[PATCH 2/5] network: Remove unused files
Fri Sep 7 05:31:38 UTC 2018
 cpukit/libnetworking/Makefile.am          |  10 --
 cpukit/libnetworking/libc/ether_addr.c    | 227 ------------------------------
 cpukit/libnetworking/libc/gethostname.c   |  24 ----
 cpukit/libnetworking/libc/inet_net_ntop.c | 139 ------------------
 cpukit/libnetworking/libc/inet_net_pton.c | 206 ---------------------------
 cpukit/libnetworking/libc/inet_neta.c     |  83 -----------
 cpukit/libnetworking/libc/ns_addr.c       | 227 ------------------------------
 cpukit/libnetworking/libc/ns_ntoa.c       | 100 -------------
 8 files changed, 1016 deletions(-)
 delete mode 100644 cpukit/libnetworking/libc/ether_addr.c
 delete mode 100644 cpukit/libnetworking/libc/gethostname.c
 delete mode 100644 cpukit/libnetworking/libc/inet_net_ntop.c
 delete mode 100644 cpukit/libnetworking/libc/inet_net_pton.c
 delete mode 100644 cpukit/libnetworking/libc/inet_neta.c
 delete mode 100644 cpukit/libnetworking/libc/ns_addr.c
 delete mode 100644 cpukit/libnetworking/libc/ns_ntoa.c
diff --git a/cpukit/libnetworking/Makefile.am b/cpukit/libnetworking/Makefile.am
index 372f642610..7807f6ef5a 100644
--- a/cpukit/libnetworking/Makefile.am
+++ b/cpukit/libnetworking/Makefile.am
@@ -16,12 +16,6 @@ $(PROJECT_LIB)/libtftpfs.a: libtftpfs.a
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/libtftpfs.a
 TMPINSTALL_FILES += $(PROJECT_LIB)/libtftpfs.a
-# poll is not supported
-UNUSED_FILES = poll.h
-# Original FreeBSD file
-UNUSED_FILES += sys/poll.h
 if LIBNETWORKING
 # Add -DFORWARD_PROTOCOL to enable UDP forwarding -- requires missing net/pf.h
 libnetworking_CPPFLAGS = -DINET -DNFS \
@@ -120,10 +114,6 @@ libc_a_SOURCES += libc/if_indextoname.c
 libc_a_SOURCES += libc/if_nameindex.c
 endif
-UNUSED_FILES += libc/ether_addr.c libc/gethostname.c libc/inet_neta.c \
-    libc/inet_net_ntop.c libc/inet_net_pton.c libc/ns_addr.c \
-    libc/ns_ntoa.c
 libc_mans = libc/byteorder.3 libc/ethers.3 \
     libc/gethostbyname.3 libc/getnetent.3 libc/getprotoent.3 \
     libc/getservent.3 libc/inet.3 libc/linkaddr.3 libc/ns.3 \
diff --git a/cpukit/libnetworking/libc/ether_addr.c b/cpukit/libnetworking/libc/ether_addr.c
deleted file mode 100644
index cecbec0db3..0000000000
--- a/cpukit/libnetworking/libc/ether_addr.c
+++ /dev/null
@@ -1,227 +0,0 @@
- * Copyright (c) 1995
- *	Bill Paul <wpaul at ctr.columbia.edu>.  All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * 3. All advertising materials mentioning features or use of this software
- *    must display the following acknowledgement:
- *	This product includes software developed by Bill Paul.
- * 4. Neither the name of the author nor the names of any co-contributors
- *    may be used to endorse or promote products derived from this software
- *    without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY Bill Paul AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * ethernet address conversion and lookup routines
- * Written by Bill Paul <wpaul at ctr.columbia.edu>
- * Center for Telecommunications Research
- * Columbia University, New York City
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <stdio.h>
-#include <paths.h>
-#include <sys/types.h>
-#include <string.h>
-#include <stdlib.h>
-#include <sys/param.h>
-#include <sys/socket.h>
-#include <net/ethernet.h>
-#ifdef YP
-#include <rpc/rpc.h>
-#include <rpcsvc/yp_prot.h>
-#include <rpcsvc/ypclnt.h>
-#endif
-#ifndef _PATH_ETHERS
-#define _PATH_ETHERS "/etc/ethers"
-#endif
- * Parse a string of text containing an ethernet address and hostname
- * and separate it into its component parts.
