[PATCH 1/2] c-user: Mention per-processor data
Fri Sep 7 13:48:48 UTC 2018
Close #3507.
 c-user/symmetric_multiprocessing_services.rst | 18 ++++++++++++++++++
 1 file changed, 18 insertions(+)
diff --git a/c-user/symmetric_multiprocessing_services.rst b/c-user/symmetric_multiprocessing_services.rst
index 638292b..4204d3f 100644
--- a/c-user/symmetric_multiprocessing_services.rst
+++ b/c-user/symmetric_multiprocessing_services.rst
@@ -791,3 +791,21 @@ from the executing to the heir thread neither the stack of the executing nor
 the heir thread must be used during interrupt processing.  For this purpose a
 temporary per-processor stack is set up which may be used by the interrupt
 prologue before the stack is switched to the interrupt stack.
+Per-Processor Data
+RTMES provides two means for per-processor data:
+1. Per-processor data which used by RTEMS itself is contained in the
+   `Per_CPU_Control` structure.  The application configuration via
+   `<rtems/confdefs.h>` creates a table of these structures
+   (`_Per_CPU_Information[]`).  The table is dimensioned according to the count
+   of configured processors
+   (:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`).
+2. For low level support libraries an API for statically allocated
+   per-processor data is available via
+   `<rtems/score/percpudata.h> <https://git.rtems.org/rtems/tree/cpukit/include/rtems/score/percpudata.h>`_.
+   This API is not intended for general application use.  Please ask on the
+   development mailing list in case you want to use it.
2.13.7
