Link RAP file error on zynq BSP
jameszxj
jameszxj at gmail.com
Mon Oct 15 08:16:49 UTC 2018
From: "Sebastian Huber"<sebastian.huber at embedded-brains.de>;
Date: Mon, Oct 15, 2018 02:43 PM
To: "devel"<devel at rtems.org>;
Cc: "jameszxj"<jameszxj at gmail.com>;
Subject: Re: Link RAP file error on zynq BSP
On 15/10/2018 08:16, jameszxj wrote:
>> d:/msys64/opt/rtems/5.1/bin/../lib/gcc/arm-rtems5/7.3.0/../../../../arm-rtems5/bin/ld.exe:
>> wsp/build/nssys.elf section `.unexpected_sections' will not fit in
>> region `UNEXPECTED_SECTIONS'
>> collect2.exe: error: ld returned 1 exit status
>Please have a look at the linker map file to figure out what these
>sections are.
0x0000000100000000 0x0
.tm_clone_table
0x0000000100000000 0x0 d:/msys64/opt/rtems/5.1/bin/../lib/gcc/arm-rtems5/7.3.0/thumb/armv7-a/neon/hard/crtbegin.o
.tm_clone_table
0x0000000100000000 0x0 d:/msys64/opt/rtems/5.1/bin/../lib/gcc/arm-rtems5/7.3.0/thumb/armv7-a/neon/hard/crtend.o
0x0000000100000000 __TMC_END__
END GROUP
LOAD d:/msys64/opt/rtems/5.1/bin/../lib/gcc/arm-rtems5/7.3.0/thumb/armv7-a/neon/hard/crtend.o
LOAD d:/msys64/opt/rtems/5.1/bin/../lib/gcc/arm-rtems5/7.3.0/thumb/armv7-a/neon/hard/crtn.o
OUTPUT(wsp/build/nssys.elf elf32-littlearm)
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181015/61a09500/attachment-0002.html>
