[PATCH] c-user: Update POSIX API configuration
Wed Oct 31 06:41:17 UTC 2018
On 31/10/2018 17:02, Sebastian Huber wrote:
> On 31/10/2018 02:16, Chris Johns wrote:
>> On 30/10/2018 18:09, Sebastian Huber wrote:
>>> Close ##2514.
>>>   c-user/configuring_a_system.rst | 34 +++++++++++++++++++++++-----------
>>>   1 file changed, 23 insertions(+), 11 deletions(-)
>>> diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
>>> index eab91ff..78344df 100644
>>> --- a/c-user/configuring_a_system.rst
>>> +++ b/c-user/configuring_a_system.rst
>>> @@ -517,7 +517,7 @@ NOTES:
>>>       ``CONFIGURE_EXTRA_TASK_STACKS``.
>>>         The maximum number of POSIX threads is specified by
>>> -    ``CONFIGURE_MAXIMUM_POSIX_THREADS``.
>>> +    :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
>>>         A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
>>>       assumption that all tasks have floating point enabled. This would require
>>> @@ -1051,9 +1051,11 @@ NOTES:
>>>   POSIX API Configuration
>>>   -The parameters in this section are used to configure resources for the RTEMS
>>> -POSIX API.  They are only relevant if the POSIX API is enabled at configure
>>> -time using the ``--enable-posix`` option.
>>> +The parameters in this section are used to configure resources for the POSIX
>>> +API supported by RTEMS.  Most POSIX API objects are available by default since
>>> +RTEMS 5.1.  The queued signals and timers are only available if the optional
>>> +parts of the POSIX API are enabled at BSP configure time using the
>> BSP configure time? Is this in common use? The User manual says ...
>> https://docs.rtems.org/branches/master/user/installation/kernel.html#building-a-bsp
>> ... we "configure RTEMS" for a BSP.
> In the "Configuring a System" chapter the term "configure RTEMS" could be
> confusing.
Yes, this is true. We should settle on something standard and use it consistently.
> What about:
> The queued signals and timers are only available if RTEMS has been
> built with the ``--enable-posix`` build configuration option.
"build configuration option" or "build configure option"?
I like 'build configuration'. Does this mean 'configuration' is the run-time
configuration or should this be explicit as well?
