[PATCH] testsuite, clang: fix malloc04 and malloctest for on clang
Sebastian Huber
Fri Oct 5 07:14:34 UTC 2018
On 05/10/2018 08:57, Daniel Hellstrom wrote:
> malloc04 and malloctest tests from the rtems test-suite fails
> when checking the return value of malloc(). The check is
> optimized away and always fails.
Please change the patch to use RTEMS_OBFUSCATE_VARIABLE() in the spots
where the compiler tries to be smarter than desired.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
