADS)
+    #define CONFIGURE_MAXIMUM_POSIX_THREADS \
+      rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
+  #endif
   #ifdef RTEMS_POSIX_API
-    #if !defined(CONFIGURE_MAXIMUM_POSIX_THREADS)
-      #define CONFIGURE_MAXIMUM_POSIX_THREADS \
-        rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-    #endif
     #if !defined(CONFIGURE_MAXIMUM_POSIX_TIMERS)
       #define CONFIGURE_MAXIMUM_POSIX_TIMERS \
@@ -2300,6 +2301,14 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       _Configure_Max_Objects(_key_value_pairs) \
         * sizeof(POSIX_Keys_Key_value_pair)))
+ * This configuration parameter specifies the maximum number of
+ * POSIX API threads.
+#ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
+  #define CONFIGURE_MAXIMUM_POSIX_THREADS 0
+#endif
  * Account for the object control structures plus the name
  * of the object to be duplicated.
@@ -2363,18 +2372,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #include <sys/types.h>
   #include <signal.h>
   #include <rtems/posix/psignal.h>
-  #include <rtems/posix/pthread.h>
   #include <rtems/posix/threadsup.h>
   #include <rtems/posix/timer.h>
-   * This configuration parameter specifies the maximum number of
-   * POSIX API threads.
-  #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
-    #define CONFIGURE_MAXIMUM_POSIX_THREADS 0
-  #endif
    * POSIX API timers.
@@ -2405,42 +2405,36 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #define _CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS(_queued_signals) \
     _Configure_From_workspace( \
       (_queued_signals) * (sizeof(POSIX_signals_Siginfo_node)) )
+#endif /* RTEMS_POSIX_API */
-  #ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
-    #ifndef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-      #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
-        #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT   POSIX_Init
-      #endif
+#ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
+  #ifndef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+    #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+      #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT   POSIX_Init
+    #endif
-      #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
-        #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
-          CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
-      #endif
+    #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+      #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
+        CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+    #endif
-      #ifdef CONFIGURE_INIT
-        posix_initialization_threads_table POSIX_Initialization_threads[] = {
-          { CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT,
-            CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE }
-      #endif
+    #ifdef CONFIGURE_INIT
+      posix_initialization_threads_table POSIX_Initialization_threads[] = {
+        { CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT,
+          CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE }
+    #endif
-      #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME \
-        POSIX_Initialization_threads
+    #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME \
+      POSIX_Initialization_threads
-      #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE \
-        RTEMS_ARRAY_SIZE(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME)
-    #endif /* !CONFIGURE_POSIX_HAS_OWN_INIT_TASK_TABLE */
-  #else /* !CONFIGURE_POSIX_INIT_THREAD_TABLE */
-    #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME NULL
-    #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE 0
-  #endif /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
-#else
-#endif /* RTEMS_POSIX_API */
+    #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE \
+      RTEMS_ARRAY_SIZE(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME)
+  #endif /* !CONFIGURE_POSIX_HAS_OWN_INIT_TASK_TABLE */
+#else /* !CONFIGURE_POSIX_INIT_THREAD_TABLE */
+  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME NULL
+  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE 0
+#endif /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
  * This configuration parameter specifies the stack size of the
@@ -2736,8 +2730,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * This accounts for any extra memory required by the POSIX API
  * Initialization Thread.
-#if defined(RTEMS_POSIX_API) && \
-    (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE > \
+#if (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE > \
       CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE)
   #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART \
     (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE - \
@@ -2999,13 +2992,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       const uint32_t _Configuration_POSIX_Maximum_timers =
         CONFIGURE_MAXIMUM_POSIX_TIMERS;
     #endif
-    posix_initialization_threads_table * const
-      _Configuration_POSIX_Initialization_threads =
-        CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME;
-    const size_t _Configuration_POSIX_Initialization_thread_count =
-      CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE;
   #endif
   const size_t _Configuration_POSIX_Minimum_stack_size =
@@ -3098,16 +3084,21 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  *  If the user has configured a set of POSIX Initialization Threads,
  *  then we need to install the code that runs that loop.
