rtems-bsp-builder .ini file syntax question (for epiphany)
Sat Sep 8 03:23:59 UTC 2018
On 8/9/18 1:12 pm, Joel Sherrill wrote:
> On Fri, Sep 7, 2018, 10:06 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     The solution is add the excluded 'no-' variant of the 'config' to the 'base'
>     flags. The code currently removes the excluded builds from the build list, code
>     needs to be added to update the base flags.
> What's the syntax for that? Or am I making a new features request?
Just code changes.
>     A consequence of this is the need for me to handle the excludes better and
>     report any errors if not correct. Currently the support is not strict to make
>     the code simpler.
> Glad to hear it is your fault. Lol
Haha I seem to be the only committer so I suspect most problems will be mine.
> Just joking.
Yeah yeah go on kick someone when they are down with the flue! ;)
> Rather peeved that Internet is out at my house and so far Monday
> 8-10 is their solution. My laptop connected directly to the cable modem isn't a
> stable connection. Down varies and up is non-existent.
That is a bit sad, I suppose you will have time to do all those chores around
the house now.
