[PATCH 12/31] build: Merge libdrvmgr/Makefile.am
Sebastian Huber
Mon Oct 8 10:43:14 UTC 2018
cpukit/Makefile.am | 24 +++++++++++++++++++++++-
cpukit/configure.ac | 1 -
cpukit/libdrvmgr/Makefile.am | 32 --------------------------------
cpukit/wrapup/Makefile.am | 4 ----
4 files changed, 23 insertions(+), 38 deletions(-)
delete mode 100644 cpukit/libdrvmgr/Makefile.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 08fce92381..0ffaa4727d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -327,6 +327,29 @@ libcpukit_a_SOURCES += libdl/rtl-unwind-dw2.c
endif
+if LIBDRVMGR
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_by_id.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_by_name.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_dev_by_name.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_drvinf.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_for_each_dev.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_for_each_list_dev.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_func.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_func_call.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_init.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_list.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_lock.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_print.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_res.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_rw.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_translate.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_translate_check.c
+libcpukit_a_SOURCES += libdrvmgr/drvmgr_unregister.c
+endif
# Create a new Version VC Key header if the VC state has changed.
@@ -363,7 +386,6 @@ all-local: generate-vc-key
# librtemscpu
_SUBDIRS = . score rtems posix
_SUBDIRS += libfs
-_SUBDIRS += libdrvmgr
_SUBDIRS += libnetworking librpc
_SUBDIRS += libpci
_SUBDIRS += libi2c
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index cdf162150f..f02474fa4d 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -497,7 +497,6 @@ score/cpu/v850/Makefile
score/cpu/x86_64/Makefile
score/cpu/no_cpu/Makefile
posix/Makefile
-libdrvmgr/Makefile
libfs/Makefile
libfs/src/nfsclient/Makefile
libgnat/Makefile
diff --git a/cpukit/libdrvmgr/Makefile.am b/cpukit/libdrvmgr/Makefile.am
deleted file mode 100644
index 3d614bb311..0000000000
--- a/cpukit/libdrvmgr/Makefile.am
+++ /dev/null
@@ -1,32 +0,0 @@
-include $(top_srcdir)/automake/compile.am
-if LIBDRVMGR
-noinst_LIBRARIES = libdrvmgr.a
-libdrvmgr_a_SOURCES = drvmgr.c
-libdrvmgr_a_SOURCES += drvmgr.h
-libdrvmgr_a_SOURCES += drvmgr_by_name.c
-libdrvmgr_a_SOURCES += drvmgr_by_id.c
-libdrvmgr_a_SOURCES += drvmgr_dev_by_name.c
-libdrvmgr_a_SOURCES += drvmgr_drvinf.c
-libdrvmgr_a_SOURCES += drvmgr_init.c
-libdrvmgr_a_SOURCES += drvmgr_confdefs.h
-libdrvmgr_a_SOURCES += drvmgr_for_each_dev.c
-libdrvmgr_a_SOURCES += drvmgr_for_each_list_dev.c
-libdrvmgr_a_SOURCES += drvmgr_func.c
-libdrvmgr_a_SOURCES += drvmgr_func_call.c
-libdrvmgr_a_SOURCES += drvmgr_list.c
-libdrvmgr_a_SOURCES += drvmgr_list.h
-libdrvmgr_a_SOURCES += drvmgr_lock.c
-libdrvmgr_a_SOURCES += drvmgr_print.c
-libdrvmgr_a_SOURCES += drvmgr_res.c
-libdrvmgr_a_SOURCES += drvmgr_rw.c
-libdrvmgr_a_SOURCES += drvmgr_translate.c
-libdrvmgr_a_SOURCES += drvmgr_translate_check.c
-libdrvmgr_a_SOURCES += drvmgr_unregister.c
-endif
-include $(top_srcdir)/automake/local.am
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index 1335b5bfce..7bf5cae9dd 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -72,10 +72,6 @@ if LIBPCI
TMP_LIBS += ../libpci/libpci.a
endif
-if LIBDRVMGR
-TMP_LIBS += ../libdrvmgr/libdrvmgr.a
-endif
if LIBNETWORKING
TMP_LIBS += ../libnetworking/libnetworking.a
TMP_LIBS += ../librpc/librpc.a
2.16.4
