sparc/leon3 in git master?
Wed Sep 12 05:24:12 UTC 2018
On 11/09/2018 21:25, Cudmore, Alan P. (GSFC-5820) wrote:
> Sorry for the false alarm, but I found out why it did not work.
> My leon3 BSP configure command had –enable-smp
> Once I removed that, it worked on both QEMU and TSIM-LEON3.
At least on Qemu it used to work with SMP enabled some time ago. With
the latest Qemu the BSP starts (with SMP enabled), but the timecounter
seems not to work:
qemu-system-sparc -no-reboot -nographic -M leon3_generic -m 64M -kernel
./sparc-rtems5/c/leon3/testsuites/samples/ticker.exe
*** BEGIN OF TEST CLOCK TICK ***
*** TEST VERSION: 5.0.0.1fe1b820de02c274c2b2b3431340152734ee9fb6
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
9670d7541e0621915e521fe76e7bb33de8cee661, Newlib
d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
> The ut699 BSP worked as well.
> Does an SMP enabled kernel/bsp only work on a system where there are >
> 1 cores?
A SMP enabled BSP should work also on systems with only one processor
provided you use the right instruction set. I use for example the erc32
BSP with SMP enabled all the time for RTEMS development.
> Thanks,
> Alan
> *From: *devel <devel-bounces at rtems.org> on behalf of Alan Cudmore
> <alan.p.cudmore at nasa.gov>
> *Date: *Tuesday, September 11, 2018 at 3:01 PM
> *To: *"rtems-devel at rtems.org" <devel at rtems.org>
> *Subject: *sparc/leon3 in git master?
> I use RTEMS 4.11 on several leon3 targets, and I have been starting to
> work with the git master to get ready for RTEMS 5.
> With 4.11, I can run ticker, hello, and other samples on TSIM2-LEON3,
> QEMU with Jiri’s leon3 patches, or real Leon3 targets.
> When I run the ticker or hello for RTEMS 5 (RSB toolchain and RTEMS
> built today) on QEMU or TSIM2 they immediately return with no output.
> I tried ticker for the sparc/erc32 BSP on SIS and it works.
> Before I start debugging, has anyone else used the generic Leon3
> target on RTEMS 5 lately?
> Thanks,
> Alan
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
