rtems-bsp-builder .ini file syntax question (for epiphany)
Fri Sep 7 02:07:29 UTC 2018
On 6/9/18 9:00 am, Joel Sherrill wrote:
> https://lists.rtems.org/pipermail/build/2018-September/000997.html still has
> epiphany
> failures. Not sure what else is going on. Do you see the pattern?
The 'debug' build is not adding '--disable-networking' as the BSP builder is not
tracking defaults or more specifically enabled by default. The SMP works because
the default is disabled while networking has a default of enabled.
