rtems-bsp-builder .ini file syntax question (for epiphany)
Sat Sep 8 05:57:32 UTC 2018
On 8/9/18 1:23 pm, Chris Johns wrote:
> On 8/9/18 1:12 pm, Joel Sherrill wrote:
>> On Fri, Sep 7, 2018, 10:06 PM Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>     The solution is add the excluded 'no-' variant of the 'config' to the 'base'
>>     flags. The code currently removes the excluded builds from the build list, code
>>     needs to be added to update the base flags.
>> What's the syntax for that? Or am I making a new features request?
> Just code changes.
I have pushed a change. Please let me know how you go.
Thanks