-int ether_line(l, e, hostname)
-        char *l;
-	struct ether_addr *e;
-	char *hostname;
-        int i, o[6];
-        i = sscanf(l, "%x:%x:%x:%x:%x:%x %s", &o[0], &o[1], &o[2],
-                                              &o[3], &o[4], &o[5],
-					      hostname);
-	if (i != 7)
-                return (i);
-        for (i=0; i<6; i++)
-                e->octet[i] = o[i];
-        return (0);
- * Convert an ASCII representation of an ethernet address to
- * binary form.
-struct ether_addr *ether_aton(a)
-        char *a;
-        int i;
-	static struct ether_addr o;
-	unsigned int o0, o1, o2, o3, o4, o5;
-        i = sscanf(a, "%x:%x:%x:%x:%x:%x", &o0, &o1, &o2, &o3, &o4, &o5);
-        if (i != 6)
-                return (NULL);
-        o.octet[0]=o0;
-	o.octet[1]=o1;
-	o.octet[2]=o2;
-	o.octet[3]=o3;
-	o.octet[4]=o4;
-	o.octet[5]=o5;
-        return ((struct ether_addr *)&o);
- * Convert a binary representation of an ethernet address to
- * an ASCII string.
-char *ether_ntoa(n)
-        struct ether_addr *n;
-        int i;
-	static char a[18];
-        i = sprintf(a,"%x:%x:%x:%x:%x:%x",n->octet[0],n->octet[1],n->octet[2],
-                                          n->octet[3],n->octet[4],n->octet[5]);
-        if (i < 11)
-                return (NULL);
-        return ((char *)&a);
- * Map an ethernet address to a hostname. Use either /etc/ethers or
- * NIS/YP.
-int ether_ntohost(hostname, e)
-	char *hostname;
-	FILE *fp;
-	char buf[BUFSIZ + 2];
-	struct ether_addr local_ether;
-	char local_host[MAXHOSTNAMELEN];
-#ifdef YP
-	char *result;
-	int resultlen;
-	char *ether_a;
-	char *yp_domain;
-#endif
-	if ((fp = fopen(_PATH_ETHERS, "r")) == NULL)
-		return (1);
-	while (fgets(buf,BUFSIZ,fp)) {
-		if (buf[0] == '#')
-			continue;
-#ifdef YP
-		if (buf[0] == '+') {
-			if (yp_get_default_domain(&yp_domain))
-				continue;
-			ether_a = ether_ntoa(e);
-			if (yp_match(yp_domain, "ethers.byaddr", ether_a,
-				strlen(ether_a), &result, &resultlen)) {
-				continue;
-			strncpy(buf, result, resultlen);
-			buf[resultlen] = '\0';
-			free(result);
-#endif
-		if (!ether_line(buf, &local_ether, local_host)) {
-			if (!bcmp((char *)&local_ether.octet[0],
-				(char *)&e->octet[0], 6)) {
-			/* We have a match */
-				strcpy(hostname, local_host);
-				fclose(fp);
-				return(0);
-	fclose(fp);
-	return (1);
- * Map a hostname to an ethernet address using /etc/ethers or
- * NIS/YP.