-#ifdef RTEMS_POSIX_API
-    #if defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) || \
-        defined(CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE)
-      RTEMS_SYSINIT_ITEM(
-        _POSIX_Threads_Initialize_user_threads_body,
-        RTEMS_SYSINIT_POSIX_USER_THREADS,
-        RTEMS_SYSINIT_ORDER_MIDDLE
-    #endif
+#ifdef CONFIGURE_INIT
+  #if defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) || \
+      defined(CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE)
+    posix_initialization_threads_table * const
+      _Configuration_POSIX_Initialization_threads =
+        CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME;
+    const size_t _Configuration_POSIX_Initialization_thread_count =
+      CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE;
+    RTEMS_SYSINIT_ITEM(
+      _POSIX_Threads_Initialize_user_threads_body,
+      RTEMS_SYSINIT_POSIX_USER_THREADS,
+      RTEMS_SYSINIT_ORDER_MIDDLE
   #endif
 #endif
@@ -3323,10 +3314,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  *        CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS  are not in this list.
 #if !defined(RTEMS_POSIX_API)
-  #if ((CONFIGURE_MAXIMUM_POSIX_THREADS != 0) || \
-       (CONFIGURE_MAXIMUM_POSIX_TIMERS != 0) || \
-       (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0) || \
-      defined(CONFIGURE_POSIX_INIT_THREAD_TABLE))
+  #if ((CONFIGURE_MAXIMUM_POSIX_TIMERS != 0) || \
+       (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0))
   #error "CONFIGURATION ERROR: POSIX API support not configured!!"
   #endif
 #endif
diff --git a/cpukit/include/rtems/monitor.h b/cpukit/include/rtems/monitor.h
index 6ecd903c63..d973687396 100644
--- a/cpukit/include/rtems/monitor.h
+++ b/cpukit/include/rtems/monitor.h
@@ -43,9 +43,7 @@ typedef enum {
     RTEMS_MONITOR_OBJECT_INIT_TASK,
     RTEMS_MONITOR_OBJECT_MPCI,
     RTEMS_MONITOR_OBJECT_SYMBOL,
-    #if defined(RTEMS_POSIX_API)
-      RTEMS_MONITOR_OBJECT_PTHREAD,
-    #endif
+    RTEMS_MONITOR_OBJECT_PTHREAD
 } rtems_monitor_object_type_t;
diff --git a/cpukit/include/rtems/posix/pthreadattrimpl.h b/cpukit/include/rtems/posix/pthreadattrimpl.h
index cd4b3528a2..b5e02ec1c7 100644
--- a/cpukit/include/rtems/posix/pthreadattrimpl.h
+++ b/cpukit/include/rtems/posix/pthreadattrimpl.h
@@ -25,9 +25,7 @@
-#endif
 #ifdef __cplusplus
 extern "C" {
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 1e97083dd7..c665fccb69 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -69,9 +69,7 @@ extern "C" {
-  #define RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE
-#endif
+#define RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE
  * With the addition of the Constant Block Scheduler (CBS),
@@ -79,9 +77,7 @@ extern "C" {
 #define RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT
-  #define RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API
-#endif
+#define RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API
 #if defined(RTEMS_DEBUG)
 #define RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT
@@ -703,7 +699,6 @@ typedef struct {
   uint32_t pending_life_change_requests;
    * @brief The thread exit value.
@@ -713,7 +708,6 @@ typedef struct {
    * - NULL.
   void *exit_value;
-#endif
 } Thread_Life_control;
 typedef struct  {
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index caa3d3ebb3..86f7d28188 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -26,30 +26,8 @@
 #include <rtems/score/protectedheap.h>
 #include <rtems/posix/keyimpl.h>
-#include <rtems/rtems/barrierimpl.h>
-#include <rtems/extensionimpl.h>
