On 17/10/2018 21:25, Sebastian Huber wrote: > The stuff in rtems_waf makes some problems. It uses the RTEMS libraries for the > probes which contain simply a main() function and no RTEMS configuration. There > are two options to address this issue. Should rtems_waf be adjusted to not do this? Chris