-int ether_hostton(hostname, e)
-	char *hostname;
-	FILE *fp;
-#ifdef YP
-	char *result;
-	int resultlen;
-	char *yp_domain;
-#endif
-		return (1);
-			continue;
-#ifdef YP
-				continue;
-			if (yp_match(yp_domain, "ethers.byname", hostname,
-				strlen(hostname), &result, &resultlen)) {
-				continue;
-			free(result);
-#endif
-			if (!strcmp(hostname, local_host)) {
-				bcopy((char *)&local_ether.octet[0],
-					(char *)&e->octet[0], 6);
-				fclose(fp);
-				return(0);
-	fclose(fp);
-	return (1);
diff --git a/cpukit/libnetworking/libc/gethostname.c b/cpukit/libnetworking/libc/gethostname.c
index 6f58189cd4..0000000000
--- a/cpukit/libnetworking/libc/gethostname.c
+++ /dev/null
@@ -1,24 +0,0 @@
-#if HAVE_CONFIG_H
-#endif
- * Solaris doesn't include the gethostname call by default.
-#include <sys/utsname.h>
-#include <sys/systeminfo.h>
-#include <netdb.h>
- * PUBLIC: #ifndef HAVE_GETHOSTNAME
- * PUBLIC: int gethostname __P((char *, int));
- * PUBLIC: #endif
-int
-gethostname(host, len)
-	char *host;
-	int len;
-	return (sysinfo(SI_HOSTNAME, host, len) == -1 ? -1 : 0);
diff --git a/cpukit/libnetworking/libc/inet_net_ntop.c b/cpukit/libnetworking/libc/inet_net_ntop.c
index f756f0a209..0000000000
--- a/cpukit/libnetworking/libc/inet_net_ntop.c
+++ /dev/null
@@ -1,139 +0,0 @@
- * Copyright (c) 1996 by Internet Software Consortium.
- * Permission to use, copy, modify, and distribute this software for any
- * purpose with or without fee is hereby granted, provided that the above
- * copyright notice and this permission notice appear in all copies.
- * THE SOFTWARE IS PROVIDED "AS IS" AND INTERNET SOFTWARE CONSORTIUM DISCLAIMS
- * ALL WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL INTERNET SOFTWARE
- * CONSORTIUM BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL
- * DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR
- * PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
- * ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
- * SOFTWARE.
-#if HAVE_CONFIG_H
-#endif
-#include <netinet/in.h>
-#include <arpa/inet.h>
-#include <errno.h>
-#include <stdio.h>
-#ifdef SPRINTF_CHAR
-# define SPRINTF(x) strlen(sprintf/**/x)
-#else
-# define SPRINTF(x) ((size_t)sprintf x)
-#endif
-static char *	inet_net_ntop_ipv4(const u_char *src, int bits,
-					char *dst, size_t size);
- * char *
- * inet_net_ntop(af, src, bits, dst, size)
- *	convert network number from network to presentation format.
- *	generates CIDR style result always.
- * return:
- *	pointer to dst, or NULL if an error occurred (check errno).
- * author:
- *	Paul Vixie (ISC), July 1996
-char *
-inet_net_ntop(af, src, bits, dst, size)
-	int af;
-	const void *src;
-	int bits;
-	char *dst;
-	size_t size;
-	switch (af) {
-	case AF_INET:
-		return (inet_net_ntop_ipv4(src, bits, dst, size));
-	default:
-		errno = EAFNOSUPPORT;
-		return (NULL);
- * static char *
- * inet_net_ntop_ipv4(src, bits, dst, size)
- *	convert IPv4 network number from network to presentation format.
- * return:
- * note:
- *	network byte order assumed.  this means 192.5.5.240/28 has
- *	0x11110000 in its fourth octet.
- * author:
-static char *
-inet_net_ntop_ipv4(src, bits, dst, size)
-	const u_char *src;
-	int bits;
-	char *dst;
-	size_t size;
-	char *odst = dst;
-	char *t;
-	u_int m;
-	int b;
-	if (bits < 0 || bits > 32) {
-		errno = EINVAL;
-		return (NULL);
-	if (bits == 0) {
-		if (size < sizeof "0")
-			goto emsgsize;
-		*dst++ = '0';
-		*dst = '\0';
-	/* Format whole octets. */
-	for (b = bits / 8; b > 0; b--) {
-		if (size < sizeof "255.")