-#include <rtems/rtems/dpmemimpl.h>
-#include <rtems/rtems/messageimpl.h>
-#include <rtems/rtems/partimpl.h>
-#include <rtems/rtems/ratemonimpl.h>
-#include <rtems/rtems/regionimpl.h>
-#include <rtems/rtems/semimpl.h>
-#include <rtems/rtems/tasksimpl.h>
-#include <rtems/rtems/timerimpl.h>
-  #include <rtems/posix/barrierimpl.h>
-  #include <rtems/posix/mqueueimpl.h>
-  #include <rtems/posix/muteximpl.h>
-  #include <rtems/posix/psignal.h>
-  #include <rtems/posix/pthreadimpl.h>
-  #include <rtems/posix/semaphoreimpl.h>
-  #include <rtems/posix/timerimpl.h>
-#endif
 static const struct {
   Objects_APIs api;
   uint16_t cls;
@@ -64,12 +42,12 @@ static const struct {
   { OBJECTS_CLASSIC_API, OBJECTS_RTEMS_REGIONS },
   { OBJECTS_CLASSIC_API, OBJECTS_RTEMS_SEMAPHORES },
   { OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TASKS },
-  { OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TIMERS }
+  { OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TIMERS },
+  { OBJECTS_POSIX_API, OBJECTS_POSIX_MESSAGE_QUEUES },
+  { OBJECTS_POSIX_API, OBJECTS_POSIX_SEMAPHORES },
+  { OBJECTS_POSIX_API, OBJECTS_POSIX_THREADS }
-    { OBJECTS_POSIX_API, OBJECTS_POSIX_MESSAGE_QUEUES },
-    { OBJECTS_POSIX_API, OBJECTS_POSIX_SEMAPHORES },
-    { OBJECTS_POSIX_API, OBJECTS_POSIX_THREADS },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_TIMERS }
   #endif
diff --git a/cpukit/libmisc/monitor/mon-monitor.c b/cpukit/libmisc/monitor/mon-monitor.c
index fe292f29d0..5a9457b9ef 100644
--- a/cpukit/libmisc/monitor/mon-monitor.c
+++ b/cpukit/libmisc/monitor/mon-monitor.c
@@ -223,7 +223,6 @@ static const rtems_monitor_command_entry_t rtems_monitor_commands[] = {
 #else
   #define RTEMS_MONITOR_POSIX_NEXT 19
 #endif
     { "pthread",
       "Display information about the specified pthreads. "
       "Default is to display information about all pthreads on this node.\n"
@@ -234,9 +233,6 @@ static const rtems_monitor_command_entry_t rtems_monitor_commands[] = {
       &rtems_monitor_commands[RTEMS_MONITOR_POSIX_NEXT],
   #define RTEMS_MONITOR_DEBUGGER_NEXT (RTEMS_MONITOR_POSIX_NEXT + 1)
-#else
-  #define RTEMS_MONITOR_DEBUGGER_NEXT RTEMS_MONITOR_POSIX_NEXT
-#endif
 #ifdef CPU_INVOKE_DEBUGGER
     { "debugger",
       "Enter the debugger, if possible. "
diff --git a/cpukit/libmisc/monitor/mon-object.c b/cpukit/libmisc/monitor/mon-object.c
index ef32214f3c..039d11fd74 100644
--- a/cpukit/libmisc/monitor/mon-object.c
+++ b/cpukit/libmisc/monitor/mon-object.c
@@ -25,9 +25,7 @@
-#endif
+#include <rtems/posix/pthreadimpl.h>
 #include <stdlib.h>             /* strtoul() */
@@ -130,7 +128,6 @@ static const rtems_monitor_object_info_t rtems_monitor_object_info[] =
       (rtems_monitor_object_dump_header_fn) rtems_monitor_driver_dump_header,
       (rtems_monitor_object_dump_fn)        rtems_monitor_driver_dump,
     { RTEMS_MONITOR_OBJECT_PTHREAD,
       (void *) &_POSIX_Threads_Information.Objects,
       sizeof(rtems_monitor_task_t),
@@ -138,8 +135,7 @@ static const rtems_monitor_object_info_t rtems_monitor_object_info[] =
       (rtems_monitor_object_canonical_fn)   rtems_monitor_task_canonical,
       (rtems_monitor_object_dump_header_fn) rtems_monitor_task_dump_header,
       (rtems_monitor_object_dump_fn)        rtems_monitor_task_dump,
-#endif
diff --git a/cpukit/posix/src/psxtransschedparam.c b/cpukit/posix/src/psxtransschedparam.c
index 614c5fb71f..587788cabd 100644
--- a/cpukit/posix/src/psxtransschedparam.c
+++ b/cpukit/posix/src/psxtransschedparam.c
@@ -30,10 +30,8 @@ int _POSIX_Thread_Translate_to_sched_policy(
   switch ( budget_algorithm ) {
