Kernel-space ctypes.h support?
Thu Sep 13 08:28:40 UTC 2018
Hello,
I test currently the tqm8xx BSP which worked fine until RTEMS 5. The
problem is that this BSP uses strtoul() to get some system configuration
parameters from the boot loader. The Newlib used by RTEMS 5 has now
support for C locales in strtoul(). The C locale support needs an
executing thread with a valid Newlib reentrancy structure. This is
definitely not the case during bsp_start().
I think we need a kernel-space ctypes.h implementation without this C
locale stuff and string support functions which use this. For example
FreeBSD has this:
sys/sys/ctype.h
sys/libkern/strtoul.c
Maybe add a <rtems/string.h> header file with this content:
#define rtems_isspace(c)    ((c) == ' ' || ((c) >= '\t' && (c) <= '\r'))
#define rtems_isascii(c)    (((c) & ~0x7f) == 0)
#define rtems_isupper(c)    ((c) >= 'A' && (c) <= 'Z')
#define rtems_islower(c)    ((c) >= 'a' && (c) <= 'z')
#define rtems_isalpha(c)    (rtems_isupper(c) || rtems_islower(c))
#define rtems_isdigit(c)    ((c) >= '0' && (c) <= '9')
#define rtems_isxdigit(c)    (rtems_isdigit(c) \
                   || ((c) >= 'A' && (c) <= 'F') \
                   || ((c) >= 'a' && (c) <= 'f'))
#define rtems_isprint(c)    ((c) >= ' ' && (c) <= '~')
#define rtems_toupper(c)    ((c) - 0x20 * (((c) >= 'a') && ((c) <= 'z')))
#define rtems_tolower(c)    ((c) + 0x20 * (((c) >= 'A') && ((c) <= 'Z')))
unsigned rtems_strtol(const char *nptr, char **endptr, int base);
unsigned long rtems_strtoul(const char *nptr, char **endptr, int base);
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