-			goto emsgsize;
-		t = dst;
-		dst += SPRINTF((dst, "%u", *src++));
-		if (b > 1) {
-			*dst++ = '.';
-			*dst = '\0';
-		size -= (size_t)(dst - t);
-	/* Format partial octet. */
-	b = bits % 8;
-	if (b > 0) {
-		if (size < sizeof ".255")
-			goto emsgsize;
-		t = dst;
-		if (dst != odst)
-			*dst++ = '.';
-		m = ((1 << b) - 1) << (8 - b);
-		dst += SPRINTF((dst, "%u", *src & m));
-	/* Format CIDR /width. */
-	if (size < sizeof "/32")
-		goto emsgsize;
-	dst += SPRINTF((dst, "/%u", bits));
-	return (odst);
- emsgsize:
-	errno = EMSGSIZE;
-	return (NULL);
diff --git a/cpukit/libnetworking/libc/inet_net_pton.c b/cpukit/libnetworking/libc/inet_net_pton.c
index 3df64168f3..0000000000
--- a/cpukit/libnetworking/libc/inet_net_pton.c
+++ /dev/null
@@ -1,206 +0,0 @@
- * SOFTWARE.
-#if HAVE_CONFIG_H
-#endif
-#include <assert.h>
-#include <ctype.h>
-#include <errno.h>
-#include <stdio.h>
-#else
-#endif
-static int	inet_net_pton_ipv4 __P((const char *src, u_char *dst,
-					size_t size));
- * static int
- * inet_net_pton(af, src, dst, size)
- *	convert network number from presentation to network format.
- *	accepts hex octets, hex strings, decimal octets, and /CIDR.
- *	"size" is in bytes and describes "dst".
- * return:
- *	number of bits, either imputed classfully or specified with /CIDR,
- *	or -1 if some failure occurred (check errno).  ENOENT means it was
- *	not a valid network specification.
- * author:
- *	Paul Vixie (ISC), June 1996
-int
-inet_net_pton(af, src, dst, size)
-	int af;
-	const char *src;
-	void *dst;
-	size_t size;
-	switch (af) {
-	case AF_INET:
-		return (inet_net_pton_ipv4(src, dst, size));
-	default:
-		return (-1);
- * static int
- * inet_net_pton_ipv4(src, dst, size)
- *	convert IPv4 network number from presentation to network format.
- * return:
- *	not an IPv4 network specification.
- * note:
- * author:
-static int
-inet_net_pton_ipv4(src, dst, size)
-	const char *src;
-	u_char *dst;
-	size_t size;
-	static const char
-		xdigits[] = "0123456789abcdef",
-		digits[] = "0123456789";
-	int n, ch, tmp, dirty, bits;
-	const u_char *odst = dst;
-	ch = *src++;
-	if (ch == '0' && (src[0] == 'x' || src[0] == 'X')
-	    && isascii(src[1]) && isxdigit(src[1])) {
-		/* Hexadecimal: Eat nybble string. */
-		if (size <= 0)
-			goto emsgsize;
-		*dst = 0, dirty = 0;
-		src++;	/* skip x or X. */
-		while ((ch = *src++) != '\0' &&
-		       isascii(ch) && isxdigit(ch)) {
-			if (isupper(ch))
-				ch = tolower(ch);
-			n = strchr(xdigits, ch) - xdigits;
-			assert(n >= 0 && n <= 15);
-			*dst |= n;
-			if (!dirty++)
-				*dst <<= 4;
-			else if (size-- > 0)
-				*++dst = 0, dirty = 0;
-			else
-				goto emsgsize;
-		if (dirty)
-			size--;
-	} else if (isascii(ch) && isdigit(ch)) {
-		/* Decimal: eat dotted digit string. */
-		for (;;) {
-			tmp = 0;
-			do {
-				n = strchr(digits, ch) - digits;
-				assert(n >= 0 && n <= 9);
-				tmp *= 10;
-				tmp += n;
-				if (tmp > 255)
-					goto enoent;
-			} while ((ch = *src++) != '\0' &&
-				 isascii(ch) && isdigit(ch));
-			if (size-- <= 0)
-				goto emsgsize;
-			*dst++ = (u_char) tmp;
-			if (ch == '\0' || ch == '/')
-				break;
-			if (ch != '.')
