[PATCH] jffs, clang: avoid some warnings of used uninitialized ptr
Sebastian Huber
Fri Oct 5 11:01:56 UTC 2018
On 05/10/2018 12:44, Daniel Hellstrom wrote:
> On 2018-10-05 09:41, Sebastian Huber wrote:
>> On 05/10/2018 09:38, Daniel Hellstrom wrote:
>>> On 2018-10-05 09:34, Sebastian Huber wrote:
>>>> On 05/10/2018 09:25, Daniel Hellstrom wrote:
>>>>> On 2018-10-05 09:12, Sebastian Huber wrote:
>>>>>> On 05/10/2018 08:57, Daniel Hellstrom wrote:
>>>>>>> This fixes the following test failures on LEON3 UP/SMP when
>>>>>>> built using clang compiler:
>>>>>>> * fsjffs2gc01
>>>>>>> * jffs2_fserror
>>>>>>> * jffs2_fspermission
>>>>>>> * jffs2_fsrdwr
>>>>>>> * jffs2_fstime
>>>>>> The problem is probably in the
>>>>>> rbtree_postorder_for_each_entry_safe(). Coverity Scan has also an
>>>>>> issue with this macro. It is on my todo list. Please do not check
>>>>>> in this patch.
>>>>> Ok I will not push it. Yes I was also thinking so. To use
>>>>> offsetof() macro could be an option maybe, however the node type
>>>>> input is not known to the rbtree_postorder_for_each_entry_safe()
>>>>> function even though it only used from jffs2 code.
>>>> The Linux code uses typeof. We could do this also:
>>>> diff --git a/cpukit/include/linux/rbtree.h
>>>> b/cpukit/include/linux/rbtree.h
>>>> index 53c777e8c1..8fc575240f 100644
>>>> --- a/cpukit/include/linux/rbtree.h
>>>> +++ b/cpukit/include/linux/rbtree.h
>>>> @@ -126,12 +126,12 @@ static inline struct rb_node *rb_parent(
>>>> struct rb_node *node )
>>>> for ( \
>>>> node = _RBTree_Postorder_first( \
>>>> (RBTree_Control *) root, \
>>>> - (size_t) ( (char *) &node->field - (char *) node ) \
>>>> + offsetof( __typeof__( *node ), field ) \
>>>> node != NULL && ( \
>>>> next = _RBTree_Postorder_next( \
>>>> &node->field, \
>>>> node != NULL \
>>>> It shouldn't be a big problem since at least GCC and clang supports
>>>> it. It is also a standard C++ operator. It is already used in
>>>> cpukit/libfs/src/jffs2/include/linux/list.h
>>> Ok, I will give it a try.
>> Thanks, please try this patch:
>> https://lists.rtems.org/pipermail/devel/2018-October/023181.html
> Yes I can confirm it fixed all the 5 tests on gr712rc with clang. It
> also removed the two warnings in jffs2 code related.
> I have updated my patch to only include the third warning fix then:
> cpukit/libfs/src/jffs2/src/readinode.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libfs/src/jffs2/src/readinode.c
> b/cpukit/libfs/src/jffs2/src/readinode.c
> index 519b0d6..ecdf335 100644
> --- a/cpukit/libfs/src/jffs2/src/readinode.c
> +++ b/cpukit/libfs/src/jffs2/src/readinode.c
> @@ -35,7 +35,7 @@ static int check_node_data(struct jffs2_sb_info *c,
> struct jffs2_tmp_dnode_info
> struct jffs2_raw_node_ref *ref = tn->fn->raw;
> int err = 0, pointed = 0;
> struct jffs2_eraseblock *jeb;
> - unsigned char *buffer;
> + unsigned char *buffer = NULL;
> uint32_t crc, ofs, len;
> size_t retlen;
What is this for a warning? Some sort of uninitialized variable warning?
This code is identical to the Linux upstream. This is probably a clang bug.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