     case THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE:
       return SCHED_OTHER;
     case THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE:
       return SCHED_RR;
-#endif
     case THREAD_CPU_BUDGET_ALGORITHM_CALLOUT:
       return SCHED_SPORADIC;
     default:
@@ -62,13 +60,12 @@ int _POSIX_Thread_Translate_sched_param(
     return 0;
   if ( policy == SCHED_RR ) {
     *budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE;
     return 0;
-#endif
+#if defined(RTEMS_POSIX_API)
   if ( policy == SCHED_SPORADIC ) {
     if ( (param->sched_ss_repl_period.tv_sec == 0) &&
          (param->sched_ss_repl_period.tv_nsec == 0) )
@@ -86,6 +83,7 @@ int _POSIX_Thread_Translate_sched_param(
     *budget_callout = _POSIX_Threads_Sporadic_budget_callout;
     return 0;
+#endif
   return EINVAL;
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index da31252063..0a790f9371 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -34,7 +34,9 @@
 #include <rtems/posix/psignalimpl.h>
+#endif
 #include <rtems/posix/config.h>
@@ -42,6 +44,7 @@
 Thread_Information _POSIX_Threads_Information;
 void _POSIX_Threads_Sporadic_timer( Watchdog_Control *watchdog )
   POSIX_API_Control    *api;
@@ -144,6 +147,7 @@ static void _POSIX_Threads_Terminate_extension( Thread_Control *executing )
   _Watchdog_Per_CPU_remove_ticks( &api->Sporadic.Timer );
   _Thread_State_release( executing, &lock_context );
+#endif
  *  _POSIX_Threads_Exitted_extension
@@ -164,9 +168,11 @@ static void _POSIX_Threads_Exitted_extension(
 User_extensions_Control _POSIX_Threads_User_extensions = {
   .Callouts = {
     .thread_create    = _POSIX_Threads_Create_extension,
-    .thread_exitted   = _POSIX_Threads_Exitted_extension,
-    .thread_terminate = _POSIX_Threads_Terminate_extension
+    .thread_terminate = _POSIX_Threads_Terminate_extension,
+#endif
+    .thread_exitted   = _POSIX_Threads_Exitted_extension
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 46fe1e7412..07fded25b4 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -73,14 +73,16 @@ int pthread_create(
   Thread_Control                     *the_thread;
   Thread_Control                     *executing;
   const Scheduler_Control            *scheduler;
-  POSIX_API_Control                  *api;
-  const POSIX_API_Control            *executing_api;
   int                                 schedpolicy = SCHED_RR;
   struct sched_param                  schedparam;
   size_t                              stacksize;
   Objects_Name                        name;
   int                                 error;
   ISR_lock_Context                    lock_context;
+  POSIX_API_Control                  *api;
+  const POSIX_API_Control            *executing_api;
+#endif
   if ( !start_routine )
     return EFAULT;
@@ -242,6 +244,10 @@ int pthread_create(
      return EINVAL;
+  the_thread->was_created_with_inherited_scheduler =
+    ( the_attr->inheritsched == PTHREAD_INHERIT_SCHED );
    *  finish initializing the per API structure
@@ -250,9 +256,6 @@ int pthread_create(
   api->signals_unblocked = executing_api->signals_unblocked;
-  the_thread->was_created_with_inherited_scheduler =
-    ( the_attr->inheritsched == PTHREAD_INHERIT_SCHED );
   _Priority_Node_set_priority( &api->Sporadic.Low_priority, core_low_prio );
   api->Sporadic.sched_ss_repl_period =
     the_attr->schedparam.sched_ss_repl_period;
@@ -264,6 +267,7 @@ int pthread_create(
   if ( schedpolicy == SCHED_SPORADIC ) {
     _POSIX_Threads_Sporadic_timer( &api->Sporadic.Timer );
+#endif
    *  POSIX threads are allocated and started in one operation.