-				goto enoent;
-			ch = *src++;
-			if (!isascii(ch) || !isdigit(ch))
-				goto enoent;
-	} else
-		goto enoent;
-	bits = -1;
-	if (ch == '/' && isascii(src[0]) && isdigit(src[0]) && dst > odst) {
-		/* CIDR width specifier.  Nothing can follow it. */
-		ch = *src++;	/* Skip over the /. */
-		bits = 0;
-		do {
-			bits *= 10;
-			bits += n;
-		} while ((ch = *src++) != '\0' && isascii(ch) && isdigit(ch));
-		if (ch != '\0')
-			goto enoent;
-		if (bits > 32)
-			goto emsgsize;
-	/* Firey death and destruction unless we prefetched EOS. */
-	if (ch != '\0')
-		goto enoent;
-	/* If nothing was written to the destination, we found no address. */
-	if (dst == odst)
-		goto enoent;
-	/* If no CIDR spec was given, infer width from net class. */
-	if (bits == -1) {
-		if (*odst >= 240)	/* Class E */
-			bits = 32;
-		else if (*odst >= 224)	/* Class D */
-			bits = 4;
-		else if (*odst >= 192)	/* Class C */
-			bits = 24;
-		else if (*odst >= 128)	/* Class B */
-			bits = 16;
-		else			/* Class A */
-			bits = 8;
-		/* If imputed mask is narrower than specified octets, widen. */
-		if (bits >= 8 && bits < ((dst - odst) * 8))
-			bits = (dst - odst) * 8;
-	/* Extend network to cover the actual mask. */
-	while (bits > ((dst - odst) * 8)) {
-		if (size-- <= 0)
-			goto emsgsize;
-		*dst++ = '\0';
-	return (bits);
- enoent:
-	errno = ENOENT;
-	return (-1);
- emsgsize:
-	errno = EMSGSIZE;
-	return (-1);
diff --git a/cpukit/libnetworking/libc/inet_neta.c b/cpukit/libnetworking/libc/inet_neta.c
index 39f2404616..0000000000
--- a/cpukit/libnetworking/libc/inet_neta.c
+++ /dev/null
@@ -1,83 +0,0 @@
- * SOFTWARE.
-#if HAVE_CONFIG_H
-#endif
-#include <errno.h>
-#include <stdio.h>
-#else
-#endif
- * char *
- * inet_neta(src, dst, size)
- *	format a u_long network number into presentation format.
- * return:
- * note:
- *	format of ``src'' is as for inet_network().
- * author:
-char *
-inet_neta(src, dst, size)
-	u_long src;
-	char *dst;
-	size_t size;
-	char *odst = dst;
-	char *tp;
-	while (src & 0xffffffff) {
-		u_char b = (src & 0xff000000) >> 24;
-		src <<= 8;
-		if (b) {
-				goto emsgsize;
-			tp = dst;
-			dst += SPRINTF((dst, "%u", b));
-			if (src != 0L) {
-				*dst++ = '.';
-				*dst = '\0';
-			size -= (size_t)(dst - tp);
-	if (dst == odst) {
-		if (size < sizeof "0.0.0.0")
-			goto emsgsize;
-		strcpy(dst, "0.0.0.0");
-	return (odst);
- emsgsize:
-	errno = EMSGSIZE;
-	return (NULL);
diff --git a/cpukit/libnetworking/libc/ns_addr.c b/cpukit/libnetworking/libc/ns_addr.c
index 2fa910e8e7..0000000000
--- a/cpukit/libnetworking/libc/ns_addr.c
+++ /dev/null
@@ -1,227 +0,0 @@
- * Copyright (c) 1986, 1993
- *	The Regents of the University of California.  All rights reserved.
