Invalid block size of 512B while setting up RFS on RAMDisk
Mon Sep 10 02:49:18 UTC 2018
On 10/09/2018 12:30, Udit agarwal wrote:
> Hi list,
> While setting up RFS with a block size of 512B on a RAMDisk, I had an I/O error
> while formatting /dev/rda using mkrfs shell command.
> Same procedure repeated for RFS on sd-card/USB-stick did worked with 512B block
> size.
> Any advice or a fix?
> BTW, my ramdisk block size is 512B with block count of 262144. and BSP used is
> BeagleBone Black.
Are you able to make a small test case?
Thanks
