[rtems-testing commit] Change default license for tests generated from templates to 0-BSD.
Tue Oct 30 14:59:06 UTC 2018
On Tue, Oct 30, 2018 at 6:17 AM Sebastian Huber <
> On 29/10/2018 21:57, Joel Sherrill wrote:
> > diff --git a/rtems-test-template/psxtest/TEST.doc
> b/rtems-test-template/psxtest/TEST.doc
> > index 4699d93..3aafcea 100644
> > --- a/rtems-test-template/psxtest/TEST.doc
> > +++ b/rtems-test-template/psxtest/TEST.doc
> > @@ -1,9 +1,16 @@
> >   #  COPYRIGHT (c) 1989-2013.
> >   #  On-Line Applications Research Corporation (OAR).
> > -#  The license and distribution terms for this file may be
> > -#  found in the file LICENSE in this distribution or at
> > -#http://www.rtems.com/license/LICENSE.
> > +#  Permission to use, copy, modify, and/or distribute this software
> > +#  for any purpose with or without fee is hereby granted.
> > +#  THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
> > +#  WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
> > +#  WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE
> AUTHOR
> > +#  BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
> > +#  OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR
> PROFITS,
> > +#  WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
> ACTION,
> > +#  ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
> SOFTWARE.
> OAR is mentioned as the copyright holder, but the disclaimer talks about
> the author.
Thanks. Since these are intended to be templates that someone instantiates
as a
starting point, I changed Year and Author to be a spot to be filled in
after the
template is instantiated.
I am going to make a sweep through them to make sure they all still compile.
And then add at least one more. Gedare and I are working on a list of
POSIX and C++11 thread examples for Google Code-In students to create.
If you have any ideas for examples that need to be written, ideas would be
appreciates.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181030/930e6236/attachment.html>