- * This code is derived from software contributed to Berkeley by
- * J.Q. Johnson.
- * are met:
- *	This product includes software developed by the University of
- *	California, Berkeley and its contributors.
- * 4. Neither the name of the University nor the names of its contributors
- * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
- * SUCH DAMAGE.
-#if HAVE_CONFIG_H
-#endif
-#include <netns/ns.h>
-#include <stdio.h>
-static struct ns_addr addr, zero_addr;
-static void Field(), cvtbase();
-struct ns_addr
-ns_addr(name)
-	const char *name;
-	char separator;
-	char *hostname, *socketname, *cp;
-	char buf[50];
-	(void)strncpy(buf, name, sizeof(buf) - 1);
-	buf[sizeof(buf) - 1] = '\0';
-	 * First, figure out what he intends as a field separtor.
-	 * Despite the way this routine is written, the prefered
-	 * form  2-272.AA001234H.01777, i.e. XDE standard.
-	 * Great efforts are made to insure backward compatability.
-	if ((hostname = strchr(buf, '#')) != NULL)
-		separator = '#';
-	else {
-		hostname = strchr(buf, '.');
-		if ((cp = strchr(buf, ':')) &&
-		    ((hostname && cp < hostname) || (hostname == 0))) {
-			hostname = cp;
-			separator = ':';
-		} else
-			separator = '.';
-	if (hostname)
-		*hostname++ = 0;
-	addr = zero_addr;
-	Field(buf, addr.x_net.c_net, 4);
-	if (hostname == 0)
-		return (addr);  /* No separator means net only */
-	socketname = strchr(hostname, separator);
-	if (socketname) {
-		*socketname++ = 0;
-		Field(socketname, (u_char *)&addr.x_port, 2);
-	Field(hostname, addr.x_host.c_host, 6);
-	return (addr);
-static void
-Field(buf, out, len)
-	char *buf;
-	u_char *out;
-	int len;
-	register char *bp = buf;
-	int i, ibase, base16 = 0, base10 = 0, clen = 0;
-	int hb[6], *hp;
-	char *fmt;
-	 * first try 2-273#2-852-151-014#socket
-	if ((*buf != '-') &&
-	    (1 < (i = sscanf(buf, "%d-%d-%d-%d-%d",
-			&hb[0], &hb[1], &hb[2], &hb[3], &hb[4])))) {
-		cvtbase(1000L, 256, hb, i, out, len);
-		return;
-	 * try form 8E1#0.0.AA.0.5E.E6#socket
-	if (1 < (i = sscanf(buf,"%x.%x.%x.%x.%x.%x",
-			&hb[0], &hb[1], &hb[2], &hb[3], &hb[4], &hb[5]))) {
-		cvtbase(256L, 256, hb, i, out, len);
-		return;
-	 * try form 8E1#0:0:AA:0:5E:E6#socket
-	if (1 < (i = sscanf(buf,"%x:%x:%x:%x:%x:%x",
-		return;
-	 * This is REALLY stretching it but there was a
-	 * comma notation separting shorts -- definitely non standard
-	if (1 < (i = sscanf(buf,"%x,%x,%x",
-			&hb[0], &hb[1], &hb[2]))) {
-		hb[0] = htons(hb[0]); hb[1] = htons(hb[1]);
-		hb[2] = htons(hb[2]);
-		cvtbase(65536L, 256, hb, i, out, len);
-		return;
-	/* Need to decide if base 10, 16 or 8 */
-	while (*bp) switch (*bp++) {
-	case '0': case '1': case '2': case '3': case '4': case '5':
-	case '6': case '7': case '-':
-		break;
