Cygwin sb-check Failure
Tue Oct 23 20:47:45 UTC 2018
On Tue, Oct 23, 2018 at 3:38 PM Chris Johns <chrisj at rtems.org> wrote:
> On 24/10/2018 07:27, Joel Sherrill wrote:
> > Looks like the recent changes have broken Cygwin:
> > $ ../source-builder/sb-check
> > error: failed to load CYGWIN_NT-10.0 host support: error: cannot find
> MinGW
> > install: C:/cygwin64/mingw64
> > Assuming this is similar to the MSYS2 situation, is there a reason to
> want to
> > use the mingw python2 with Cygwin and is it even avaialble?
> A cygwin build should be POSIX which should work like Linux etc.
> Left a piece of debug in windows.py. On line 161 please remove the 'or
> True'. If
> this works on cygwin please push.
That let's sb-check pass. I have an anonymous clone in this environment.
Please push it.
> I am sorry about this.
No problem. There are a lot of moving parts with the Python change that we
can't
control. I am  just trying to test like I promised. :)
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181023/1f0e3b87/attachment-0002.html>
