Invalid block size of 512B while setting up RFS on RAMDisk
Udit agarwal dev.madaari at gmail.com
Mon Sep 10 02:30:27 UTC 2018
Hi list,
While setting up RFS with a block size of 512B on a RAMDisk, I had an I/O
error while formatting /dev/rda using mkrfs shell command.
Same procedure repeated for RFS on sd-card/USB-stick did worked with 512B
block size.
Any advice or a fix?
BTW, my ramdisk block size is 512B with block count of 262144. and BSP used
is BeagleBone Black.
Regards,
Udit kumar agarwal
http://uditagarwal.in/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180910/6878a2ec/attachment.html>