-	case '8': case '9':
-		base10 = 1;
-		break;
-	case 'a': case 'b': case 'c': case 'd': case 'e': case 'f':
-	case 'A': case 'B': case 'C': case 'D': case 'E': case 'F':
-		base16 = 1;
-		break;
-	case 'x': case 'X':
-		*--bp = '0';
-		base16 = 1;
-		break;
-	case 'h': case 'H':
-		base16 = 1;
-		/* fall into */
-	default:
-		*--bp = 0; /* Ends Loop */
-	if (base16) {
-		fmt = "%3x";
-		ibase = 4096;
-	} else if (base10 == 0 && *buf == '0') {
-		fmt = "%3o";
-		ibase = 512;
-	} else {
-		fmt = "%3d";
-		ibase = 1000;
-	for (bp = buf; *bp++; ) clen++;
-	if (clen == 0) clen++;
-	if (clen > 18) clen = 18;
-	i = ((clen - 1) / 3) + 1;
-	bp = clen + buf - 3;
-	hp = hb + i - 1;
-	while (hp > hb) {
-		(void)sscanf(bp, fmt, hp);
-		bp[0] = 0;
-		hp--;
-		bp -= 3;
-	(void)sscanf(buf, fmt, hp);
-	cvtbase((long)ibase, 256, hb, i, out, len);
-static void
-cvtbase(oldbase,newbase,input,inlen,result,reslen)
-	long oldbase;
-	int newbase;
-	int input[];
-	int inlen;
-	unsigned char result[];
-	int reslen;
-	int d, e;
-	long sum;
-	e = 1;
-	while (e > 0 && reslen > 0) {
-		d = 0; e = 0; sum = 0;
-		/* long division: input=input/newbase */
-		while (d < inlen) {
-			sum = sum*oldbase + (long) input[d];
-			e += (sum > 0);
-			input[d++] = sum / newbase;
-			sum %= newbase;
-		result[--reslen] = sum;	/* accumulate remainder */
-	for (d=0; d < reslen; d++)
-		result[d] = 0;
diff --git a/cpukit/libnetworking/libc/ns_ntoa.c b/cpukit/libnetworking/libc/ns_ntoa.c
index 5a93b5cd42..0000000000
--- a/cpukit/libnetworking/libc/ns_ntoa.c
+++ /dev/null
@@ -1,100 +0,0 @@
- * are met:
- * SUCH DAMAGE.
-#if HAVE_CONFIG_H
-#endif
-#include <stdio.h>
-char *
-ns_ntoa(addr)
-	struct ns_addr addr;
-	static char obuf[40];
-	union { union ns_net net_e; u_long long_e; } net;
-	u_short port = htons(addr.x_port);
-	register char *cp;
-	char *cp2;
-	register u_char *up = addr.x_host.c_host;
-	u_char *uplim = up + 6;
-	static char *spectHex();
-	net.net_e = addr.x_net;
-	sprintf(obuf, "%lx", (u_long)ntohl(net.long_e));
-	cp = spectHex(obuf);
-	cp2 = cp + 1;
-	while (*up==0 && up < uplim) up++;
-	if (up == uplim) {
-		if (port) {
-			sprintf(cp, ".0");
-			cp += 2;
-	} else {
-		sprintf(cp, ".%x", *up++);
-		while (up < uplim) {
-			while (*cp) cp++;
-			sprintf(cp, "%02x", *up++);
-		cp = spectHex(cp2);
-	if (port) {
-		sprintf(cp, ".%x", port);
-		spectHex(cp + 1);
-	return (obuf);
-static char *
-spectHex(p0)
-	char *p0;
-	int ok = 0;
-	int nonzero = 0;
-	register char *p = p0;
-	for (; *p; p++) switch (*p) {
-		*p += ('A' - 'a');
-		/* fall into . . . */
-		ok = 1;
-	case '1': case '2': case '3': case '4': case '5':
-	case '6': case '7': case '8': case '9':
-		nonzero = 1;
-	if (nonzero && !ok) { *p++ = 'H'; *p = 0; }
-	return (p);
2.13.7
