[PATCH] Coverage: add the style and js files to the symbol-set report directory
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Oct 28 09:33:59 UTC 2018
On Sun, 28 Oct 2018 at 09:00, Chris Johns <chrisj at rtems.org> wrote:
> On 27/10/18 5:13 am, Vijay Kumar Banerjee wrote:
> >   tester/rt/coverage.py | 17 ++++-------------
> >   1 file changed, 4 insertions(+), 13 deletions(-)
> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> > index 978a8c4..4200dad 100644
> > --- a/tester/rt/coverage.py
> > +++ b/tester/rt/coverage.py
> > @@ -201,23 +201,14 @@ class report_gen_html:
> >           index_content = self._prepare_index_content(partial_reports)
> >           self._create_index_file(head_section,index_content)
> > -    def add_covoar_src_path(self):
> > +    def add_covoar_css(self):
> >           table_js_path = path.join(self.covoar_src_path, 'table.js')
> >           covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
> >           for symbol_set in self.symbol_sets:
> >               symbol_set_dir = path.join(self.build_dir,
> >                                          self.bsp + '-coverage',
> symbol_set)
> > -            html_files = os.listdir(symbol_set_dir)
> > -            for html_file in html_files:
> > -                html_file = path.join(symbol_set_dir, html_file)
> > -                if path.exists(html_file) and 'html' in html_file:
> > -                    with open(html_file, 'r') as f:
> > -                        file_data = f.read()
> > -                    file_data = file_data.replace('table.js',
> table_js_path)
> > -                    file_data = file_data.replace('covoar.css',
> > -                                                  covoar_css_path)
> > -                    with open(html_file, 'w') as f:
> > -                        f.write(file_data)
> > +            shutil.copy(covoar_css_path, symbol_set_dir)
> > +            shutil.copy(table_js_path, symbol_set_dir)
> How portable are these calls?
> Please have a look at 'path.copy_tree' in the rtemstoolkit's path.py. I
> think you can use that call instead.
> shutil is portable as it comes with python. i looked into the
path.copy_tree
it uses shutil as well, but it requires the source-name to be a directory
wherefrom it will copy all the files to destination directory.
Is there a reason that path.copy_tree has been used instead of
shutil.copytree ?
https://docs.python.org/2/library/shutil.html#shutil.copytree
> >   class build_path_generator(object):
> > @@ -402,7 +393,7 @@ class coverage_run(object):
> >                                        self.rtdir,
> >                                        self.macros['bsp'])
> >               report.generate()
> > -            report.add_covoar_src_path()
> > +            report.add_covoar_css()
> >       def _cleanup(self):
> >           if not self.no_clean:
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181028/815edb15/attachment-0002.html>