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index 7c5b6f109d..8d87620d93 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -40,12 +40,14 @@ static int _POSIX_Set_sched_param(
   int                      normal_prio;
-  int                      low_prio;
   bool                     valid;
   Priority_Control         core_normal_prio;
+  int                      low_prio;
   Priority_Control         core_low_prio;
+#endif
   normal_prio = param->sched_priority;
@@ -56,6 +58,7 @@ static int _POSIX_Set_sched_param(
     return EINVAL;
     low_prio = param->sched_ss_low_priority;
   } else {
@@ -70,9 +73,11 @@ static int _POSIX_Set_sched_param(
   api = the_thread->API_Extensions[ THREAD_API_POSIX ];
+#endif
   _Priority_Node_set_priority( &the_thread->Real_priority, core_normal_prio );
   if ( _Priority_Node_is_active( &api->Sporadic.Low_priority ) ) {
     _Thread_Priority_add(
       the_thread,
@@ -86,17 +91,21 @@ static int _POSIX_Set_sched_param(
     _Priority_Node_set_inactive( &api->Sporadic.Low_priority );
   } else {
+#endif
     _Thread_Priority_changed(
       the_thread,
       false,
       queue_context
+#endif
   the_thread->budget_algorithm = budget_algorithm;
   the_thread->budget_callout   = budget_callout;
   api->Sporadic.sched_ss_repl_period = param->sched_ss_repl_period;
   api->Sporadic.sched_ss_init_budget = param->sched_ss_init_budget;
@@ -105,9 +114,12 @@ static int _POSIX_Set_sched_param(
     _POSIX_Threads_Sporadic_timer_insert( the_thread, api );
   } else {
+#endif
     the_thread->cpu_time_budget =
       rtems_configuration_get_ticks_per_timeslice();
+#endif
   return 0;
diff --git a/cpukit/rtems/src/rtemsobjectgetapiclassname.c b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
index 3f26f2f25b..a00b06b990 100644
--- a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
+++ b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
@@ -43,9 +43,9 @@ static const rtems_assoc_t rtems_object_api_classic_assoc[] = {
 static const rtems_assoc_t rtems_object_api_posix_assoc[] = {
   { "Thread",                  OBJECTS_POSIX_THREADS, 0},
   { "Key",                     OBJECTS_POSIX_KEYS, 0},
+#ifdef RTEMS_POSIX_API
   { "Interrupt",               OBJECTS_POSIX_INTERRUPTS, 0},
 #endif
   { "Message Queue",           OBJECTS_POSIX_MESSAGE_QUEUES, 0},
diff --git a/cpukit/score/src/threaditerate.c b/cpukit/score/src/threaditerate.c
index 0f9a1bef44..eff3472d57 100644
--- a/cpukit/score/src/threaditerate.c
+++ b/cpukit/score/src/threaditerate.c
@@ -29,11 +29,9 @@ void _Thread_Iterate(
     const Objects_Information *information;
     Objects_Maximum            i;
-#if !defined(RTEMS_POSIX_API)
     if ( _Objects_Information_table[ api_index ] == NULL ) {
       continue;
-#endif
     information = _Objects_Information_table[ api_index ][ 1 ];
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index ae5c3382ae..66cf4df845 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -77,12 +77,9 @@ static void _Thread_Raise_real_priority(
 typedef struct {
   Thread_queue_Context  Base;
   void                 *exit_value;
-#endif
 } Thread_Join_context;
 static Thread_Control *_Thread_Join_flush_filter(
   Thread_Control       *the_thread,
   Thread_queue_Queue   *queue,
@@ -97,26 +94,19 @@ static Thread_Control *_Thread_Join_flush_filter(
   return the_thread;
-#endif
 static void _Thread_Wake_up_joining_threads( Thread_Control *the_thread )
   Thread_Join_context join_context;
   join_context.exit_value = the_thread->Life.exit_value;
-#endif
   _Thread_queue_Context_initialize( &join_context.Base );
   _Thread_queue_Acquire( &the_thread->Join_queue, &join_context.Base );
   _Thread_queue_Flush_critical(
     &the_thread->Join_queue.Queue,
     THREAD_JOIN_TQ_OPERATIONS,
     _Thread_Join_flush_filter,
-#else
-    _Thread_queue_Flush_default_filter,
-#endif
     &join_context.Base
@@ -289,7 +279,6 @@ static Per_CPU_Control *_Thread_Wait_for_join(
   Per_CPU_Control *cpu_self
   _Thread_State_acquire( executing, &lock_context );
@@ -308,7 +297,6 @@ static Per_CPU_Control *_Thread_Wait_for_join(
   } else {
-#endif
   return cpu_self;
@@ -442,9 +430,7 @@ void _Thread_Join(
   _Assert( the_thread != executing );
   _Assert( _Thread_State_is_owner( the_thread ) );
   executing->Wait.return_argument = NULL;
-#endif
   _Thread_queue_Context_set_thread_state( queue_context, waiting_for_join );
   _Thread_queue_Enqueue(
@@ -460,9 +446,7 @@ static void _Thread_Set_exit_value(
   void           *exit_value
   the_thread->Life.exit_value = exit_value;
-#endif
 void _Thread_Cancel(
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index 2657ba0dda..c9df793526 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -53,11 +53,9 @@ static uint32_t _Workspace_Get_maximum_thread_count( void )
     Configuration_RTEMS_API.maximum_tasks
   thread_count += rtems_resource_maximum_per_allocation(
     _Configuration_POSIX_Maximum_threads
-#endif
   return thread_count;
2.16.4
